Import block linear NvSciBufObj with pitch to CUDA
Dear @VickNV,
Thank you very much, it was a super insightful explanation. It is super important for us to understand what is going on under the hood as there is a strange behavior under DriveOS 6.0.8.1 which we don’t understand yet.
We have a visual validation pipeline that loads a video, processes it and produces a quality score in the end. During the processing we use NvMedia and CUDA operations as well. This score is deterministic under DriveOS 5, every time we run the pipeline we get the very same score, all the images are pixel-perfect the same in the consecutive runs.
Under DriveOS 6 we get a deterministic score when we don’t use CUDA operations on the images. But whenever CUDA is involved the end score fluctuates slightly. The images looks good, there is nothing visibly broken, but the images from the consecutive runs are not pixel-perfectly the same.
Is it possible that the padded image are between width and pitch somehow affects CUDA operations, NvMedia operations or the encoder? We saw non-deterministic pipeline score under DriveOS 5 as well previously, it was caused by the memory junk if the height of the video was not dividable by 16.
We don’t have an explanation yet so we are brainstorming what can cause the slight end score fluctuation under DriveOS 6 when CUDA operations are involved, an unexpected side-effect of this changed pitch seems to be a good candidate. Do you have any idea what we should double-check? We already double and triple-checked the synchronization, it must not be the problem.
Thank you,
Adam
