Please I need help concerning a CSI camera I bought on Amazon https://www.amazon.com/Yahboom-IMX219-77-Camera-NVIDIA-Interface/dp/B07TS7NCP2
. It has out of the box Nvidia-Jetson Nano support so I connected it as shown. It even shows up when running
ls /dev/video0
but when running the example shown on https://github.com/JetsonHacksNano/CSI-Camera it merely screenshots my screen as opposed to streaming a video
The command specified is
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e
Could you try modify the flip-method=2 to try.
It still didn’t work but after switching to an RPi v2 camera it worked
I tried embedding it into my python code using opencv and gstreamer however as shown below
def gstreamer_pipeline(
... capture_width=3280,
... capture_height=2464,
... display_width=820,
... display_height=616,
... framerate=21,
... flip_method=0,
... return (
... "nvarguscamerasrc ! "
... "video/x-raw(memory:NVMM), "
... "width=(int)%d, height=(int)%d, "
... "format=(string)NV12, framerate=(fraction)%d/1 ! "
... "nvvidconv flip-method=%d ! "
... "video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
... "videoconvert ! "
... "video/x-raw, format=(string)BGR ! appsink"
... capture_width,
... capture_height,
... framerate,
... flip_method,
... display_width,
... display_height,
import cv2
cam = cv2.VideoCapture(gstreamer_pipeline(), cv2.CAP_GSTREAMER)
ret, frame = cam.read()
print(ret)
False
