Hello again,
I was able to reproduce the error in r32.2 using a modified version of 06_jpeg_decode. The application immediately terminates instead of properly shutting down. Let me know if you have any questions. The reason I was unable to reproduce the issue before was an unrelated problem.
Here is the code:
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "NvUtils.h"
#include <errno.h>
#include <fstream>
#include <iostream>
#include <malloc.h>
#include <csignal>
#include <string.h>
#include <thread>
#include <unistd.h>
#include "jpeg_decode.h"
#define TEST_ERROR(cond, str, label) if(cond) { \
cerr << str << endl; \
error = 1; \
goto label; }
using namespace std;
static bool running = true;
static void
abort(context_t * ctx)
ctx->got_error = true;
ctx->conv->abort();
static bool
conv_capture_dqbuf_thread_callback(struct v4l2_buffer *v4l2_buf,
NvBuffer * buffer, NvBuffer * shared_buffer,
void *arg)
context_t *ctx = (context_t *) arg;
if (!v4l2_buf)
cerr << "Failed to dequeue buffer from conv capture plane" << endl;
abort(ctx);
return false;
write_video_frame(ctx->out_file[ctx->current_file++], *buffer);
return false;
static uint64_t
get_file_size(ifstream * stream)
uint64_t size = 0;
streampos current_pos = stream->tellg();
stream->seekg(0, stream->end);
size = stream->tellg();
stream->seekg(current_pos, stream->beg);
return size;
static void
set_defaults(context_t * ctx)
memset(ctx, 0, sizeof(context_t));
ctx->use_fd = true;
ctx->stress_test = 1;
ctx->current_file = 0;
static int
jpeg_decode_proc(context_t& ctx, int argc, char *argv[])
int ret = 0;
int error = 0;
int fd = 0;
uint32_t width, height, pixfmt;
int i = 0;
set_defaults(&ctx);
ret = parse_csv_args(&ctx, argc, argv);
TEST_ERROR(ret < 0, "Error parsing commandline arguments", cleanup);
for(i = 0; i < ctx.num_files; i++)
ctx.in_file[i] = new ifstream(ctx.in_file_path[i]);
TEST_ERROR(!ctx.in_file[i]->is_open(), "Could not open input file", cleanup);
ctx.out_file[i] = new ofstream(ctx.out_file_path[i]);
TEST_ERROR(!ctx.out_file[i]->is_open(), "Could not open output file", cleanup);
ctx.jpegdec = NvJPEGDecoder::createJPEGDecoder("jpegdec");
TEST_ERROR(!ctx.jpegdec, "Could not create Jpeg Decoder", cleanup);
ctx.in_file_size = get_file_size(ctx.in_file[i]);
ctx.in_buffer = new unsigned char[ctx.in_file_size];
ctx.in_file[i]->read((char *) ctx.in_buffer, ctx.in_file_size);
if (!ctx.use_fd)
NvBuffer *buffer;
ret = ctx.jpegdec->decodeToBuffer(&buffer, ctx.in_buffer,
ctx.in_file_size, &pixfmt, &width, &height);
TEST_ERROR(ret < 0, "Could not decode image", cleanup);
cout << "Image Resolution - " << width << " x " << height << endl;
write_video_frame(ctx.out_file[i], *buffer);
delete buffer;
goto cleanup;
ctx.conv = NvVideoConverter::createVideoConverter("conv");
TEST_ERROR(!ctx.conv, "Could not create Video Converter", cleanup);
ret = ctx.jpegdec->decodeToFd(fd, ctx.in_buffer, ctx.in_file_size, pixfmt,
width, height);
ret = ctx.conv->setCropRect(0, 0, width, height);
TEST_ERROR(ret < 0, "Could not set crop rect for conv0", cleanup);
// Set conv output plane format
ret =
ctx.conv->setOutputPlaneFormat(pixfmt, width,
height, V4L2_NV_BUFFER_LAYOUT_PITCH);
TEST_ERROR(ret < 0, "Could not set output plane format for conv", cleanup);
// Set conv capture plane format
ret =
ctx.conv->setCapturePlaneFormat(pixfmt, width,
height,
TEST_ERROR(ret < 0, "Could not set capture plane format for conv", cleanup);
// REQBUF, EXPORT and MAP conv output plane buffers
ret = ctx.conv->output_plane.setupPlane(V4L2_MEMORY_DMABUF, 1, false, false);
TEST_ERROR(ret < 0, "Error while setting up output plane for conv",
cleanup);
// REQBUF and EXPORT conv capture plane buffers
// No need to MAP since buffer will be shared to next component
// and not read in application
ret =
ctx.conv->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 1,
true, false);
TEST_ERROR(ret < 0, "Error while setting up capture plane for conv",
cleanup);
// conv output plane STREAMON
ret = ctx.conv->output_plane.setStreamStatus(true);
TEST_ERROR(ret < 0, "Error in output plane streamon for conv", cleanup);
// conv capture plane STREAMON
ret = ctx.conv->capture_plane.setStreamStatus(true);
TEST_ERROR(ret < 0, "Error in capture plane streamon for conv", cleanup);
ctx.conv->
capture_plane.setDQThreadCallback(conv_capture_dqbuf_thread_callback);
// Start threads to dequeue buffers on conv capture plane
ctx.conv->capture_plane.startDQThread(&ctx);
// Enqueue all empty conv capture plane buffers
for (uint32_t i = 0; i < ctx.conv->capture_plane.getNumBuffers(); i++)
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, MAX_PLANES * sizeof(struct v4l2_plane));
v4l2_buf.index = i;
v4l2_buf.m.planes = planes;
ret = ctx.conv->capture_plane.qBuffer(v4l2_buf, NULL);
if (ret < 0)
cerr << "Error while queueing buffer at conv capture plane" << endl;
abort(&ctx);
goto cleanup;
v4l2_buf.index = 0;
planes[0].m.fd = fd;
planes[0].bytesused = 1234;
ret = ctx.conv->output_plane.qBuffer(v4l2_buf, NULL);
if (ret < 0)
cerr << "Error while queueing buffer at conv output plane" << endl;
abort(&ctx);
goto cleanup;
// Wait till all capture plane buffers on conv are dequeued
ctx.conv->capture_plane.waitForDQThread(2000);
cleanup:
if (ctx.conv && ctx.conv->isInError())
cerr << "VideoConverter is in error" << endl;
error = 1;
if (ctx.got_error)
error = 1;
delete ctx.conv;
delete[] ctx.in_buffer;
delete ctx.in_file[i];
delete ctx.out_file[i];
free(ctx.in_file_path[i]);
free(ctx.out_file_path[i]);
// Destructors do all the cleanup, unmapping and deallocating buffers
// and calling v4l2_close on fd
delete ctx.jpegdec;
return -error;
void signalHandler(sigset_t* set)
int sig;
sigwait(set, &sig);
std::cout << "Got signal " << sig << "... terminating application..." << std::endl;
running = false;
int
main(int argc, char *argv[])
context_t ctx;
int ret = 0;
int iterator_num = 0; //save iterator number
std::thread signalThread;
sigset_t set;
sigemptyset(&set);
sigaddset(&set, SIGQUIT);
sigaddset(&set, SIGINT);
sigaddset(&set, SIGTERM);
pthread_sigmask(SIG_BLOCK, &set, nullptr);
signalThread = std::thread(&signalHandler, &set);
do
ret = jpeg_decode_proc(ctx, argc, argv);
iterator_num++;
} while(running && ret == 0);
if (ret)
cout << "App run failed" << endl;
else
cout << "App run was successful" << endl;
signalThread.join();
return ret;
