Hello, my name is Alex. I need to implement Average Pooling on Tensor object in C++ by using cuDNN 9.5. Function cudnnPoolingForward and related descriptor functions are deprecated. Thanks in advance.
Here are some potential solutions to implement Average Pooling on a Tensor object in C++ using cuDNN 9.5, considering that cudnnPoolingForward
and related descriptor functions are deprecated:
Transition to the PyTorch Quantization Library:
- Utilize the PyTorch Quantization Library, which includes classes like
QuantAvgPool2d
,QuantAvgPool3d
, andQuantAdaptiveAvgPool1d
, suitable for average pooling operations.
Utilize TensorRT for Average Pooling:
- Explore the TensorRT C++ API for implementing Average Pooling. This allows you to create and configure layers for average pooling without relying on deprecated cuDNN functions.
Explore Alternative Libraries:
- Consider using other deep learning libraries that provide optimized implementations for Average Pooling operations compatible with cuDNN 9.5 or newer.
Consult Official Documentation and Forums:
- Refer to the official cuDNN and TensorRT documentation for updates or replacements for the deprecated pooling functions. Engaging with community forums can also provide valuable insights.
Custom Implementation:
- If necessary, implement a custom Average Pooling operation using lower-level CUDA programming or custom kernel implementations, offering a solution tailored to your specific needs.
For specific guidance and detailed instructions, consult the official documentation of the relevant libraries and explore community resources.
