Hi !
I flashed the Jetson OS on SD Card with Balena Etcher.
I’m trying to boot but this appear :
If i click on OK, i have a boot menu that ask me login and password …
But … i didn’t choose any login or password before, i just flashed the sd card.
Can you help me ?
Thanks for advance
Vincent
Welcome to the NVIDIA Developer forums. Your issue should be posted in the Jetson Nano category. I will move it over for you.
Best,
Tom K
Thanks, still waiting for the answer
Could you help dump the log?
Remove this sd card out from jetson nano and plug into your host machine to check /var/log/oem-config.log.
Please attach that log when error happened. Thanks.
I have the same problem, I can’t boot my jetson nano 2Gb. Someone knows a solution for that?
Thank you in advance
kayccc
March 22, 2022, 11:09pm
6
Could you help dump the log? Which imge you download?
Hi !
I can’t find what you say ! Here is what i see when I plug my SD-CARD in my computer.
And if I click on one of them, it says “please format your drive disk” …
So, what can I do ?
Sorry that do you have any ubuntu/linux machine to dump the log? Since the disk is ext4, Windows may not able to read it.
oem-config.log (3.5 KB)
Here it is !
Thanks for your kind share. Let us check.
Okay thanks, now we can continue, but after setting up the SWAP allocation, we click on “next” and this screen appears :
If it can help you, the green led of the Jetson is not blinking …
If we restart, we have to do the configuration again. It looks like a dead loop.
Do you mean the configuration of user account will be a loop?
When I follow the install setup like on this https://automaticaddison.com/how-to-set-up-the-nvidia-jetson-nano-developer-kit/ , i have the ubuntu screen after clicking on NEXT after choosing “SWAP SIZE”.
If you don’t configure swap size, will it pass?
It works ! The swap is the problem, if we click on “NO”, it works.
Hi @ViinceL ,
Could you check if your syslog (/var/log/syslog) on jetson keeps any record when you firstly boot up in jp4.6?
syslog (164.7 KB)
Here it is !
Thanks for kind share. But I mean the log when your first try over jp4.6, not the log boot up today. Do you keep that log?
system
Closed
April 8, 2022, 4:10pm
22
