Hi, I am using the prebuilt container nvcr.io/nvidia/tensorrt:19.05-py2 . Installed tendorflow-gpu (for running TensroRT examples ), but the above library issue happens . Is there a easy way to get around that ?
python -c “import tensorflow as tf; print tf.version”
File “”, line 1, in
File “/usr/local/lib/python2.7/dist-packages/tensorflow/init.py”, line 24, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/init.py”, line 49, in
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(‘_pywrap_tensorflow_internal’, fp, pathname, description)
ImportError: libcublas.so.10.0: cannot open shared object file: No such file or directory
