Implementation Guide: DGX Spark with Qwen3.5-35B-A3B via llama.cpp for Claude Code
Hey all, this setup has really been working out for me. 128K context so I can reasonably use this model for substantial coding and openclaw and it benches at:
Qwen3.5-35B-A3B — Performance Benchmark
Model: Qwen3.5-35B-A3B-UD-Q4_K_XL
Backend: llama-server (llama.cpp)
Date: 2026-04-01
Runs per task: 2 (mean ± stdev reported)
Hardware & Configuration
Parameter Value
Hardware DGX Spark / GB10 (Blackwell SM121)
GPU offload All layers (-ngl 999)
Context size 131,072 tokens
Batch / ubatch size 2,048
KV cache type Q8_0 (K and V)
Flash attention Enabled
Memory mapping Disabled (--no-mmap)
Quantisation Q4_K_XL
Reasoning (chain-of-thought) Disabled (--reasoning off)
Temperature 0.0 (deterministic)
Metrics are server-side timings from llama-server’s timings response field — not wall-clock estimates.
Results by Task
Tiny Prompt / Short Answer
Metric Mean ± Stdev
Prompt tokens 8
Output tokens 32 0
Prefill speed (t/s) 94.8 8.2
Generation speed (t/s) 48.2 0.3
TTFT / prefill time (ms) 85 7
Total wall time (ms) 778 20
Factual Q&A
Metric Mean ± Stdev
Prompt tokens 19
Output tokens 64 0
Prefill speed (t/s) 163.4 36.7
Generation speed (t/s) 47.8 0.2
TTFT / prefill time (ms) 119 27
Total wall time (ms) 1,576 166
Short Code Generation
Metric Mean ± Stdev
Prompt tokens 19
Output tokens 256 0
Prefill speed (t/s) 201.3 47.3
Generation speed (t/s) 55.2 0.1
TTFT / prefill time (ms) 97 23
Total wall time (ms) 4,846 108
Complex Code Generation
Metric Mean ± Stdev
Prompt tokens 46
Output tokens 512 0
Prefill speed (t/s) 440.6 12.7
Generation speed (t/s) 48.2 6.4
TTFT / prefill time (ms) 104 3
Total wall time (ms) 10,850 1,421
Multi-step Reasoning
Metric Mean ± Stdev
Prompt tokens 69
Output tokens 300 0
Prefill speed (t/s) 543.9 15.9
Generation speed (t/s) 52.6 0.1
TTFT / prefill time (ms) 127 4
Total wall time (ms) 5,857 41
Long-form Generation (~600 tokens)
Metric Mean ± Stdev
Prompt tokens 44
Output tokens 600 0
Prefill speed (t/s) 400.7 0.5
Generation speed (t/s) 52.4 0.0
TTFT / prefill time (ms) 110 0
Total wall time (ms) 11,571 21
Long Context / Summarisation
Metric Mean ± Stdev
Prompt tokens 300
Output tokens 400 0
Prefill speed (t/s) 1,221.4 45.0
TTFT / prefill time (ms) 246 9
Total wall time (ms) 7,974 45
Summary Table
Task Prompt tok Output tok Prefill (t/s) Generation (t/s) TTFT (ms) Wall (ms)
Tiny prompt 8 32 94.8 48.2 85 778
Factual Q&A 19 64 163.4 47.8 119 1,576
Short code gen 19 256 201.3 55.2 97 4,846
Complex code gen 46 512 440.6 48.2 104 10,850
Multi-step reasoning 69 300 543.9 52.6 127 5,857
Long-form generation 44 600 400.7 52.4 110 11,571
Long context / summarisation 300 400 1,221.4 52.4 246 7,974
Overall
Metric Value
Mean generation speed 51.0 t/s
Min generation speed 47.8 t/s
Max generation speed 55.2 t/s
Mean prefill speed 438.0 t/s
Peak prefill speed (300-tok prompt) 1,221.4 t/s
TTFT range 85–246 ms
Key observations
  • Generation speed is highly stable — stdev is ≤ 0.3 t/s on most tasks, indicating consistent GPU utilisation with no thermal throttling.
  • Prefill speed scales with prompt length — short prompts (8–19 tokens) prefill at 95–201 t/s; a 300-token prompt reaches 1,221 t/s, reflecting better GPU parallelism over larger batches.
  • TTFT is low and predictable — 85–130 ms for typical prompts, rising to ~246 ms only for the 300-token context input.
  • No KV cache reuse across requests (cache_hits = 0 on all runs) — a prefix cache or system-prompt cache could reduce TTFT further for repeated prompts.
Implementation Guide: Qwen3.5-35B-A3B via llama.cpp for Claude Code
Serves Qwen3.5-35B-A3B (MoE) locally using llama-server with its native Anthropic
Messages API, so Claude Code points directly at it — no proxy or shim required.
Target hardware: NVIDIA DGX Spark / GB10 (Blackwell, SM121 / CUDA 12.1)
Prerequisites
Requirement Notes
Ubuntu/Debian Linux (other distros: adjust apt-get commands)
NVIDIA GPU (Blackwell / SM121) The build flags are SM121-specific; adjust CMAKE_CUDA_ARCHITECTURES for other GPUs
CUDA toolkit installed nvcc must be available, typically at /usr/local/cuda/bin/nvcc
git For cloning llama.cpp
uv (Python package manager) Used to download the model via huggingface_hub
~25 GB free disk space For the GGUF model file (~20 GB)
~25 GB GPU VRAM To run 35B MoE fully on GPU
Step 1 — Install uv
uv manages the Python environment and model download dependencies.
curl -LsSf https://astral.sh/uv/install.sh | sh
# Restart your shell or run:
source ~/.local/bin/env
uv --version   # verify
Step 2 — Build llama.cpp with CUDA support
2a. Install the required system library
sudo apt-get install libcurl4-openssl-dev
This enables llama-server’s built-in HuggingFace download flag (-hf).
2b. Clone the repository
git clone https://github.com/ggml-org/llama.cpp.git
cd llama.cpp
2c. Set CUDA paths
export CUDACXX=/usr/local/cuda/bin/nvcc
export PATH=/usr/local/cuda/bin:$PATH
Verify nvcc location: find /usr/local -name nvcc 2>/dev/null
If it’s in a different path, update CUDACXX accordingly.
2d. Configure the build
cmake -B build \
  -DGGML_CUDA=ON \
  -DLLAMA_CURL=ON \
  -DGGML_CUDA_FA_ALL_QUANTS=ON \
  -DCMAKE_CUDA_ARCHITECTURES=121 \
  -DGGML_NATIVE=ON
Flag Purpose
DGGML_CUDA=ON Enable CUDA GPU acceleration
DLLAMA_CURL=ON Enable HuggingFace download support
DGGML_CUDA_FA_ALL_QUANTS=ON Flash attention across all quantization types (needed for q8_0 KV cache)
DCMAKE_CUDA_ARCHITECTURES=121 Target Blackwell SM121; change to 89 for Ada, 86 for Ampere, etc.
DGGML_NATIVE=ON Optimize for the host CPU architecture
2e. Compile and install
cmake --build build --config Release -j 20
sudo cp build/bin/llama-server /usr/local/bin/
sudo cp build/bin/llama-cli    /usr/local/bin/
sudo cp build/bin/llama-bench  /usr/local/bin/
The -j 20 uses 20 parallel jobs — tune to your CPU core count. Compilation takes
5–15 minutes.
Verify:
llama-server --version
Step 3 — Download the model
The model is Qwen3.5-35B-A3B-UD-Q4_K_XL.gguf from the
unsloth/Qwen3.5-35B-A3B-GGUF repo on HuggingFace (~20 GB).
Run from the project directory
(~/data/ollama_configs/qwen-3-5-30b-moe-claude-code/):
cd ~/data/ollama_configs/qwen-3-5-30b-moe-claude-code
uv run --with "huggingface_hub>=0.24" --with hf_transfer \
    python3 -c "
import huggingface_hub
from huggingface_hub import hf_hub_download
import os
os.environ['HF_HUB_ENABLE_HF_TRANSFER'] = '1'
hf_hub_download(
    repo_id='unsloth/Qwen3.5-35B-A3B-GGUF',
    filename='Qwen3.5-35B-A3B-UD-Q4_K_XL.gguf',
    local_dir=os.path.expanduser('~/data/ollama_configs/qwen-3-5-30b-moe-claude-code/qwen3.5-35b-a3b'),
print('Done.')
HF_HUB_ENABLE_HF_TRANSFER=1 uses the Rust-backed hf_transfer library for
maximum download speed.
The file will land at:
~/data/ollama_configs/qwen-3-5-30b-moe-claude-code/qwen3.5-35b-a3b/Qwen3.5-35B-A3B-UD-Q4_K_XL.gguf
Alternatively, just run ./qwen35-serve.sh — it will download the model automatically
if not present (the download_model function is called by default; the current script
has it commented out, so uncomment the download_model call in main() if needed).
Step 4 — Start the server
chmod +x qwen35-serve.sh
./qwen35-serve.sh
The script will:
  1. Check that uv and llama-server are present
  2. Verify port 8080 is free
  3. Start llama-server on port 8080 (logs to /tmp/qwen35-serve.log)
  4. Wait up to 5 minutes for the server health check to pass
  5. Run a smoke test against /v1/messages
  6. Print the Claude Code environment variables to use
  7. Continue tailing logs until you Ctrl+C
Server flags explained
Flag Value Why
--model path to .gguf The model to load
--alias qwen3.5-35b The model name Claude Code sends in requests
--host 0.0.0.0 Accept connections from other machines on the network
--port 8080 Avoids conflict with Ollama’s default 11434
--ctx-size 131072 128k token context window
--batch-size / --ubatch-size 2048 Prompt processing batch size
--threads 16 CPU threads for non-GPU work
-ngl 999 Load all layers onto GPU (effectively “full GPU offload”)
--no-mmap DGX Spark perf fix — mmap causes severe slowdowns on GB10; always disable
--flash-attn on Flash attention; Blackwell (SM121) supports all quant types natively
--cache-type-k q8_0 Critical — Qwen3.5 degrades with the default f16 KV cache; use q8_0
--cache-type-v q8_0 Same as above for value cache
--temp 0.6 Sampling temperature
--top-p 0.95 Nucleus sampling
--top-k 20 Top-k sampling
--min-p 0.01 Min-p sampling
--repeat-penalty 1.05 Mild repetition penalty
--jinja Enable Jinja2 chat template rendering (required for Qwen’s chat format)
--reasoning off Disables chain-of-thought — thinking mode burns tokens on every turn, killing Claude Code performance in agentic use
Step 5 — Configure Claude Code
Set these environment variables before launching Claude Code. Add them to a wrapper
script or your shell profile.
unset ANTHROPIC_API_KEY
export ANTHROPIC_AUTH_TOKEN=llamacpp
export ANTHROPIC_BASE_URL=http://gx10-44bc.local:8080
export CLAUDE_CODE_ATTRIBUTION_HEADER=0
Variable Value Why
ANTHROPIC_API_KEY unset Must be unset so Claude Code uses ANTHROPIC_AUTH_TOKEN instead
ANTHROPIC_AUTH_TOKEN llamacpp Any non-empty string — llama-server accepts all tokens
ANTHROPIC_BASE_URL http://<your-host>:8080 Points Claude Code at the local llama-server; replace hostname/IP
CLAUDE_CODE_ATTRIBUTION_HEADER=0 0 Critical perf fix — Claude Code prepends an attribution header that busts the KV cache on every turn, causing ~90% slower inference. Setting this to 0 suppresses the header.
Then start Claude Code:
claude --model qwen3.5-35b
The model name qwen3.5-35b must match the --alias flag used when starting the server.
Example wrapper script (multi-mode claude.sh)
#!/bin/bash
MODE="${1:-claude}"
if [ "$MODE" = "claude" ]; then
    # Normal Anthropic cloud
    claude "${@:2}"
elif [ "$MODE" = "qwen" ]; then
    claude --model qwen3.5-35b "${@:2}"
fi
Usage: ./claude.sh qwen starts Claude Code against the local Qwen model.
Verification
Check server health
curl http://localhost:8080/health
# Expected: {"status":"ok"}
Manual Anthropic API smoke test
curl http://localhost:8080/v1/messages \
  -H "Content-Type: application/json" \
  -H "x-api-key: llamacpp" \
  -d '{
    "model": "qwen3.5-35b",
    "max_tokens": 64,
    "messages": [{"role": "user", "content": "Say READY"}]
View server logs
tail -f /tmp/qwen35-serve.log
Troubleshooting
Symptom Cause Fix
llama-server not found Not built or not copied to /usr/local/bin Re-run Step 2
Port 8080 already in use Another process (including a previous server) is bound lsof -i :8080 to find it, then kill it
Slow inference (~5–10 tok/s) --no-mmap missing, or KV cache using f16 Confirm both --no-mmap and --cache-type-k/v q8_0 are set
KV cache thrash / slow per-turn Attribution header not suppressed Confirm CLAUDE_CODE_ATTRIBUTION_HEADER=0 is exported
Out of VRAM Model too large for single GPU Use a smaller quant (Q4_K_M instead of Q4_K_XL) or split across GPUs with --tensor-split
Download hangs or is slow hf_transfer not active Ensure HF_HUB_ENABLE_HF_TRANSFER=1 is set before the download
cmake can’t find nvcc CUDA not on PATH export CUDACXX=/usr/local/cuda/bin/nvcc and re-run cmake
Architecture summary
Claude Code CLI
    │  (Anthropic Messages API)
llama-server :8080
    │  (native /v1/messages endpoint)
    │  (fully loaded on GPU)
NVIDIA GB10 (Blackwell SM121)
llama.cpp’s llama-server natively implements the Anthropic Messages API — no adapter,
proxy, or shim is required. Claude Code speaks directly to it.
Nice guide, i also wanted to point out that Vulkan may be faster than CUDA for Qwen3 models.
GGML_VK_PREFER_HOST_MEMORY=1 /home/pont/git/llama.cpp/build/bin/llama-bench -hf unsloth/Qwen3.5-35B-A3B-GGUF:UD-Q4_K_XL -ngl 99 -fa 1 -ctv q8_0 -ctk q8_0 --mmap 0 -d 0,10000,65000 -dev CUDA0,Vulkan0
ggml_cuda_init: found 1 CUDA devices (Total VRAM: 124546 MiB):
Device 0: NVIDIA GB10, compute capability 12.1, VMM: yes, VRAM: 124546 MiB
ggml_vulkan: Found 1 Vulkan devices:
ggml_vulkan: 0 = NVIDIA GB10 (NVIDIA) | uma: 1 | fp16: 1 | bf16: 1 | warp size: 32 | shared memory: 49152 | int dot: 1 | matrix cores: NV_coopmat2
model size params backend ngl type_k type_v fa dev mmap test t/s
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 CUDA0 0 pp512 2142.15 ± 16.59
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 CUDA0 0 tg128 59.93 ± 0.19
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 CUDA0 0 pp512 @ d10000 1967.87 ± 8.25
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 CUDA0 0 tg128 @ d10000 57.19 ± 0.14
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 CUDA0 0 pp512 @ d65000 1497.27 ± 10.12
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 CUDA0 0 tg128 @ d65000 45.14 ± 0.06
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 Vulkan0 0 pp512 2060.24 ± 26.34
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 Vulkan0 0 tg128 61.55 ± 0.04
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 Vulkan0 0 pp512 @ d10000 1826.91 ± 16.28
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 Vulkan0 0 tg128 @ d10000 58.61 ± 0.06
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 Vulkan0 0 pp512 @ d65000 1217.75 ± 11.55
qwen35moe 35B.A3B Q4_K - Medium 20.70 GiB 34.66 B CUDA,Vulkan 99 q8_0 q8_0 1 Vulkan0 0 tg128 @ d65000 48.60 ± 0.02
Nice to have a full write-up with benchmarks :)
Just a heads up, it seems a lot of it was AI generated and some of it is outdated and shouldn’t be used in this way any more; particularly step 3. Still a good starting point as a playbook :)
This model is remarkable, it blows my mind how good it is. I’ve been using the same model as the backend against which I build agentic applications - previously I was trending towards $200/day for gemini tokens, testing the reliability of agents. I also run 2 openclaws - concurrency is vital for my setup, hence hosting in vllm.
Some useful nuggets I’ll mine from your post - thank you for sharing!
- Paul
