“Unitree Go2” is provided as an asset in Isaac Sim, but is there any plan to provide its derivative model, Unitree Go2-W?
If there are no plans to provide it, which approach would you recommend ? :
Importing from URDF is likely the most straightforward approach. You can use the URDF importer extension in Isaac Sim to convert a URDF file of the Go2-W into USD format
