Hi all!
I’m doing a gauss filtering on image.
The steps of my goal are:
read data from an image
create a kernel
applying FFT to image and kernel data
pointwise multiplication
applying IFFT to 4. results.
If I do the same operation in MATLAB I have best accuracy.
I have read in other topics, that I must normalize the IFFT results with 1/size_fft,
or use only Z2Z/C2C cufft type because matlab use double precision data type.
I have done it, but I haven’t improvements.
The only doubt come from the C2C use, my data are float and I convert them in Complex before call cufftExecC2C:
//for
image_complex[i].x = image[i].x;
image_complex[i].y = 0;
//end for
cufftExecC2C(plan, (cufftComplex *)image_complex, (cufftComplex *)image_complex, CUFFT_FORWARD);
and on IFFT I need unsigned char data from complex:
cufftExecC2C(plan, (cufftComplex *)image_complex, (cufftComplex *)image_complex, CUFFT_INVERSE);
//for
filtered[i]=(char)image_complex[i].x;
//end for
In the end I use filtered data for bitmap visualization.
thank you for support.
Hi all!
create a kernel
//for
//end for
//for
//end for
I’m curious if you’ve tried Jacket. The Jacket GPU version in MATLAB should be identical to the CPU version. Free 15-day trial is available here (to purchase is only a few hundred bucks): http://www.accelereyes.com
-John
I need to do Image Denoising in CUDA and compare results in execution time and accuracy with Matlab that use CPU.
So, I don’t know if Jacket is useful for my goal.
There are many people using a combination of Jacket’s core functions as well as Jacket’s Image Processing Library (http://wiki.accelereyes.com/wiki/index.php/Image_Processing_Library ) for these kinds of applications. I think it would do what you need it to. Feel free to email me (see my signature below) if I can help any further.
I report this to my tutor, but it says that matlab/freemat and cudaFFT using FFTW both, so the results can’t be too different.
I have solved!
The problem was the padding!
Is it normal that for hight equal value of kernel radius and gauss delta,
is accuracy better in Matlab than CUDA ?
