So I am encouting this issue after attempting to boot the Jetson™ Xavier™ NX Industrial Fanless PC - DSBOX-NX2 on a micro SD folliowing this tutorial : Run Jetson TX1 from SD Card – JetsonHacks .
It seems that the jetson is no longer able to loag on the boot driver. How can I factory reset or go back to default boot ?
Complete error
please help !
kayccc
February 22, 2022, 11:14pm
#4
Can you solved it? Which version Jetpack for this problem ?
yes i was able to return to default boot with this :
mount /dev/mmcblk0p1 /mnt
2. Add the boot args
For T210 (Jetson Nano/ TX1)
sed -i “s|^([ \t]APPEND ${cbootargs}) . |\1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1|” /mnt/boot/extlinux/extlinux.conf
For T186 serise (TX2/TX2i/TX2-4GB)
sed -i “s|^([ \t]APPEND ${cbootargs}) . |\1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2|” /mnt/boot/extlinux/extlinux.conf
For T194 series (NX/AGX Xavier)
sed -i “s|^([ \t]APPEND ${cbootargs}) . |\1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0|” /mnt/boot/extlinux/extlinux.conf
Unmount APP partition and reboot
umount /mnt
reboot
system
closed
March 11, 2022, 1:46pm
#7
