Implementing L2 cache persistence into python
Hello, I’m recently studying Device Memory L2 Access Management from nvidia document.
I’m into implementing examples of nvidia document on python now.
However, declaring cuda graph node “cudaGraphNode_t node” is becoming an obstacle now.
To be more precise, I want to convert code below into python.
cudaGraph_t graph;
cudaGraphExec_t graphExec;
cudaStream_t stream;
size_t numNodes = 0;
cudaGraphNode_t* nodes = nullptr;
cudaGraphNode_t node;
cudaGraphGetNodes(graph, nullptr, &numNodes);
nodes = new cudaGraphNode_t[numNodes];
CUDA_CHECK(cudaGraphGetNodes(graph, nodes, &numNodes));
node = nodes[0];
cudaKernelNodeAttrValue node_attribute;
node_attribute.accessPolicyWindow.base_ptr = reinterpret_cast<void*>(d_data);
node_attribute.accessPolicyWindow.num_bytes = total_size;
node_attribute.accessPolicyWindow.hitRatio = hitRatio;
node_attribute.accessPolicyWindow.hitProp = cudaAccessPropertyPersisting;
node_attribute.accessPolicyWindow.missProp = cudaAccessPropertyStreaming;
CUDA_CHECK(cudaGraphKernelNodeSetAttribute(node, cudaKernelNodeAttributeAccessPolicyWindow, &node_attribute));
cudaGraphInstantiate(&graphExec, graph, nullptr, nullptr, 0);
can anyone help me with converting code above into python?
Thank you in advance.
I believe that cuda-python should have everything you need, since it has basically a 1:1 correspondence with CUDA C++ that you have written, and you haven’t expressed a toolchain preference (e.g. numba, cupy, etc.) Sorry I don’t have a code example for you. The following may be of interest: 1 (note the runtime API directory on the right) 2 (basic tutorial) 3 (github)
