Has anyone implemented image stabilization in CUDA? What’s the best way to go about it? Is it to use an FFT based 2D correlation to find the offsets or are there ways of estimating how much an image has moved using textures? Any advice or help is appreciated!
Iain
Do you plan to also stabilize against rotation? Or just translation…
Initially just translation but eventually rotation.
For your initial goal a simple 2D correlation along a representative pixel column and row will work.
CUDA is fast enough to perform a correlation even without using an FFT.
If you also want to track rotation, maybe the optical flow code from the link below might be able to generate an estimated displacement per pixel, which you could try to match up against a combined rotation/displacement matrix.
http://forums.nvidia.com/index.php?showtopic=105611
The translatory displacement would be obtained by averaging over all pixel displacement values in the X and Y directions.
For matching against a rotation matrix I can imagine a search in parameter space, similar to how a (generalized) Hough transform is able to identify lines and other shapes in a 2D image. Your parameters are x,y coordinates for the center of rotation and the rotation angle. So that’s three dimensional parameter space to search in. It is certainly not a simple problem.
Are there any better and simpler methods for estimating the rotation matrix, given two camera images?
Christian
