I have successfully flashed the images from my machine for my custom-board with Nvidia Xavier NX, when I zip/tar/bzip/gzip the images i.e., Linux_for_tegra and /built/image/directory for flashing emmc based board it boots fine but HDMI doesn’t turn on.
The issue I see is there’s a backlight turned on in the HDMI screen, the ttyACM0 port is giving serial console only HDMI doesn’t give the GUI experience after doing the first time system configuration.
I see that BUILD_IMG/ directory has root permissions when I compress the file the binaries for userspace apps or kernel modules for HDMI must be non-executable.
Kindly, help me with best way to compress and send images over for other PCs to flash the board.
Firstly, thanks for the response.
I tried to copy the binaries built :
BUILD_IMG/
Linux_for_tegra/
to flash binaries from other system. This validation is being done so that anyone can flash the images from shared memory.
I resolved the error of ownership and group assigned to the directories.
By using chown and chgrp to make root user alone to access.
But I am facing same issue, flash done but no GUI on HDMI.
Is there any information on L4T which can cause this issue ??
