Hi, I am trying to get the ImageColorToGrayscale from Module 3 to verify, but I always seem to get the error “Failed to grade solution.” This happens both when I use my own .cu file and the solution provided in the the teaching kit. Is there a configuration I am missing? I am running the latest teaching kit from the master on bitbucket.
Output below:
user@host:~/gputeachingkit-labs$ ./ImageColorToGrayscale_Solution -e ~/ece597_gpu/labs/lab03/code/work/ImageColorToGrayscale/Dataset/0/output.pbm -i ~/ece597_gpu/labs/lab03/code/work/ImageColorToGrayscale/Dataset/0/input.ppm
{"data": {"elapsed_time": 599459, "end_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "end_function": "main", "end_line": 73, "end_time": 3118079243204168, "id": "1b684cf8-2940-4185-ac63-004d59ad7555", "idx": 1, "kind": "GPU", "message": "Doing GPU memory allocation", "mpi_rank": 0, "parent_id": 0, "session_id": "session_id_disabled", "start_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "start_function": "main", "start_line": 68, "start_time": 3118079242604709, "stopped": true}, "id": "1b684cf8-2940-4185-ac63-004d59ad7555", "session_id": "session_id_disabled", "type": "timer"}
{"data": {"elapsed_time": 394334, "end_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "end_function": "main", "end_line": 79, "end_time": 3118079243749774, "id": "b8a380cc-5abf-429e-8282-4648ce70252a", "idx": 2, "kind": "Copy", "message": "Copying data to the GPU", "mpi_rank": 0, "parent_id": 0, "session_id": "session_id_disabled", "start_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "start_function": "main", "start_line": 75, "start_time": 3118079243355440, "stopped": true}, "id": "b8a380cc-5abf-429e-8282-4648ce70252a", "session_id": "session_id_disabled", "type": "timer"}
{"data": {"elapsed_time": 55369, "end_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "end_function": "main", "end_line": 90, "end_time": 3118079243870624, "id": "9b8ee39c-416a-4431-8c3f-738cfde4ead0", "idx": 3, "kind": "Compute", "message": "Doing the computation on the GPU", "mpi_rank": 0, "parent_id": 0, "session_id": "session_id_disabled", "start_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "start_function": "main", "start_line": 82, "start_time": 3118079243815255, "stopped": true}, "id": "9b8ee39c-416a-4431-8c3f-738cfde4ead0", "session_id": "session_id_disabled", "type": "timer"}
{"data": {"elapsed_time": 191808, "end_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "end_function": "main", "end_line": 97, "end_time": 3118079244120002, "id": "25119fee-68d0-4d33-825b-7a5e6643b950", "idx": 4, "kind": "Copy", "message": "Copying data from the GPU", "mpi_rank": 0, "parent_id": 0, "session_id": "session_id_disabled", "start_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "start_function": "main", "start_line": 93, "start_time": 3118079243928194, "stopped": true}, "id": "25119fee-68d0-4d33-825b-7a5e6643b950", "session_id": "session_id_disabled", "type": "timer"}
{"data": {"elapsed_time": 1593223, "end_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "end_function": "main", "end_line": 99, "end_time": 3118079244179523, "id": "bfd9d4b3-3c38-4077-a2ac-d62db83fc7a3", "idx": 0, "kind": "GPU", "message": "Doing GPU Computation (memory + compute)", "mpi_rank": 0, "parent_id": -1, "session_id": "session_id_disabled", "start_file": "/home/user/gputeachingkit-labs/Module3/ImageColorToGrayscale/solution.cu", "start_function": "main", "start_line": 66, "start_time": 3118079242586300, "stopped": true}, "id": "bfd9d4b3-3c38-4077-a2ac-d62db83fc7a3", "session_id": "session_id_disabled", "type": "timer"}
{"data": {"file": "/home/user/gputeachingkit-labs/libwb/wbSolution.cpp", "function": "wbSolution", "id": "c87b25b7-d384-47bd-a5ee-32b9c0e3495c", "level": "Error", "line": 145, "message": "Failed to grade solution", "mpi_rank": 0, "session_id": "session_id_disabled", "time": 3118079244234459}, "id": "c87b25b7-d384-47bd-a5ee-32b9c0e3495c", "session_id": "session_id_disabled", "type": "logger"}
{"data": {"correctq": false, "message": ""}, "type": "solution"}
