Hello everybody.
I have a SDcard 64gb with all to boot XAVIER NX.
I made a image of that SD card on my laptop and I flashed it on a SDcard of 128gb.
The 64 sdcard works fine and boot ok, but the SDcard 128gb does not boot.
To create the image on my laptop I used:
sudo dd if=/dev/sdb64 of=~/SDCardBackup.img`
And to flash the 128gb card I used:
sudo dd bs=4M if=~/SDCardBackup.img of=/dev/sdb128.
I unmount the SDcard in all operations and I also used gparted to expand the SDcard filesystem.
Any idea of what is bringing this problem?
Thanks in advance
Do you really use path “/dev/sdb64
” or “/dev/sdb128
”? These are not valid. If you are just illustrating and naming which card, that’s fine, but actual command lines would require something like “/dev/sdb1” for the first partition.
Hi @linuxdev.
In fact this is only for illustration. I am using the paths given by the system.
Do you think if I try to copy one sdcard direct to other I will get a different result?
Copying to a host PC image file, then to the SD, should not differ versus directly from SD to SD. However, not all content is partition content. I will suggest setting up all partitions to the correct size, and then copying the image of each partition from one SD to the other, but only if this is to be used on the same NX.
The idea is that if the SD has partitions created ahead of time with something like gdisk
, then all metadata will be correct for that partition layout. After that you could use a resizing app (provided it is aware of preserving ext4 and not corrupting it) if needed.
Thank you @linuxdev.
Maybe a silly question regarding partitions:
When I check the sdcard with GParted for example, I only see one partition on sdcard. I quite did not understand what partitions you are referring. Can you, please, explain it a little more ?
Hello @linuxdev.
I made it work.
This is what I did.
I followed the steps given here:
Getting Started With Jetson Xavier NX Developer Kit | NVIDIA Developer.
I dowloaded the image from Nvidia website and flashed it on the 128gb Sdcard using balena etcher sw.
I pluged the sdcard on the board and made the initial configurations.
After that, without formating the sdcard, I used the procedure:
After that, I pluged again on the board and it booted.
As you proposed, I used gparted to extend the partition preserving the fylesystem.
I believe that, when I flashed the sdcard with Nvidia image, maybe I have restored the partition table that was not properly set before.
Thank you for your support.
On an eMMC system you would only see one partition on an SD card used for boot. On a dev kit with only SD card, the SD would have a lot of partitions. Example (this is from 2 different SD card models/installs):
Number Start (sector) End (sector) Size Code Name
1 28672 124733439 59.5 GiB 8300 APP
2 2048 2303 128.0 KiB 8300 TBC
3 4096 4991 448.0 KiB 8300 RP1
4 6144 7295 576.0 KiB 8300 EBTNumber Start (sector) End (sector) Size Code Name
1 40 29360167 14.0 GiB 0700 APP
2 29360168 29491239 64.0 MiB 0700 kernel
3 29491240 29622311 64.0 MiB 0700 kernel_b
4 29622312 29623207 448.0 KiB 0700 kernel-dtb
5 29623208 29624103 448.0 KiB 0700 kernel-dtb_b
6 29624104 29753127 63.0 MiB 0700 recovery
7 29753128 29754151 512.0 KiB 0700 recovery-dtb
8 29754152 29754663 256.0 KiB 0700 kernel-bootctrl
9 29754664 29755175 256.0 KiB 0700 kernel-bootctrl_b
10 29755176 29959975 100.0 MiB 0700 RECROOTFS
11 29959976 124735454 45.2 GiB 0700 UDA
5 8192 8319 64.0 KiB 8300 WB0
6 10240 10623 192.0 KiB 8300 BPF
7 12288 13055 384.0 KiB 8300 BPF-DTB
8 14336 14463 64.0 KiB 8300 FX
9 16384 17279 448.0 KiB 8300 TOS
10 18432 19327 448.0 KiB 8300 DTB
11 20480 22015 768.0 KiB 8300 LNX
12 22528 22655 64.0 KiB 8300 EKS
13 24576 24735 80.0 KiB 8300 BMP
14 26624 26879 128.0 KiB 8300 RP4
# OR:
Without those non-rootfs (not “APP”) partitions boot will fail. The location of the non-rootfs partitions depends on the Jetson model. Typically an eMMC model would use those on eMMC, and if booting a rootfs on SD, then only the APP/rootfs partition would be on SD. An image of rootfs on an SD card of a non-eMMC model will fail to boot.
You are probably correct that the steps you took restored a partition table, and that this is why it now boots correctly. When people manually install and do not allow the other software to reinstall there is a chance that the surrounding non-rootfs content will be broken in some way.
