Hi, I am writing a particle filter on TX2 with C++. The code is like this:
//LanMaker
struct LandMarker{
double x, y, theta;
//Particle class
class Particle{
void update(double move, double steer, vector<LandMarker> cones, vector<LandMarker> map){
for (LandMarker& l1 : cones){
for (LandMarker& l2 : maps){
///do something
//Particle Filter main function
//this loop is the most time consuming part
vector<LandMarker> cones = ....
vector<LandMarker> maps = ....
for (Particle& p : particleArray) {
double move = ...
double steer = ...
p.update(move, steer, _cones, _map);
I am thinking putting the “p.update” into multi-thread since TX2 has many cores. The code needs to wait for all Particle got updated and then exit the for loop.
I personally has not experience with multi thread code. I am wondering if anyone can help me and show some sample code?
Also, is it a good idea to use the GPU to implement the p.update?
Thank you very much.
