implementation faster sgemm
Hi, I’m trying to implement a kernel of sgemm faster then Sdk sample.
I read this link and this link but source code are very hard to me.
I just read this Volkov talk http://www.cs.berkeley.edu/~volkov/volkov10-GTC.pdf
specially Part IV and I try to make same changes to sdk code.
With block-size=16 I can see some speed increase, but test failed !!
I use makefile of sdk to compile program, but I don’t understand how to remove “–maxrregcount 32" parameter if it is default set.
However I have this results :
test with kernel changed
test with original kernel
block size 32 - test with kernel changed
here code of kernel
__global__ void
matrixMul3( float* C, float* A, float* B, int wA, int wB)
    // Block index
    int bx = blockIdx.x;
    int by = blockIdx.y;
// Thread index
    int tx = threadIdx.x;
    int ty = threadIdx.y;
// Index of the first sub-matrix of A processed by the block
    int aBegin = wA * BLOCK_SIZE * by;
// Index of the last sub-matrix of A processed by the block
    int aEnd   = aBegin + wA - 1;
// Step size used to iterate through the sub-matrices of A
    int aStep  = BLOCK_SIZE;
// Index of the first sub-matrix of B processed by the block
    int bBegin = BLOCK_SIZE * bx;
// Step size used to iterate through the sub-matrices of B
    int bStep  = BLOCK_SIZE * wB;
// Csub is used to store the element of the block sub-matrix
    // that is computed by the thread
    float Csub[2] = {0,0};
// Loop over all the sub-matrices of A and B
    // required to compute the block sub-matrix
    for (int a = aBegin, b = bBegin;
             a <= aEnd;
             a += aStep, b += bStep) {
// Declaration of the shared memory array As used to
        // store the sub-matrix of A
        __shared__ float As[BLOCK_SIZE][BLOCK_SIZE];
// Declaration of the shared memory array Bs used to
        // store the sub-matrix of B
        __shared__ float Bs[BLOCK_SIZE][BLOCK_SIZE];
// Load the matrices from device memory
        // to shared memory; each thread loads
        // one element of each matrix
        AS(ty,tx) = A[a + wA * ty + tx];
        BS(ty,tx) = B[b + wB * ty + tx];
	AS(ty+16,tx) = A[a + wA * (ty+16) + tx];
        BS(ty+16,tx) = B[b + wB * (ty+16) + tx];
// Synchronize to make sure the matrices are loaded
        __syncthreads();
	// Multiply the two matrices together;
        // each thread computes one element
        // of the block sub-matrix
#pragma unroll
        for (int k = 0; k < BLOCK_SIZE; ++k)
            Csub[0] += AS(ty,k) * BS(k,tx);
	    Csub[1] += AS(ty+16,k) * BS(k,tx);
        // Synchronize to make sure that the preceding
        // computation is done before loading two new
        // sub-matrices of A and B in the next iteration
        __syncthreads();
// Write the block sub-matrix to device memory;
    // each thread writes one element
    int c = wB * BLOCK_SIZE * by + BLOCK_SIZE * bx;
    C[c + wB * ty + tx] = Csub[0];
    C[c + wB * (ty+16) + tx] = Csub[1];
I want know another thing, why cuda sdk kernel with block-size=32 failed ??
