Image taken via tiler_sink_pad_probe is damaged
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.1-b110
• TensorRT Version 8.2
I use similar code as shown in deepstream_imagedata-multistream.py in deepstream_python_apps/apps/deepstream-imagedata-multistream/deepstream_imagedata-multistream.py at v1.1.1 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
The simplified code of tiler_sink_probe is
gst_buffer = info.get_buffer()
buffer_hash = hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(buffer_hash)
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
cv_frame_buf = pyds.get_nvds_buf_surface(buffer_hash, frame_meta.batch_id)
cv_frame = np.array(cv_frame_buf, copy=True, order='C')
cv_frame = cv2.cvtColor(cv_frame, cv2.COLOR_RGBA2BGR) #A)
cv2.imwrite(f"/tmp/img_{frame_meta.frame_num}.jpg", cv_frame)
but the saved images are still broken. Please, could you help me somehow?
Are you using a rtsp source or a local file source? From the image attached, it looks like a network packet loss in rtsp.
No, I use the CSI camera as a source. And, a few of the first images look like the following:
OK. Could you save the output to video by referring to our FAQ? We can rule out whether opencv is the cause of the issue by that.
The output shown on my monitor is completely OK. Problematic are only pictures saved via the tiler_sink_probe. Also, another strange thing is that on my laptop the code works correctly and pictures saved via the tiler_sink_probe are OK too. Only Jetson Nano seems to be somehow problematic
What exactly do you mean by the image damage? Can you describe it in detail and attach the original image?
