we are trying to capture images with three imx185 cameras connected to a custom carrier board. Because we need a higher vertical resolution, we implemented the 1920x1200 mode in the kernel driver and changed the device tree like this:
* Copyright (c) 2016-2019, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
host1x {
vi@15700000 {
num-channels = <3>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_vi_in0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_out0>;
port@1 {
reg = <1>;
liimx185_vi_in1: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_out1>;
port@2 {
reg = <2>;
liimx185_vi_in2: endpoint {
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_out2>;
nvcsi@150c0000 {
num-channels = <3>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&liimx185_imx185_out0>;
port@1 {
reg = <1>;
liimx185_csi_out0: endpoint@1 {
remote-endpoint = <&liimx185_vi_in0>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_csi_in1: endpoint@0 {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&liimx185_imx185_out1>;
port@1 {
reg = <1>;
liimx185_csi_out1: endpoint@1 {
remote-endpoint = <&liimx185_vi_in1>;
channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_csi_in2: endpoint@0 {
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&liimx185_imx185_out2>;
port@1 {
reg = <1>;
liimx185_csi_out2: endpoint@1 {
remote-endpoint = <&liimx185_vi_in2>;
i2c@3180000 {
tca9546@70 {
i2c@0 {
imx185_a@1a {
compatible = "nvidia,imx185";
reg = <0x1a>;
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="imx185";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
use_decibel_gain = "true";
/* if true, delay gain setting by one frame to be in sync with exposure */
delayed_gain = "true";
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 {/*mode IMX185_MODE_1920X1200_CROP_30FPS*/
mclk_khz = "37125";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "1920";
active_h = "1200";
line_length = "3750";
inherent_gain = "1";
mclk_multiplier = "4";
pix_clk_hz = "148500000";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "480"; /* 48dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "30"; /* us */
max_exp_time = "660000"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_imx185_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_in0>;
i2c@1 {
imx185_c@1a {
reg = <0x1a>;
devnode = "video1";
* ==== Modes ====
* phy_mode = "";
* pix_clk_hz = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
mclk_khz = "37125";
num_lanes = "4";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1200";
gain_factor = "10";
default_gain = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_imx185_out1: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_in1>;
i2c@2 {
imx185_e@1a {
reg = <0x1a>;
devnode = "video2";
* ==== Modes ====
* phy_mode = "";
* pix_clk_hz = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
mclk_khz = "37125";
num_lanes = "4";
tegra_sinterface = "serial_e";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1200";
gain_factor = "10";
default_gain = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_imx185_out2: endpoint {
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_in2>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module1 {
badge = "imx185_center_liimx185";
position = "center";
orientation = "0";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx185 30-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx185_a@1a";
module0 {
badge = "imx185_front_liimx185";
position = "front";
orientation = "0";
drivernode0 {
devname = "imx185 31-001a";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@1/imx185_c@1a";
module2 {
badge = "imx185_bottom_liimx185";
position = "bottom";
orientation = "0";
drivernode0 {
devname = "imx185 32-001a";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@2/imx185_e@1a";
The cameras are detected properly and it is also possible to get a live image using argus_camera, at least sometimes. Unfortunately, most of the time, argus_camera just freezes and does not display an image. Looking at the dmesg outputs (see attachment) it seems that a timeout occurred.
I also tried to capture some raw data using v4l2-ctl:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1200, --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
Here I got the following output:
[ 137.458308] tegra-i2c 3180000.i2c: no acknowledge from address 0x1a
[ 137.465043] imx185 30-001a: imx185_write_reg: i2c write failed, 0x3003 = 1
[ 137.472094] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000004
[ 137.480942] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 137.488848] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
When using the 1920x1080 mode I could not see any problems. It also happens only when starting a camera. If the camera could be started, it runs without any issue at 30fps.
The question is, what could be the problem here? Did someone have similar issues? Could it be caused by a bad signal quality or is it maybe a software issue? I would appreciate any help for debugging this issue.
dmesg.log (66.8 KB)
