i want to grab multiple images from /dev/videoX - process it with cuda and send the result to another jetson. What is the best way to do that with minimum latency?
My System:
2 Jetson Xavier with 10Gb Ethernet
JP 4.5.1
My System:
JP 4.5.1
A general approach is to send data to another device is to run RTSP. You may set up an RTSP server on Xavier through test-launch. Please refer to
Jetson Nano FAQ
Q: Is there any example of running RTSP streaming?
If you need to do deep earning inference, you can consider to use DeepStream SDK. We also have RTSP implementation in Sink Group
DeepStream Reference Application - deepstream-app — DeepStream 5.1 Release documentation
