hello,
i have a question for the developer of the tegra decoder:
i want to use multi-threading decoder to decode the h264 nalu streams, i created 3 threads to run the sample code of the tegra docder(00_video_decode), i can decode the h264 nalu strreams successfully, but when i want to destroy the decoder context, the code is below:
if (ctx.conv)
ctx.conv->capture_plane.waitForDQThread(-1);
it will block in this function, never to exit.
so i want to get some helps for this problem:
1 can the tegra decoder support the multi-threading?
2 why the code will block in that function?
thanks!
