Image signing fails with tegrahost_v2 fails with Error: Return value -11
I’m using BSP 35.2 for Jetson Xavier and I’m running flash.sh to sign the images, but the signig fails with the following log:
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0440 ] Using default ramcode: 0
[   0.0440 ] Disable BPMP dtb trim, using default dtb
[   0.0440 ]
[   0.0584 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0585 ] Assuming zero filled SBK key
[   0.0481 ] Generating RCM messages
[   0.0497 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
Command tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
I have a few questions about that tegrahost_v2 tools:
  • What does it do?
  • What could cause the return value -11?
hello aleksei.fedotov,
may I also have your complete command-line for reference?
besides, did you fused your device or not?
I’m running the following command
FAB=100 BOARDID=3668 BOARDSKU=0001 BOARDREV= CHIPREV=2 FUSELEVEL="fuselevel_production" ROOTFS_AB=1 NO_ROOTFS=1 NO_RECOVERY_IMG=1 ./flash.sh --no-flash --no-systemimg --no-root-check --bup --multi-spec jetson-xavier-nx-devkit-emmc mmcblk0p1
The device I want to flash is fused but not connected.
since the target is fused, you’ll need to provide all those keys.
besides, these commands looks contradiction. are you trying to speed-up the process to create sign/encrypt binary files?
I already run flash.sh to sign the binaries and I’m running this command just to generate capsule update (BUP) for the device.
there’s a script file, l4t_generate_soc_capsule.sh.
please see-also developer guide, Generating the Capsule Update Payload.
besides,
you may see-also external wiki page for the steps to run capsule update.
