ImportError when running Reinforcement Learning using Stable Baselines
Hi, I try to running Reinforcement Learning using Stable Baselines.
When I execute
~/.local/share/ov/pkg/isaac_sim-2021.2.1/python.sh train.py
It shows the error:
File "/home/chinwei.chang/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/site-packages/stable_baselines3/common/utils.py", line 190, in configure_logger
    raise ImportError("Trying to log data to tensorboard but tensorboard is not installed.")
ImportError: Trying to log data to tensorboard but tensorboard is not installed.
I tried to fix this error and I installed:
~/.local/share/ov/pkg/isaac_sim-2021.2.1/python.sh -m pip install tb-nightly
The error disappeared, and I can run the example.
I’m not sure that do I miss any steps before running this example?
There shouldn’t be anything extra needed, as part of the omniverse launcher install process
python.sh -m pip install -r requirements.txt should automatically get executed.
But if there are issues, you can also run this manually to install tensorboard
