Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.6
Target Operating System
Linux
Hardware Platform
SDK Manager Version
other
Host Machine Version
I have installed torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl. There are no errors during installation. But when I run import torch I am getting “Import Error: libopenblas.so.0: Cannot open shared object file: No such file or directory” this error.
nvidia@tegra-ubuntu:~$ sudo apt-get install libopenblas-dev
[sudo] password for nvidia:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
gcc-10-base libatomic1 libcc1-0 libgcc-s1 libgfortran5 libgomp1 libitm1 liblsan0 libopenblas-pthread-dev
libopenblas0 libopenblas0-pthread libstdc++6 libtsan0 libubsan1
The following NEW packages will be installed:
libgfortran5 libopenblas-dev libopenblas-pthread-dev libopenblas0 libopenblas0-pthread
The following packages will be upgraded:
gcc-10-base libatomic1 libcc1-0 libgcc-s1 libgomp1 libitm1 liblsan0 libstdc++6 libtsan0 libubsan1
10 upgraded, 5 newly installed, 0 to remove and 168 not upgraded.
Need to get 12.5 MB of archives.
After this operation, 68.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libatomic1 arm64 10.5.0-1ubuntu1~20.04 [9808 B]
Get:2 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libubsan1 arm64 10.5.0-1ubuntu1~20.04 [765 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libtsan0 arm64 10.5.0-1ubuntu1~20.04 [1972 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 gcc-10-base arm64 10.5.0-1ubuntu1~20.04 [20.8 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libstdc++6 arm64 10.5.0-1ubuntu1~20.04 [461 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 liblsan0 arm64 10.5.0-1ubuntu1~20.04 [800 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libitm1 arm64 10.5.0-1ubuntu1~20.04 [24.1 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libgomp1 arm64 10.5.0-1ubuntu1~20.04 [93.5 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libcc1-0 arm64 10.5.0-1ubuntu1~20.04 [46.2 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libgcc-s1 arm64 10.5.0-1ubuntu1~20.04 [34.6 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 libgfortran5 arm64 10.5.0-1ubuntu1~20.04 [346 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 libopenblas0-pthread arm64 0.3.8+ds-1ubuntu0.20.04.1 [5153 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 libopenblas0 arm64 0.3.8+ds-1ubuntu0.20.04.1 [5892 B]
Get:14 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 libopenblas-pthread-dev arm64 0.3.8+ds-1ubuntu0.20.04.1 [2787 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 libopenblas-dev arm64 0.3.8+ds-1ubuntu0.20.04.1 [16.4 kB]
Fetched 12.5 MB in 10s (1304 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 59494 files and directories currently installed.)
Preparing to unpack .../libatomic1_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libatomic1:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../libubsan1_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libubsan1:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../libtsan0_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libtsan0:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../gcc-10-base_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking gcc-10-base:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Setting up gcc-10-base:arm64 (10.5.0-1ubuntu1~20.04) ...
(Reading database ... 59493 files and directories currently installed.)
Preparing to unpack .../libstdc++6_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libstdc++6:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Setting up libstdc++6:arm64 (10.5.0-1ubuntu1~20.04) ...
Preparing to unpack .../liblsan0_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking liblsan0:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../libitm1_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libitm1:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../libgomp1_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libgomp1:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../libcc1-0_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libcc1-0:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Preparing to unpack .../libgcc-s1_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libgcc-s1:arm64 (10.5.0-1ubuntu1~20.04) over (10.3.0-1ubuntu1~20.04) ...
Setting up libgcc-s1:arm64 (10.5.0-1ubuntu1~20.04) ...
Selecting previously unselected package libgfortran5:arm64.
Preparing to unpack .../libgfortran5_10.5.0-1ubuntu1~20.04_arm64.deb ...
Unpacking libgfortran5:arm64 (10.5.0-1ubuntu1~20.04) ...
Selecting previously unselected package libopenblas0-pthread:arm64.
Preparing to unpack .../libopenblas0-pthread_0.3.8+ds-1ubuntu0.20.04.1_arm64.deb ...
Unpacking libopenblas0-pthread:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
Selecting previously unselected package libopenblas0:arm64.
Preparing to unpack .../libopenblas0_0.3.8+ds-1ubuntu0.20.04.1_arm64.deb ...
Unpacking libopenblas0:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
Selecting previously unselected package libopenblas-pthread-dev:arm64.
Preparing to unpack .../libopenblas-pthread-dev_0.3.8+ds-1ubuntu0.20.04.1_arm64.deb ...
Unpacking libopenblas-pthread-dev:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
Selecting previously unselected package libopenblas-dev:arm64.
Preparing to unpack .../libopenblas-dev_0.3.8+ds-1ubuntu0.20.04.1_arm64.deb ...
Unpacking libopenblas-dev:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
Setting up libgomp1:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libatomic1:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libgfortran5:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libubsan1:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libcc1-0:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up liblsan0:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libitm1:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libtsan0:arm64 (10.5.0-1ubuntu1~20.04) ...
Setting up libopenblas0-pthread:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
update-alternatives: using /usr/lib/aarch64-linux-gnu/openblas-pthread/libblas.so.3 to provide /usr/lib/aarch64-linux-gnu/libblas.so.3 (libblas.so.3-aarch64-linux-gnu) in auto mode
update-alternatives: using /usr/lib/aarch64-linux-gnu/openblas-pthread/liblapack.so.3 to provide /usr/lib/aarch64-linux-gnu/liblapack.so.3 (liblapack.so.3-aarch64-linux-gnu) in auto mode
update-alternatives: using /usr/lib/aarch64-linux-gnu/openblas-pthread/libopenblas.so.0 to provide /usr/lib/aarch64-linux-gnu/libopenblas.so.0 (libopenblas.so.0-aarch64-linux-gnu) in auto mode
Setting up libopenblas0:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
Setting up libopenblas-pthread-dev:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
update-alternatives: using /usr/lib/aarch64-linux-gnu/openblas-pthread/libblas.so to provide /usr/lib/aarch64-linux-gnu/libblas.so (libblas.so-aarch64-linux-gnu) in auto mode
update-alternatives: using /usr/lib/aarch64-linux-gnu/openblas-pthread/liblapack.so to provide /usr/lib/aarch64-linux-gnu/liblapack.so (liblapack.so-aarch64-linux-gnu) in auto mode
update-alternatives: using /usr/lib/aarch64-linux-gnu/openblas-pthread/libopenblas.so to provide /usr/lib/aarch64-linux-gnu/libopenblas.so (libopenblas.so-aarch64-linux-gnu) in auto mode
Setting up libopenblas-dev:arm64 (0.3.8+ds-1ubuntu0.20.04.1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
/sbin/ldconfig.real: /lib/aarch64-linux-gnu/libnl-genl-3.so.200 is not a symbolic link
nvidia@tegra-ubuntu:~$ sudo updatedb
sudo: updatedb: command not found
nvidia@tegra-ubuntu:~$ sudo apt-get install locate
locate
0 upgraded, 1 newly installed, 0 to remove and 168 not upgraded.
Need to get 82.9 kB of archives.
After this operation, 245 kB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports focal/universe arm64 locate arm64 4.7.0-1ubuntu1 [82.9 kB]
Fetched 82.9 kB in 1s (60.5 kB/s)
Selecting previously unselected package locate.
(Reading database ... 59540 files and directories currently installed.)
Preparing to unpack .../locate_4.7.0-1ubuntu1_arm64.deb ...
Unpacking locate (4.7.0-1ubuntu1) ...
Setting up locate (4.7.0-1ubuntu1) ...
nvidia@tegra-ubuntu:~$ ls /usr/lib/aarch64-linux-gnu/libopenblas.so.0
