Hi all.
This is part of the pseudo code I am implementing in CUDA as part of an image reconstruction algorithm:
for each xbin(0->detectorXDim/2-1):
for each ybin(0->detectorYDim-1):
rayInit=(xbin*xBinSize+0.5,ybin*xBinSize+0.5,-detectordistance)
rayEnd=beamFocusCoord
slopeVector=rayEnd-rayInit
//knowing that r=rayInit+t*slopeVector;
//x=rayInit[0]+t*slopeVector[0]
//y=rayInit[1]+t*slopeVector[1]
//z=rayInit[2]+t*slopeVector[2]
//to find ray xx intersections:
for each xinteger(xbin+1->detectorXDim/2):
solve t for x=xinteger*xBinSize;
find corresponding y and z
add to intersections array
//find ray yy intersections(analogous to xx intersections)
//find ray zz intersections(analogous to xx intersections)
So far, this is what I have come up with:
__global__ void sysmat(int xfocus,int yfocus, int zfocus, int xbin,int xbinsize,int ybin,int ybinsize, int zbin, int projecoes){
int tx=threadIdx.x, ty=threadIdx.y,tz=threadIdx.z, bx=blockIdx.x, by=blockIdx.y,i,x,y,z;
int idx=ty+by*blocksize;
int idy=tx+bx*blocksize;
int slopeVectorx=xfocus-idx*xbinsize+0.5;
int slopeVectory=yfocus-idy*ybinsize+0.5;
int slopeVectorz=zfocus-zdetector;
__syncthreads();
//points where the ray intersects x axis
int xint=idx+1;
int yint=idy+1;
int*intersectionsx[(detectorXDim/2-xint)+(detectorYDim-yint)+(zfocus)];
int*intersectionsy[(detectorXDim/2-xint)+(detectorYDim-yint)+(zfocus)];
int*intersectionsz[(detectorXDim/2-xint)+(detectorYDim-yint)+(zfocus)];
for(xint=xint; xint<detectorXDim/2;xint++){
x=xint*xbinsize;
t=(x-idx)/slopeVectorx;
y=idy+t*slopeVectory;
z=z+t*slopeVectorz;
intersectionsx[xint-1]=x;
intersectionsy[xint-1]=y;
intersectionsz[xint-1]=z;
__syncthreads();
So, this is just a piece of the code. I know that there might be some errors(you can point them if they are blatantly wrong) but what I am more concerned is this:
Each thread(which corresponds to a detector bin) needs three arrays so it can save the points where the ray(which passes through this thread/bin) intersects multiples of the x,y and z axis. Each array’s length depend on the place of the thread/bin(it’s index) in the detector and on the beamFocusCoord(which are fixed). In order to do this I wrote this piece of code, which I am almost certain can not be done:
int*intersectionsx[(detectorXDim/2-xint)+(detectorXDim-yint)+(zfocus)];
int*intersectionsy[(detectorXDim/2-xint)+(detectorXDim-yint)+(zfocus)];
int*intersectionsz[(detectorXDim/2-xint)+(detectorXDim-yint)+(zfocus)];
In the end I wanted to be sure that this is wrong, and how can I have one thread be responsible for three arrays, which length depend on the thread’s index
