Image2D OpenCL & Snow Leopard
I have a problem with an OpenCL code that runs correctly on Windows XP and 7 on different graphic cards (GF 8400GS, GF 9500GT, GTX285, GTX 470, Quadro 4000).
But with Snow Leopard on a mac mini (9400m) the code doesn’t work and we get the following errors:
  1. After a clEnqueueReadBuffer → CL_INVALID_COMMAND_QUEUE
  2. When we try to use clCreateImage2D with the following image format configuration
cl_image_format image_format;
image_format.image_channel_order = CL_INTESITY;
image_format.image_channel_data_type = CL_FLOAT;
we get the error : CL_IMAGE_FORMAT_NOT_SUPPORTED.
Is there a problem with OsX SL and OpenCL?
I try to install the latest cuda 4 driver and it changes nothing;
Thanks for your help.
Not all image formats are mandatory for an OpenCL implementation. Does clGetSupportedImageFormats() return that format?
I didn’t know this function. I will try it.
Thanks a lot.
OpenCL implementation in osX snow loepard seems to not support our image format.
Unfortunately no format supported can answer to our problem.
That’s a bad news
Any idea for the first problem? Is a bad kernel execution can corrupt the command queue and return CL_INVALID_COMMAND_QUEUE when we use it after?
Thanks a lot.
I’ve no idea. Do other operations on the same queue succeed?
It seems that a bad kernel execution corrupt the command queue and there is no other solution than create a new command queue.
