Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
[+] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
SDK Manager Version
[+] 1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
[+] native Ubuntu 18.04
other
I was trying to generate world points from the image points generated from lane detection sample. (Since the world points variable in dwlaneDetector_detectlanes was always giving 0 as output).
I followed below link to generate the world points (without lane graph) How to transform points from image space to world space?
But When I plotted the world points of the lanes obtained, it is not as expected.(the lateral coordinates varies too much). Please find the world points plot and corresponding image points plots attached.
Hi @SivaRamaKrishnaNV , main.cpp (34.6 KB)
Please find the attached main file.
I have commented rendering section as I was facing some difficulties in visualization. (I did visualizations above in MATLAB).
I have just added the code snippet for world point generation. Also pointed the rig file in sample lane detection as required.
I have calculated the xGround (long) and yGround (lat) points as shown in image and plotted these values.
As you can see from plots the lateral coordinates of points on same lane line changes considerably . For example yellow line changes y from 1 to around 13, but as from image we can see its a straight road and heading almost parallel to road. In such cases our y values should be almost constant right? please correct me if I am wrong.
I just saved the ground points generated for each lane line in a frame and plotted between xGround and yGround. Currently as a trial I printed points to console in debug mode and copied from there to create .mat files and plotted in matlab.
Kindly let me know if any other details required.
At last figured out what was going wrong with me. I should have checked the documentation and rig file little more carefully. Resized images are used in lane detection sample . I should multiply the image points with the image rescale factor before finding world points. Now am getting the lane lines almost parallel and values seems to be correct. Thanks for the support.
