Image with timestamp embedded to it
Hi Team, i’m currently using HTE in orin AGX for getting the time stamp for the every rising edge pulse from the i’m getting the time stamp and then those time stamp is embedded to the image buffer at the start of the image in first 32 bit of an image
is there any way that i can append the timestamp from the HTE to the image time stamp with out affecting the other pule time to it
for time stamp from HTE to vi layer im using the extern variables for it to acces the time stamp to append in the image
Why i’m append the time stamp in image is(as of now dmesg timestamp and image starting 32 bit time stamp are same for every pulse
dev kit- AGX Orin dev kit
jetpack 6.1.0
thanks.
Don’t have clear understand your question.
Below is the timestamp discussion topic for your reference.
