Hi All,
I wanted to implement a standalone python script which launches a SimulationApp and listens to a rostopic while the world is open.
Obviously, the python.sh can’t find any imports associated with rospy. Now my (probably dumb) question: How can I tell my ISAAC python environment where it can find rospy?
Any help appreciated. Thanks.
Hi @cgoelle2
You can take a look at the following standalone examples that include the import and use of rospy
standalone_examples/api/omni.isaac.ros_bridge/carter_stereo.py
standalone_examples/api/omni.isaac.ros_bridge/clock.py
standalone_examples/api/omni.isaac.ros_bridge/contact.py
standalone_examples/api/omni.isaac.ros_bridge/subscriber.py
Basically, the workflow is:
instantiate the
SimulationApp
classAny Omniverse level imports must occur after the class is instantiated. Because APIs are provided by the extension/runtime plugin system, it must be loaded before they will be available to import.
enable the
extension -
check for ROS master
import
rospy
and other packages/modules
For example:
import carb
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"renderer": "RayTracedLighting", "headless": True})
from omni.isaac.core.utils.extensions import enable_extension
# enable ROS bridge extension
enable_extension("omni.isaac.ros_bridge")
simulation_app.update()
# check if rosmaster node is running
# this is to prevent this sample from waiting indefinetly if roscore is not running
# can be removed in regular usage
import rosgraph
if not rosgraph.is_master_online():
carb.log_error("Please run roscore before executing this script")
simulation_app.close()
exit()
# Note that this is not the system level rospy, but one compiled for omniverse
import rospy
Thank you very much. You can’t imagine how much you helped us!
