Implement this function x^y
Hi @ all
It is possible to implement the function x^y in cuda?
X is a float1 vector and y is a float constant.
Here is a example:
float y = 0.234;
float1 x ={1,2,3,4,5};
x1= 1^0.234;
x2= 2^0.234
x3= 3^0.234
x4= 4^0.234
x5= 5^0.234
__global__ powerVector(float *in, float* out, float y, unsigned int length)
   tid = threadIdx.x + blockIdx.x*blockDim.x;
if( tid >= length )
	 return;
out[tid] = powf(in[tid], y);
Have a look at this forum topic.
Oh, this is your post!!! :wacko:
Please, read the CUDA Programming Guide. :thumbup:
I dont understand this code segment.
if( tid >= length )
return;
Is this function abort if the length is to large?
For example the x vector has 512*256 elements, then I call the function “powerVector” with this code:
powerVector <<<512*256/512,512>>> --> How great is the variable tid? (I have a NVIDIA 9800GXT+ GPU)
The tid equals:
0 for the first thread of block 0,
1 for the second thread of block 0,
511 for the last thread of block 0,
512 for the first thread of block 1,
(512*256/512-1)512 + 511 for the last thread of block 512256/512 -1 (last block).
INDEED the tid IS threadIdx.x + blockIdx.x*blockDim.x;
blockIdx.x is the number of the current block (0 … 512*256/512-1)
blockDim.x is the number of threads per block (512)
threadIdx.x is the number of the current thread within th current block (0 … 512-1).
When length is 130 and blocksize is 128 you may launch your kernel with <<<2, 128>>> so there are threads whose tid is greater than length.
PLEASE READ THE PROGRAMMING GUIDE
Thanks for your Information. I think the Programming Guide is very bad for newbie.
If it possible to take the double precision pow in cuda 2.1?
Maximum ulp error pow = 7 --> single precision
Maximum ulp error pow = 2 --> double precision
my idea:
  1. copy input data (datatype float) in second memory (datatype double)
  2. use the pow function (double precision)
  3. copy the results back in output data memory (datatype float) --> necessary to save bandwidth (copy results from GPU to CPU)
It is good enough to answer most of your questions. ;-)
Don’t forget to convert. Memcpy from
float *a
to
double *b
won’t work.
AGAIN: READ A BOOK (about the C Programming language).
You may try this:
if( tid >= length )
	 return;
out[tid] = (float) YOUR_DOUBLE_PREC_POW( (double)in[tid], y);
Cave: Storing the results in single precision may result in rounding errors. But this need not be a disadvantage.
–Edit: Meh, ignore me. If people feel like helping you, good for you.
Thanks I will your program.
If i use float datatype the result is 3^0,0135 = 1,0149417 but I need a better precision.
[b]
If I use double precision datatype 3^0,0135 =0.0 --> Have cuda a problem with double precision datatype?
Here is my Code[/b]
/* Example showing the use of CUFFT for fast 1D-convolution using FFT. */
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cufft.h>
#include <cutil_inline.h>
static global void absolute_value(double*, double*, double, unsigned int);
// declaration, forward
void runTest(int argc, char** argv);
// The filter size is assumed to be a number smaller than the signal size
#define SIGNAL_SIZE 512*256
#define TEST 0.0135
// Program main
int main(int argc, char** argv)
runTest(argc, argv);
cutilExit(argc, argv);
//! Run a simple test for CUDA
if( cutCheckCmdLineFlag(argc, (const char**)argv, “device”) )
    cutilDeviceInit(argc, argv);
else
    cudaSetDevice( cutGetMaxGflopsDeviceId() );
// Allocate host memory for the signal
double* h_signal_a = (double*)malloc(sizeof(double) * SIGNAL_SIZE);
double* h_results = (double*)malloc(sizeof(double) * SIGNAL_SIZE);
// Initalize the memory for the signal
for(unsigned int i = 0; i < SIGNAL_SIZE; ++i)
    h_signal_a[i] = 3.0;
for(unsigned int i = 0; i < 10; ++i)
    printf("Wert: %f \n", h_signal_a[i]);
int mem_size = sizeof(double) * SIGNAL_SIZE;
// Allocate device memory for signal
double* d_signal_a;
cutilSafeCall(cudaMalloc((void**)&d_signal_a, mem_size));
double* d_signal_b;
cutilSafeCall(cudaMalloc((void**)&d_signal_b, mem_size));
// Copy host memory to device
cutilSafeCall(cudaMemcpy(d_signal_a, h_signal_a, mem_size, cudaMemcpyHostToDevice));
// Multiply the coefficients together and normalize the result
absolute_value<<<SIGNAL_SIZE/512, 512>>>(d_signal_a,d_signal_b,TEST,SIGNAL_SIZE);
// Check if kernel execution generated and error
cutilCheckMsg("Kernel execution failed [ absolute_value ]");
// Copy device memory to host
cutilSafeCall(cudaMemcpy(h_results, d_signal_b, mem_size, cudaMemcpyDeviceToHost));
// Das Ergebnis anzeigen
for (unsigned int i = 0; i < 10; ++i)
    printf(" Ergebnis: %2.20f \n", h_results[i]);
// cleanup memory
free(h_signal_a);
cutilSafeCall(cudaFree(d_signal_a));
cudaThreadExit();
// Betrag berechnen
global void absolute_value(double in, double out, double y, unsigned int length)
int tid = threadIdx.x + blockIdx.x*blockDim.x;
if( tid >= length )
    return;
//out[tid] = pow(in[tid], y);
Double precision is only available on compute capability 1.3 devices (GTX200 based products).
As others have advised you on many occasions, please read the documentation…
At the moment I have a 9800GTX+ but in 2 weeks i have a 285gtx. The I will test this again.
