Import Object for Data Generator
Im trying to import 3d models from Rhino/Grasshopper into Kaolin in order to use the data generator function. Im using the publish as prop function with in the Omniverse GH plugin to export as a .usd file. However, when imported into Kaolin data generator the 3d model fails to load.
Is there currently a functionality within Kaolin to introduce data from connectors such as Rhino or maya etc?
Hello joshuaylye,
Thank you for posting, I will bring your inquiry to the Kaolin developers for review.
Thank you for your patience.
Hello joshuaylye,
I believe we have found the issue. Can you please try this:
  1. Open the converted Rhino/Grasshopper USD (File->Open)
  2. Open the Stage panel (Window->Stage)
  3. Right-click on the root prim (top-most element) in the tree
  4. Click on Set as Default Prim
  5. Save (File->Save)
Now try adding the asset through the Data Generator once more. Please let us know if your issue persists. Thank you for bringing this to our attention!
