With cuda support OpenCV library it cost 3 seconds to infer a flow from two frames, my goal is to build a python program that can calculate dense optical about 5 ~ 10 FPS.
Any suggestion about API or SDK I can start with?
Unfortunately, we don’t have a dense optical flow sample for Nano.
Have you maximized the device performance when running OpenCV?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
More, maybe you can downscale the image to see if any improvemnt if this is acceptable.
