Hi, I wanted to know, can you import a Jpeg, BMP or PNG file onto the Omniverse stage and apply on it on a shape or object? For example, in Unreal you can apply decals and add them on a object. For example a graffiti artwork onto a wall and it blends onto the object. Is that possible in Omniverse?
Update
Just figured it out with Unreal. When you export your scene, on the dialog export box youâll see an option which will say âExport Decal Actors as Planesâ. Select that and it will export them as planes on the stage in Machinima. Although, I still donât know how to do it manually but only on Unreal.
Hi!
See this, these are are settings to use on a plane to have png image with opacity.
Hope yo can re-make this?
Pekka
If you have problems with opacity quality on this âone pngâ solution, you can make a different black&white jpg image for the opacity, and use it:
thanks Pekka! Iâll try that and see if I can get it to work and let you know :)
