Hi Jerry ,
These things i have already tried but didn’t get expected results.
dmesg output
[ 1141.320021] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1141.541612] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1141.548071] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1141.769608] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1141.776056] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1141.997578] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1142.004027] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1142.013846] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 1142.021793] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 1142.245533] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1142.252003] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1142.473578] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1142.480034] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1142.489989] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 1142.497873] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 1142.717483] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1142.723869] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
Trace output
kworker/4:2-8584 [004] … 1918.309611: rtos_queue_peek_from_isr_failed: tstamp:60209049614 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1918.396147: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1918.396187: tegra_channel_capture_frame: sof:1918.65534144
vi-output, imx2-8919 [003] … 1918.403206: tegra_channel_capture_frame: sof:1918.293625856
kworker/4:2-8584 [004] … 1918.421568: rtos_queue_send_from_isr_failed: tstamp:60212697197 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421574: rtos_queue_send_from_isr_failed: tstamp:60212697327 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.421576: rtos_queue_send_from_isr_failed: tstamp:60212697435 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.421578: rtos_queue_send_from_isr_failed: tstamp:60212697542 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.421581: rtos_queue_send_from_isr_failed: tstamp:60212697647 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.421583: rtos_queue_send_from_isr_failed: tstamp:60212697753 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.421585: rtos_queue_send_from_isr_failed: tstamp:60212697857 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.421588: rtos_queue_send_failed: tstamp:60212698411 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421591: rtos_queue_send_from_isr_failed: tstamp:60212700479 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421593: rtos_queue_send_from_isr_failed: tstamp:60212700587 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.421595: rtos_queue_send_from_isr_failed: tstamp:60212700693 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.421597: rtos_queue_send_from_isr_failed: tstamp:60212700801 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.421599: rtos_queue_send_from_isr_failed: tstamp:60212700906 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.421601: rtos_queue_send_from_isr_failed: tstamp:60212701011 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.421604: rtos_queue_send_from_isr_failed: tstamp:60212701116 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.421606: rtos_queue_send_failed: tstamp:60212701549 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421608: rtos_queue_send_from_isr_failed: tstamp:60212705254 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421610: rtos_queue_send_from_isr_failed: tstamp:60212705360 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.421612: rtos_queue_send_from_isr_failed: tstamp:60212705465 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.421614: rtos_queue_send_from_isr_failed: tstamp:60212705573 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.421617: rtos_queue_send_from_isr_failed: tstamp:60212705676 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.421619: rtos_queue_send_from_isr_failed: tstamp:60212705780 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.421621: rtos_queue_send_from_isr_failed: tstamp:60212705884 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.421623: rtos_queue_send_failed: tstamp:60212706313 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421625: rtos_queue_send_from_isr_failed: tstamp:60212707831 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421628: rtos_queue_send_from_isr_failed: tstamp:60212707938 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.421630: rtos_queue_send_from_isr_failed: tstamp:60212708043 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.421632: rtos_queue_send_from_isr_failed: tstamp:60212708150 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.421634: rtos_queue_send_from_isr_failed: tstamp:60212708254 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.421636: rtos_queue_send_from_isr_failed: tstamp:60212708358 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.421638: rtos_queue_send_from_isr_failed: tstamp:60212708463 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.421641: rtos_queue_send_failed: tstamp:60212709605 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.421645: rtcpu_vinotify_event: tstamp:60212710466 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:60212709227 data:0x00000001
kworker/4:2-8584 [004] … 1918.421647: rtcpu_vinotify_event: tstamp:60212922112 tag:ATOMP_FS channel:0x00 frame:210 vi_tstamp:60212921738 data:0x00000000
kworker/4:2-8584 [004] … 1918.421649: rtcpu_vinotify_event: tstamp:60212927648 tag:CHANSEL_PXL_SOF channel:0x00 frame:210 vi_tstamp:60212927283 data:0x00000001
kworker/4:2-8584 [004] … 1918.421651: rtcpu_vinotify_event: tstamp:60212932624 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:210 vi_tstamp:60212932251 data:0x08000000
kworker/4:2-8584 [004] … 1918.421653: rtcpu_vinotify_event: tstamp:60213431576 tag:CHANSEL_PXL_EOF channel:0x00 frame:210 vi_tstamp:60213430914 data:0x043f0002
kworker/4:2-8584 [004] … 1918.421655: rtcpu_vinotify_event: tstamp:60213431696 tag:CHANSEL_FAULT channel:0x00 frame:210 vi_tstamp:60213430997 data:0x04400040
kworker/4:2-8584 [004] … 1918.421657: rtcpu_vinotify_event: tstamp:60213432200 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:210 vi_tstamp:60213431835 data:0x08000000
kworker/4:2-8584 [004] … 1918.477581: rtcpu_vinotify_event: tstamp:60213511068 tag:ATOMP_FE channel:0x00 frame:210 vi_tstamp:60213510621 data:0x00000000
kworker/4:2-8584 [004] … 1918.477589: rtos_queue_peek_from_isr_failed: tstamp:60214049606 queue:0x0b4b4940
vi-output, imx2-8919 [000] … 1918.622164: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [000] … 1918.622200: tegra_channel_capture_frame: sof:1918.293625856
vi-output, imx2-8919 [004] .n… 1918.631298: tegra_channel_capture_frame: sof:1918.521718080
kworker/4:2-8584 [004] … 1918.645594: rtos_queue_peek_from_isr_failed: tstamp:60219049597 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1918.645600: rtos_queue_send_from_isr_failed: tstamp:60219759259 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645602: rtos_queue_send_from_isr_failed: tstamp:60219759369 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.645604: rtos_queue_send_from_isr_failed: tstamp:60219759478 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.645606: rtos_queue_send_from_isr_failed: tstamp:60219759591 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.645609: rtos_queue_send_from_isr_failed: tstamp:60219759694 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.645611: rtos_queue_send_from_isr_failed: tstamp:60219759798 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.645613: rtos_queue_send_from_isr_failed: tstamp:60219759903 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.645660: rtos_queue_send_failed: tstamp:60219760452 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645663: rtos_queue_send_from_isr_failed: tstamp:60219762447 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645665: rtos_queue_send_from_isr_failed: tstamp:60219762554 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.645667: rtos_queue_send_from_isr_failed: tstamp:60219762660 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.645670: rtos_queue_send_from_isr_failed: tstamp:60219762769 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.645672: rtos_queue_send_from_isr_failed: tstamp:60219762874 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.645674: rtos_queue_send_from_isr_failed: tstamp:60219762979 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.645676: rtos_queue_send_from_isr_failed: tstamp:60219763085 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.645678: rtos_queue_send_failed: tstamp:60219763526 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645680: rtos_queue_send_from_isr_failed: tstamp:60219767607 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645683: rtos_queue_send_from_isr_failed: tstamp:60219767713 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.645685: rtos_queue_send_from_isr_failed: tstamp:60219767820 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.645687: rtos_queue_send_from_isr_failed: tstamp:60219767926 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.645689: rtos_queue_send_from_isr_failed: tstamp:60219768031 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.645691: rtos_queue_send_from_isr_failed: tstamp:60219768136 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.645693: rtos_queue_send_from_isr_failed: tstamp:60219768241 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.645696: rtos_queue_send_failed: tstamp:60219768679 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645698: rtos_queue_send_from_isr_failed: tstamp:60219770900 queue:0x0b4a7698
kworker/4:2-8584 [004] .n… 1918.645700: rtos_queue_send_from_isr_failed: tstamp:60219771007 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.645732: rtos_queue_send_from_isr_failed: tstamp:60219771112 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.645735: rtos_queue_send_from_isr_failed: tstamp:60219771219 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.645737: rtos_queue_send_from_isr_failed: tstamp:60219771323 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.645739: rtos_queue_send_from_isr_failed: tstamp:60219771429 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.645742: rtos_queue_send_from_isr_failed: tstamp:60219771536 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.645744: rtos_queue_send_failed: tstamp:60219772678 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.645748: rtcpu_vinotify_event: tstamp:60219773529 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:60219772281 data:0x00000001
kworker/4:2-8584 [004] … 1918.645750: rtcpu_vinotify_event: tstamp:60220049987 tag:ATOMP_FS channel:0x00 frame:222 vi_tstamp:60220049607 data:0x00000000
kworker/4:2-8584 [004] … 1918.645752: rtcpu_vinotify_event: tstamp:60220055517 tag:CHANSEL_PXL_SOF channel:0x00 frame:222 vi_tstamp:60220055153 data:0x00000001
kworker/4:2-8584 [004] … 1918.645754: rtcpu_vinotify_event: tstamp:60220062104 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:222 vi_tstamp:60220061731 data:0x08000000
kworker/4:2-8584 [004] … 1918.701548: rtcpu_vinotify_event: tstamp:60220559406 tag:CHANSEL_PXL_EOF channel:0x00 frame:222 vi_tstamp:60220558784 data:0x043f0002
kworker/4:2-8584 [004] … 1918.701553: rtcpu_vinotify_event: tstamp:60220559525 tag:CHANSEL_FAULT channel:0x00 frame:222 vi_tstamp:60220558866 data:0x04400040
kworker/4:2-8584 [004] … 1918.701555: rtcpu_vinotify_event: tstamp:60220560031 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:222 vi_tstamp:60220559665 data:0x08000000
kworker/4:2-8584 [004] … 1918.701557: rtcpu_vinotify_event: tstamp:60220638939 tag:ATOMP_FE channel:0x00 frame:222 vi_tstamp:60220638493 data:0x00000000
kworker/4:2-8584 [004] … 1918.813560: rtos_queue_peek_from_isr_failed: tstamp:60224049592 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1918.850386: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1918.850421: tegra_channel_capture_frame: sof:1918.521718080
vi-output, imx2-8919 [004] … 1918.859381: tegra_channel_capture_frame: sof:1918.749809728
kworker/4:2-8584 [004] … 1918.869583: rtos_queue_send_from_isr_failed: tstamp:60226886314 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869587: rtos_queue_send_from_isr_failed: tstamp:60226886424 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.869589: rtos_queue_send_from_isr_failed: tstamp:60226886533 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.869592: rtos_queue_send_from_isr_failed: tstamp:60226886641 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.869594: rtos_queue_send_from_isr_failed: tstamp:60226886743 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.869596: rtos_queue_send_from_isr_failed: tstamp:60226886857 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.869598: rtos_queue_send_from_isr_failed: tstamp:60226886962 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.869602: rtos_queue_send_failed: tstamp:60226887526 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869604: rtos_queue_send_from_isr_failed: tstamp:60226891485 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869606: rtos_queue_send_from_isr_failed: tstamp:60226891593 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.869608: rtos_queue_send_from_isr_failed: tstamp:60226891698 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.869610: rtos_queue_send_from_isr_failed: tstamp:60226891807 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.869613: rtos_queue_send_from_isr_failed: tstamp:60226891910 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.869615: rtos_queue_send_from_isr_failed: tstamp:60226892014 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.869617: rtos_queue_send_from_isr_failed: tstamp:60226892119 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.869622: rtos_queue_send_failed: tstamp:60226892546 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869625: rtos_queue_send_from_isr_failed: tstamp:60226900181 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869627: rtos_queue_send_from_isr_failed: tstamp:60226900286 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.869629: rtos_queue_send_from_isr_failed: tstamp:60226900391 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.869631: rtos_queue_send_from_isr_failed: tstamp:60226900501 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.869633: rtos_queue_send_from_isr_failed: tstamp:60226900605 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.869636: rtos_queue_send_from_isr_failed: tstamp:60226900710 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.869638: rtos_queue_send_from_isr_failed: tstamp:60226900815 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.869640: rtos_queue_send_failed: tstamp:60226901247 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869642: rtos_queue_send_from_isr_failed: tstamp:60226903146 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869644: rtos_queue_send_from_isr_failed: tstamp:60226903254 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1918.869646: rtos_queue_send_from_isr_failed: tstamp:60226903360 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1918.869648: rtos_queue_send_from_isr_failed: tstamp:60226903468 queue:0x0b4af718
kworker/4:2-8584 [004] … 1918.869651: rtos_queue_send_from_isr_failed: tstamp:60226903573 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1918.869653: rtos_queue_send_from_isr_failed: tstamp:60226903678 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1918.869655: rtos_queue_send_from_isr_failed: tstamp:60226903783 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1918.869657: rtos_queue_send_failed: tstamp:60226904711 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1918.869661: rtcpu_vinotify_event: tstamp:60227177858 tag:ATOMP_FS channel:0x00 frame:234 vi_tstamp:60227177479 data:0x00000000
kworker/4:2-8584 [004] … 1918.869663: rtcpu_vinotify_event: tstamp:60227183398 tag:CHANSEL_PXL_SOF channel:0x00 frame:234 vi_tstamp:60227183025 data:0x00000001
kworker/4:2-8584 [004] … 1918.869665: rtcpu_vinotify_event: tstamp:60227188187 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:234 vi_tstamp:60227187822 data:0x08000000
kworker/4:2-8584 [004] … 1918.925566: rtcpu_vinotify_event: tstamp:60227687279 tag:CHANSEL_PXL_EOF channel:0x00 frame:234 vi_tstamp:60227686655 data:0x043f0002
kworker/4:2-8584 [004] … 1918.925571: rtcpu_vinotify_event: tstamp:60227687397 tag:CHANSEL_FAULT channel:0x00 frame:234 vi_tstamp:60227686738 data:0x04400040
kworker/4:2-8584 [004] … 1918.925573: rtcpu_vinotify_event: tstamp:60227687907 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:234 vi_tstamp:60227687536 data:0x08000000
kworker/4:2-8584 [004] … 1918.925575: rtcpu_vinotify_event: tstamp:60227766811 tag:ATOMP_FE channel:0x00 frame:234 vi_tstamp:60227766362 data:0x00000000
kworker/4:2-8584 [004] … 1918.925579: rtos_queue_peek_from_isr_failed: tstamp:60229049581 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1919.093533: rtos_queue_send_from_isr_failed: tstamp:60234008101 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.093541: rtos_queue_send_from_isr_failed: tstamp:60234008211 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.093544: rtos_queue_send_from_isr_failed: tstamp:60234008329 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.093546: rtos_queue_send_from_isr_failed: tstamp:60234008438 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.093548: rtos_queue_send_from_isr_failed: tstamp:60234008547 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.093550: rtos_queue_send_from_isr_failed: tstamp:60234008652 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.093552: rtos_queue_send_from_isr_failed: tstamp:60234008757 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.093555: rtos_queue_send_failed: tstamp:60234009289 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.093557: rtos_queue_send_from_isr_failed: tstamp:60234011331 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.093559: rtos_queue_send_from_isr_failed: tstamp:60234011437 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.093562: rtos_queue_send_from_isr_failed: tstamp:60234011542 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.093564: rtos_queue_send_from_isr_failed: tstamp:60234011651 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.093566: rtos_queue_send_from_isr_failed: tstamp:60234011755 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.093568: rtos_queue_send_from_isr_failed: tstamp:60234011860 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.093570: rtos_queue_send_from_isr_failed: tstamp:60234011965 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.093572: rtos_queue_send_failed: tstamp:60234012386 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.093576: rtos_queue_peek_from_isr_failed: tstamp:60234049571 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1919.094381: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1919.094417: tegra_channel_capture_frame: sof:1918.749809728
vi-output, imx2-8919 [003] … 1919.106618: tegra_channel_capture_frame: sof:1918.996909344
kworker/4:2-8584 [004] … 1919.149554: rtos_queue_send_from_isr_failed: tstamp:60234523261 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.149560: rtos_queue_send_from_isr_failed: tstamp:60234523369 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.149562: rtos_queue_send_from_isr_failed: tstamp:60234523477 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.149564: rtos_queue_send_from_isr_failed: tstamp:60234523584 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.149566: rtos_queue_send_from_isr_failed: tstamp:60234523689 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.149568: rtos_queue_send_from_isr_failed: tstamp:60234523794 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.149570: rtos_queue_send_from_isr_failed: tstamp:60234523899 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.149573: rtos_queue_send_failed: tstamp:60234524336 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.149575: rtos_queue_send_from_isr_failed: tstamp:60234527236 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.149578: rtos_queue_send_from_isr_failed: tstamp:60234527342 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.149580: rtos_queue_send_from_isr_failed: tstamp:60234527457 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.149582: rtos_queue_send_from_isr_failed: tstamp:60234527565 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.149584: rtos_queue_send_from_isr_failed: tstamp:60234527688 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.149586: rtos_queue_send_from_isr_failed: tstamp:60234527793 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.149589: rtos_queue_send_from_isr_failed: tstamp:60234527898 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.149591: rtos_queue_send_failed: tstamp:60234528820 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.149594: rtcpu_vinotify_event: tstamp:60234899716 tag:ATOMP_FS channel:0x00 frame:247 vi_tstamp:60234899340 data:0x00000000
kworker/4:2-8584 [004] … 1919.149596: rtcpu_vinotify_event: tstamp:60234905259 tag:CHANSEL_PXL_SOF channel:0x00 frame:247 vi_tstamp:60234904885 data:0x00000001
kworker/4:2-8584 [004] … 1919.149598: rtcpu_vinotify_event: tstamp:60234914279 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:247 vi_tstamp:60234913915 data:0x08000000
kworker/4:2-8584 [004] … 1919.149600: rtcpu_vinotify_event: tstamp:60235409140 tag:CHANSEL_PXL_EOF channel:0x00 frame:247 vi_tstamp:60235408515 data:0x043f0002
kworker/4:2-8584 [004] … 1919.149602: rtcpu_vinotify_event: tstamp:60235409258 tag:CHANSEL_FAULT channel:0x00 frame:247 vi_tstamp:60235408599 data:0x04400040
kworker/4:2-8584 [004] … 1919.149604: rtcpu_vinotify_event: tstamp:60235409762 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:247 vi_tstamp:60235409397 data:0x08000000
kworker/4:2-8584 [004] … 1919.149606: rtcpu_vinotify_event: tstamp:60235488671 tag:ATOMP_FE channel:0x00 frame:247 vi_tstamp:60235488222 data:0x00000000
kworker/4:2-8584 [004] … 1919.261554: rtos_queue_peek_from_isr_failed: tstamp:60239049576 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1919.327992: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1919.328026: tegra_channel_capture_frame: sof:1918.996909344
vi-output, imx2-8919 [000] … 1919.334586: tegra_channel_capture_frame: sof:1919.225000960
kworker/4:2-8584 [004] … 1919.373562: rtos_queue_send_from_isr_failed: tstamp:60241816380 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373568: rtos_queue_send_from_isr_failed: tstamp:60241816489 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.373570: rtos_queue_send_from_isr_failed: tstamp:60241816597 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.373572: rtos_queue_send_from_isr_failed: tstamp:60241816704 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.373574: rtos_queue_send_from_isr_failed: tstamp:60241816809 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.373577: rtos_queue_send_from_isr_failed: tstamp:60241816913 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.373579: rtos_queue_send_from_isr_failed: tstamp:60241817017 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.373581: rtos_queue_send_failed: tstamp:60241817559 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373584: rtos_queue_send_from_isr_failed: tstamp:60241819990 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373586: rtos_queue_send_from_isr_failed: tstamp:60241820096 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.373588: rtos_queue_send_from_isr_failed: tstamp:60241820203 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.373590: rtos_queue_send_from_isr_failed: tstamp:60241820310 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.373592: rtos_queue_send_from_isr_failed: tstamp:60241820414 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.373594: rtos_queue_send_from_isr_failed: tstamp:60241820520 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.373597: rtos_queue_send_from_isr_failed: tstamp:60241820624 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.373599: rtos_queue_send_failed: tstamp:60241821055 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373601: rtos_queue_send_from_isr_failed: tstamp:60241825243 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373603: rtos_queue_send_from_isr_failed: tstamp:60241825353 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.373605: rtos_queue_send_from_isr_failed: tstamp:60241825475 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.373607: rtos_queue_send_from_isr_failed: tstamp:60241825597 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.373610: rtos_queue_send_from_isr_failed: tstamp:60241825703 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.373612: rtos_queue_send_from_isr_failed: tstamp:60241825807 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.373614: rtos_queue_send_from_isr_failed: tstamp:60241825912 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.373616: rtos_queue_send_failed: tstamp:60241826336 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373618: rtos_queue_send_from_isr_failed: tstamp:60241828120 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373620: rtos_queue_send_from_isr_failed: tstamp:60241828227 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.373622: rtos_queue_send_from_isr_failed: tstamp:60241828333 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.373625: rtos_queue_send_from_isr_failed: tstamp:60241828441 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.373627: rtos_queue_send_from_isr_failed: tstamp:60241828544 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.373629: rtos_queue_send_from_isr_failed: tstamp:60241828648 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.373631: rtos_queue_send_from_isr_failed: tstamp:60241828752 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.373633: rtos_queue_send_failed: tstamp:60241829897 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.373637: rtcpu_vinotify_event: tstamp:60241830771 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:60241829514 data:0x00000001
kworker/4:2-8584 [004] … 1919.373638: rtcpu_vinotify_event: tstamp:60242027585 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:60242027209 data:0x00000000
kworker/4:2-8584 [004] … 1919.373640: rtcpu_vinotify_event: tstamp:60242033119 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:60242032754 data:0x00000001
kworker/4:2-8584 [004] … 1919.373642: rtcpu_vinotify_event: tstamp:60242038761 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:5 vi_tstamp:60242038397 data:0x08000000
kworker/4:2-8584 [004] … 1919.373644: rtcpu_vinotify_event: tstamp:60242537012 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:60242536386 data:0x043f0002
kworker/4:2-8584 [004] … 1919.373646: rtcpu_vinotify_event: tstamp:60242537131 tag:CHANSEL_FAULT channel:0x00 frame:5 vi_tstamp:60242536469 data:0x04400040
kworker/4:2-8584 [004] … 1919.373648: rtcpu_vinotify_event: tstamp:60242537638 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:5 vi_tstamp:60242537272 data:0x08000000
kworker/4:2-8584 [004] … 1919.373650: rtcpu_vinotify_event: tstamp:60242616540 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:60242616093 data:0x00000000
kworker/4:2-8584 [004] … 1919.429595: rtos_queue_peek_from_isr_failed: tstamp:60244049571 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1919.554414: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1919.554455: tegra_channel_capture_frame: sof:1919.225000960
vi-output, imx2-8919 [003] … 1919.562684: tegra_channel_capture_frame: sof:1919.453092800
kworker/4:2-8584 [004] … 1919.597547: rtos_queue_send_from_isr_failed: tstamp:60248890182 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597554: rtos_queue_send_from_isr_failed: tstamp:60248890300 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.597556: rtos_queue_send_from_isr_failed: tstamp:60248890407 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.597559: rtos_queue_send_from_isr_failed: tstamp:60248890516 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.597561: rtos_queue_send_from_isr_failed: tstamp:60248890620 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.597563: rtos_queue_send_from_isr_failed: tstamp:60248890725 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.597565: rtos_queue_send_from_isr_failed: tstamp:60248890830 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.597569: rtos_queue_send_failed: tstamp:60248891388 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597571: rtos_queue_send_from_isr_failed: tstamp:60248894003 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597573: rtos_queue_send_from_isr_failed: tstamp:60248894110 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.597575: rtos_queue_send_from_isr_failed: tstamp:60248894226 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.597577: rtos_queue_send_from_isr_failed: tstamp:60248894344 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.597580: rtos_queue_send_from_isr_failed: tstamp:60248894448 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.597582: rtos_queue_send_from_isr_failed: tstamp:60248894553 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.597584: rtos_queue_send_from_isr_failed: tstamp:60248894657 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.597586: rtos_queue_send_failed: tstamp:60248895082 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597588: rtos_queue_send_from_isr_failed: tstamp:60248899681 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597590: rtos_queue_send_from_isr_failed: tstamp:60248899789 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.597593: rtos_queue_send_from_isr_failed: tstamp:60248899895 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.597595: rtos_queue_send_from_isr_failed: tstamp:60248900003 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.597597: rtos_queue_send_from_isr_failed: tstamp:60248900108 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.597599: rtos_queue_send_from_isr_failed: tstamp:60248900213 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.597601: rtos_queue_send_from_isr_failed: tstamp:60248900317 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.597603: rtos_queue_send_failed: tstamp:60248900795 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597605: rtos_queue_send_from_isr_failed: tstamp:60248903131 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597611: rtos_queue_send_from_isr_failed: tstamp:60248903237 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.597613: rtos_queue_send_from_isr_failed: tstamp:60248903343 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.597616: rtos_queue_send_from_isr_failed: tstamp:60248903452 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.597618: rtos_queue_send_from_isr_failed: tstamp:60248903558 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.597620: rtos_queue_send_from_isr_failed: tstamp:60248903662 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.597623: rtos_queue_send_from_isr_failed: tstamp:60248903767 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.597625: rtos_queue_send_failed: tstamp:60248904681 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.597628: rtos_queue_peek_from_isr_failed: tstamp:60249049555 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1919.597632: rtcpu_vinotify_event: tstamp:60249155453 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:60249155078 data:0x00000000
kworker/4:2-8584 [004] … 1919.597634: rtcpu_vinotify_event: tstamp:60249160990 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:60249160623 data:0x00000001
kworker/4:2-8584 [004] … 1919.597636: rtcpu_vinotify_event: tstamp:60249166479 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:17 vi_tstamp:60249166112 data:0x08000000
kworker/4:2-8584 [004] … 1919.597638: rtcpu_vinotify_event: tstamp:60249664883 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:60249664254 data:0x043f0002
kworker/4:2-8584 [004] … 1919.597640: rtcpu_vinotify_event: tstamp:60249665001 tag:CHANSEL_FAULT channel:0x00 frame:17 vi_tstamp:60249664338 data:0x04400040
kworker/4:2-8584 [004] … 1919.597642: rtcpu_vinotify_event: tstamp:60249665506 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:17 vi_tstamp:60249665140 data:0x08000000
kworker/4:2-8584 [004] … 1919.597644: rtcpu_vinotify_event: tstamp:60249744412 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:60249743961 data:0x00000000
kworker/4:2-8584 [004] … 1919.765550: rtos_queue_peek_from_isr_failed: tstamp:60254049549 queue:0x0b4b4940
vi-output, imx2-8919 [003] … 1919.782153: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [003] … 1919.782187: tegra_channel_capture_frame: sof:1919.453092800
vi-output, imx2-8919 [004] … 1919.790754: tegra_channel_capture_frame: sof:1919.681184736
kworker/4:2-8584 [004] … 1919.821559: rtos_queue_send_from_isr_failed: tstamp:60256008824 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821565: rtos_queue_send_from_isr_failed: tstamp:60256008934 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.821567: rtos_queue_send_from_isr_failed: tstamp:60256009045 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.821569: rtos_queue_send_from_isr_failed: tstamp:60256009152 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.821572: rtos_queue_send_from_isr_failed: tstamp:60256009257 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.821574: rtos_queue_send_from_isr_failed: tstamp:60256009362 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.821576: rtos_queue_send_from_isr_failed: tstamp:60256009467 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.821579: rtos_queue_send_failed: tstamp:60256010017 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821581: rtos_queue_send_from_isr_failed: tstamp:60256011910 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821583: rtos_queue_send_from_isr_failed: tstamp:60256012017 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.821585: rtos_queue_send_from_isr_failed: tstamp:60256012123 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.821588: rtos_queue_send_from_isr_failed: tstamp:60256012231 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.821590: rtos_queue_send_from_isr_failed: tstamp:60256012334 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.821592: rtos_queue_send_from_isr_failed: tstamp:60256012439 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.821594: rtos_queue_send_from_isr_failed: tstamp:60256012544 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.821596: rtos_queue_send_failed: tstamp:60256012981 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821598: rtos_queue_send_from_isr_failed: tstamp:60256017121 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821600: rtos_queue_send_from_isr_failed: tstamp:60256017228 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.821603: rtos_queue_send_from_isr_failed: tstamp:60256017334 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.821605: rtos_queue_send_from_isr_failed: tstamp:60256017442 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.821607: rtos_queue_send_from_isr_failed: tstamp:60256017547 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.821609: rtos_queue_send_from_isr_failed: tstamp:60256017652 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.821611: rtos_queue_send_from_isr_failed: tstamp:60256017756 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.821613: rtos_queue_send_failed: tstamp:60256018185 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821615: rtos_queue_send_from_isr_failed: tstamp:60256020584 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821618: rtos_queue_send_from_isr_failed: tstamp:60256020690 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1919.821620: rtos_queue_send_from_isr_failed: tstamp:60256020795 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1919.821622: rtos_queue_send_from_isr_failed: tstamp:60256020908 queue:0x0b4af718
kworker/4:2-8584 [004] … 1919.821624: rtos_queue_send_from_isr_failed: tstamp:60256021013 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1919.821626: rtos_queue_send_from_isr_failed: tstamp:60256021117 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1919.821628: rtos_queue_send_from_isr_failed: tstamp:60256021220 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1919.821630: rtos_queue_send_failed: tstamp:60256022136 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1919.821634: rtcpu_vinotify_event: tstamp:60256283327 tag:ATOMP_FS channel:0x00 frame:29 vi_tstamp:60256282947 data:0x00000000
kworker/4:2-8584 [004] … 1919.821636: rtcpu_vinotify_event: tstamp:60256288860 tag:CHANSEL_PXL_SOF channel:0x00 frame:29 vi_tstamp:60256288493 data:0x00000001
kworker/4:2-8584 [004] … 1919.821638: rtcpu_vinotify_event: tstamp:60256293612 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:29 vi_tstamp:60256293227 data:0x08000000
kworker/4:2-8584 [004] … 1919.821640: rtcpu_vinotify_event: tstamp:60256792751 tag:CHANSEL_PXL_EOF channel:0x00 frame:29 vi_tstamp:60256792123 data:0x043f0002
kworker/4:2-8584 [004] … 1919.821642: rtcpu_vinotify_event: tstamp:60256792870 tag:CHANSEL_FAULT channel:0x00 frame:29 vi_tstamp:60256792206 data:0x04400040
kworker/4:2-8584 [004] … 1919.821644: rtcpu_vinotify_event: tstamp:60256793377 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:29 vi_tstamp:60256793010 data:0x08000000
kworker/4:2-8584 [004] … 1919.821646: rtcpu_vinotify_event: tstamp:60256872279 tag:ATOMP_FE channel:0x00 frame:29 vi_tstamp:60256871830 data:0x00000000
kworker/4:2-8584 [004] … 1919.933573: rtos_queue_peek_from_isr_failed: tstamp:60259049540 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1920.010039: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1920.010074: tegra_channel_capture_frame: sof:1919.681184736
vi-output, imx2-8919 [004] … 1920.018820: tegra_channel_capture_frame: sof:1919.909276640
kworker/4:2-8584 [004] … 1920.045560: rtos_queue_send_from_isr_failed: tstamp:60263130449 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045566: rtos_queue_send_from_isr_failed: tstamp:60263130567 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.045568: rtos_queue_send_from_isr_failed: tstamp:60263130674 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.045570: rtos_queue_send_from_isr_failed: tstamp:60263130783 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.045573: rtos_queue_send_from_isr_failed: tstamp:60263130887 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.045575: rtos_queue_send_from_isr_failed: tstamp:60263130991 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.045577: rtos_queue_send_from_isr_failed: tstamp:60263131096 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.045580: rtos_queue_send_failed: tstamp:60263131647 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045583: rtos_queue_send_from_isr_failed: tstamp:60263133794 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045585: rtos_queue_send_from_isr_failed: tstamp:60263133899 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.045587: rtos_queue_send_from_isr_failed: tstamp:60263134007 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.045589: rtos_queue_send_from_isr_failed: tstamp:60263134116 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.045591: rtos_queue_send_from_isr_failed: tstamp:60263134221 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.045594: rtos_queue_send_from_isr_failed: tstamp:60263134326 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.045596: rtos_queue_send_from_isr_failed: tstamp:60263134431 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.045598: rtos_queue_send_failed: tstamp:60263134858 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045600: rtos_queue_send_from_isr_failed: tstamp:60263139386 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045602: rtos_queue_send_from_isr_failed: tstamp:60263139492 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.045604: rtos_queue_send_from_isr_failed: tstamp:60263139598 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.045606: rtos_queue_send_from_isr_failed: tstamp:60263139707 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.045609: rtos_queue_send_from_isr_failed: tstamp:60263139812 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.045611: rtos_queue_send_from_isr_failed: tstamp:60263139917 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.045613: rtos_queue_send_from_isr_failed: tstamp:60263140022 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.045615: rtos_queue_send_failed: tstamp:60263140466 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045617: rtos_queue_send_from_isr_failed: tstamp:60263142250 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045619: rtos_queue_send_from_isr_failed: tstamp:60263142356 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.045621: rtos_queue_send_from_isr_failed: tstamp:60263142464 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.045624: rtos_queue_send_from_isr_failed: tstamp:60263142572 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.045626: rtos_queue_send_from_isr_failed: tstamp:60263142675 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.045628: rtos_queue_send_from_isr_failed: tstamp:60263142780 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.045630: rtos_queue_send_from_isr_failed: tstamp:60263142885 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.045632: rtos_queue_send_failed: tstamp:60263144030 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.045636: rtcpu_vinotify_event: tstamp:60263144900 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:60263143677 data:0x00000001
kworker/4:2-8584 [004] … 1920.045638: rtcpu_vinotify_event: tstamp:60263411200 tag:ATOMP_FS channel:0x00 frame:41 vi_tstamp:60263410818 data:0x00000000
kworker/4:2-8584 [004] … 1920.045640: rtcpu_vinotify_event: tstamp:60263416728 tag:CHANSEL_PXL_SOF channel:0x00 frame:41 vi_tstamp:60263416363 data:0x00000001
kworker/4:2-8584 [004] … 1920.045642: rtcpu_vinotify_event: tstamp:60263420680 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:41 vi_tstamp:60263420319 data:0x08000000
kworker/4:2-8584 [004] … 1920.045644: rtcpu_vinotify_event: tstamp:60263920619 tag:CHANSEL_PXL_EOF channel:0x00 frame:41 vi_tstamp:60263919993 data:0x043f0002
kworker/4:2-8584 [004] … 1920.045646: rtcpu_vinotify_event: tstamp:60263920737 tag:CHANSEL_FAULT channel:0x00 frame:41 vi_tstamp:60263920076 data:0x04400040
kworker/4:2-8584 [004] … 1920.045648: rtcpu_vinotify_event: tstamp:60263921247 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:41 vi_tstamp:60263920878 data:0x08000000
kworker/4:2-8584 [004] … 1920.045650: rtcpu_vinotify_event: tstamp:60264000151 tag:ATOMP_FE channel:0x00 frame:41 vi_tstamp:60263999700 data:0x00000000
kworker/4:2-8584 [004] … 1920.045653: rtos_queue_peek_from_isr_failed: tstamp:60264049533 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1920.213558: rtos_queue_peek_from_isr_failed: tstamp:60269049526 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1920.238268: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1920.238305: tegra_channel_capture_frame: sof:1919.909276640
vi-output, imx2-8919 [003] … 1920.246951: tegra_channel_capture_frame: sof:1920.137368352
kworker/4:2-8584 [004] … 1920.269560: rtos_queue_send_from_isr_failed: tstamp:60270258882 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269566: rtos_queue_send_from_isr_failed: tstamp:60270258993 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.269568: rtos_queue_send_from_isr_failed: tstamp:60270259100 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.269571: rtos_queue_send_from_isr_failed: tstamp:60270259208 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.269573: rtos_queue_send_from_isr_failed: tstamp:60270259313 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.269575: rtos_queue_send_from_isr_failed: tstamp:60270259418 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.269577: rtos_queue_send_from_isr_failed: tstamp:60270259523 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.269581: rtos_queue_send_failed: tstamp:60270260065 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269583: rtos_queue_send_from_isr_failed: tstamp:60270263492 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269585: rtos_queue_send_from_isr_failed: tstamp:60270263600 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.269587: rtos_queue_send_from_isr_failed: tstamp:60270263705 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.269589: rtos_queue_send_from_isr_failed: tstamp:60270263812 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.269592: rtos_queue_send_from_isr_failed: tstamp:60270263916 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.269594: rtos_queue_send_from_isr_failed: tstamp:60270264020 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.269596: rtos_queue_send_from_isr_failed: tstamp:60270264125 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.269598: rtos_queue_send_failed: tstamp:60270264548 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269600: rtos_queue_send_from_isr_failed: tstamp:60270270014 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269602: rtos_queue_send_from_isr_failed: tstamp:60270270122 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.269605: rtos_queue_send_from_isr_failed: tstamp:60270270228 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.269607: rtos_queue_send_from_isr_failed: tstamp:60270270336 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.269609: rtos_queue_send_from_isr_failed: tstamp:60270270440 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.269611: rtos_queue_send_from_isr_failed: tstamp:60270270543 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.269613: rtos_queue_send_from_isr_failed: tstamp:60270270649 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.269615: rtos_queue_send_failed: tstamp:60270271076 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269617: rtos_queue_send_from_isr_failed: tstamp:60270273886 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269620: rtos_queue_send_from_isr_failed: tstamp:60270273993 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.269622: rtos_queue_send_from_isr_failed: tstamp:60270274099 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.269624: rtos_queue_send_from_isr_failed: tstamp:60270274207 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.269626: rtos_queue_send_from_isr_failed: tstamp:60270274310 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.269628: rtos_queue_send_from_isr_failed: tstamp:60270274415 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.269630: rtos_queue_send_from_isr_failed: tstamp:60270274519 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.269636: rtos_queue_send_failed: tstamp:60270275449 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.269640: rtcpu_vinotify_event: tstamp:60270539066 tag:ATOMP_FS channel:0x00 frame:53 vi_tstamp:60270538688 data:0x00000000
kworker/4:2-8584 [004] … 1920.269642: rtcpu_vinotify_event: tstamp:60270544601 tag:CHANSEL_PXL_SOF channel:0x00 frame:53 vi_tstamp:60270544233 data:0x00000001
kworker/4:2-8584 [004] … 1920.269644: rtcpu_vinotify_event: tstamp:60270549786 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:53 vi_tstamp:60270549420 data:0x08000000
kworker/4:2-8584 [004] … 1920.269646: rtcpu_vinotify_event: tstamp:60271048487 tag:CHANSEL_PXL_EOF channel:0x00 frame:53 vi_tstamp:60271047864 data:0x043f0002
kworker/4:2-8584 [004] … 1920.269648: rtcpu_vinotify_event: tstamp:60271048607 tag:CHANSEL_FAULT channel:0x00 frame:53 vi_tstamp:60271047947 data:0x04400040
kworker/4:2-8584 [004] … 1920.269650: rtcpu_vinotify_event: tstamp:60271049111 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:53 vi_tstamp:60271048746 data:0x08000000
kworker/4:2-8584 [004] … 1920.269652: rtcpu_vinotify_event: tstamp:60271128021 tag:ATOMP_FE channel:0x00 frame:53 vi_tstamp:60271127571 data:0x00000000
kworker/4:2-8584 [004] … 1920.381550: rtos_queue_peek_from_isr_failed: tstamp:60274049522 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1920.484228: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1920.484263: tegra_channel_capture_frame: sof:1920.137368352
kworker/4:2-8584 [004] … 1920.493574: rtos_queue_send_from_isr_failed: tstamp:60277441223 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493580: rtos_queue_send_from_isr_failed: tstamp:60277441334 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.493583: rtos_queue_send_from_isr_failed: tstamp:60277441442 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.493585: rtos_queue_send_from_isr_failed: tstamp:60277441548 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.493587: rtos_queue_send_from_isr_failed: tstamp:60277441652 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.493589: rtos_queue_send_from_isr_failed: tstamp:60277441757 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.493591: rtos_queue_send_from_isr_failed: tstamp:60277441862 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.493594: rtos_queue_send_failed: tstamp:60277442396 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493596: rtos_queue_send_from_isr_failed: tstamp:60277444316 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493598: rtos_queue_send_from_isr_failed: tstamp:60277444422 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.493600: rtos_queue_send_from_isr_failed: tstamp:60277444527 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.493602: rtos_queue_send_from_isr_failed: tstamp:60277444635 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.493605: rtos_queue_send_from_isr_failed: tstamp:60277444738 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.493607: rtos_queue_send_from_isr_failed: tstamp:60277444846 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.493609: rtos_queue_send_from_isr_failed: tstamp:60277444951 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.493611: rtos_queue_send_failed: tstamp:60277445383 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493613: rtos_queue_send_from_isr_failed: tstamp:60277956241 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493615: rtos_queue_send_from_isr_failed: tstamp:60277956347 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.493617: rtos_queue_send_from_isr_failed: tstamp:60277956454 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.493620: rtos_queue_send_from_isr_failed: tstamp:60277956561 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.493622: rtos_queue_send_from_isr_failed: tstamp:60277956666 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.493624: rtos_queue_send_from_isr_failed: tstamp:60277956771 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.493626: rtos_queue_send_from_isr_failed: tstamp:60277956876 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.493628: rtos_queue_send_failed: tstamp:60277957316 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493630: rtos_queue_send_from_isr_failed: tstamp:60277959598 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493633: rtos_queue_send_from_isr_failed: tstamp:60277959703 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.493635: rtos_queue_send_from_isr_failed: tstamp:60277959808 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.493637: rtos_queue_send_from_isr_failed: tstamp:60277959916 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.493639: rtos_queue_send_from_isr_failed: tstamp:60277960021 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.493641: rtos_queue_send_from_isr_failed: tstamp:60277960126 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.493643: rtos_queue_send_from_isr_failed: tstamp:60277960231 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.493645: rtos_queue_send_failed: tstamp:60277961364 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.493649: rtcpu_vinotify_event: tstamp:60277962232 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:60277960997 data:0x00000001
vi-output, imx2-8919 [003] … 1920.494052: tegra_channel_capture_frame: sof:1920.384467744
kworker/4:2-8584 [004] … 1920.549584: rtcpu_vinotify_event: tstamp:60278260924 tag:ATOMP_FS channel:0x00 frame:66 vi_tstamp:60278260546 data:0x00000000
kworker/4:2-8584 [004] … 1920.549588: rtcpu_vinotify_event: tstamp:60278266459 tag:CHANSEL_PXL_SOF channel:0x00 frame:66 vi_tstamp:60278266091 data:0x00000001
kworker/4:2-8584 [004] … 1920.549590: rtcpu_vinotify_event: tstamp:60278271602 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:66 vi_tstamp:60278271241 data:0x08000000
kworker/4:2-8584 [004] … 1920.549592: rtcpu_vinotify_event: tstamp:60278770348 tag:CHANSEL_PXL_EOF channel:0x00 frame:66 vi_tstamp:60278769722 data:0x043f0002
kworker/4:2-8584 [004] … 1920.549594: rtcpu_vinotify_event: tstamp:60278770466 tag:CHANSEL_FAULT channel:0x00 frame:66 vi_tstamp:60278769805 data:0x04400040
kworker/4:2-8584 [004] … 1920.549596: rtcpu_vinotify_event: tstamp:60278770974 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:66 vi_tstamp:60278770606 data:0x08000000
kworker/4:2-8584 [004] … 1920.549598: rtcpu_vinotify_event: tstamp:60278849880 tag:ATOMP_FE channel:0x00 frame:66 vi_tstamp:60278849431 data:0x00000000
kworker/4:2-8584 [004] … 1920.549602: rtos_queue_peek_from_isr_failed: tstamp:60279049533 queue:0x0b4b4940
vi-output, imx2-8919 [003] … 1920.714467: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [003] … 1920.714506: tegra_channel_capture_frame: sof:1920.384467744
kworker/4:2-8584 [004] … 1920.717516: rtos_queue_peek_from_isr_failed: tstamp:60284049505 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1920.717522: rtos_queue_send_from_isr_failed: tstamp:60285139563 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717524: rtos_queue_send_from_isr_failed: tstamp:60285139673 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.717525: rtos_queue_send_from_isr_failed: tstamp:60285139782 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.717527: rtos_queue_send_from_isr_failed: tstamp:60285139900 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.717528: rtos_queue_send_from_isr_failed: tstamp:60285140005 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.717529: rtos_queue_send_from_isr_failed: tstamp:60285140110 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.717530: rtos_queue_send_from_isr_failed: tstamp:60285140215 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.717533: rtos_queue_send_failed: tstamp:60285140765 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717534: rtos_queue_send_from_isr_failed: tstamp:60285143990 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717536: rtos_queue_send_from_isr_failed: tstamp:60285144096 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.717537: rtos_queue_send_from_isr_failed: tstamp:60285144201 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.717538: rtos_queue_send_from_isr_failed: tstamp:60285144310 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.717539: rtos_queue_send_from_isr_failed: tstamp:60285144415 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.717541: rtos_queue_send_from_isr_failed: tstamp:60285144519 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.717542: rtos_queue_send_from_isr_failed: tstamp:60285144625 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.717543: rtos_queue_send_failed: tstamp:60285145058 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717545: rtos_queue_send_from_isr_failed: tstamp:60285150721 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717546: rtos_queue_send_from_isr_failed: tstamp:60285150826 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.717547: rtos_queue_send_from_isr_failed: tstamp:60285150931 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.717549: rtos_queue_send_from_isr_failed: tstamp:60285151039 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.717550: rtos_queue_send_from_isr_failed: tstamp:60285151142 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.717551: rtos_queue_send_from_isr_failed: tstamp:60285151246 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.717552: rtos_queue_send_from_isr_failed: tstamp:60285151351 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.717554: rtos_queue_send_failed: tstamp:60285151792 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717555: rtos_queue_send_from_isr_failed: tstamp:60285154829 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.717556: rtos_queue_send_from_isr_failed: tstamp:60285154935 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.717557: rtos_queue_send_from_isr_failed: tstamp:60285155040 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.717559: rtos_queue_send_from_isr_failed: tstamp:60285155148 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.717560: rtos_queue_send_from_isr_failed: tstamp:60285155253 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.717561: rtos_queue_send_from_isr_failed: tstamp:60285155366 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.717562: rtos_queue_send_from_isr_failed: tstamp:60285155471 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.717564: rtos_queue_send_failed: tstamp:60285156398 queue:0x0b4a7698
vi-output, imx2-8919 [004] … 1920.722108: tegra_channel_capture_frame: sof:1920.612559552
kworker/4:2-8584 [004] … 1920.773550: rtcpu_vinotify_event: tstamp:60285388800 tag:ATOMP_FS channel:0x00 frame:78 vi_tstamp:60285388418 data:0x00000000
kworker/4:2-8584 [004] … 1920.773556: rtcpu_vinotify_event: tstamp:60285394333 tag:CHANSEL_PXL_SOF channel:0x00 frame:78 vi_tstamp:60285393963 data:0x00000001
kworker/4:2-8584 [004] … 1920.773559: rtcpu_vinotify_event: tstamp:60285398251 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:78 vi_tstamp:60285397887 data:0x08000000
kworker/4:2-8584 [004] … 1920.773561: rtcpu_vinotify_event: tstamp:60285898216 tag:CHANSEL_PXL_EOF channel:0x00 frame:78 vi_tstamp:60285897594 data:0x043f0002
kworker/4:2-8584 [004] … 1920.773563: rtcpu_vinotify_event: tstamp:60285898336 tag:CHANSEL_FAULT channel:0x00 frame:78 vi_tstamp:60285897677 data:0x04400040
kworker/4:2-8584 [004] … 1920.773565: rtcpu_vinotify_event: tstamp:60285898844 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:78 vi_tstamp:60285898475 data:0x08000000
kworker/4:2-8584 [004] … 1920.773567: rtcpu_vinotify_event: tstamp:60285977752 tag:ATOMP_FE channel:0x00 frame:78 vi_tstamp:60285977301 data:0x00000000
kworker/4:2-8584 [004] … 1920.885545: rtos_queue_peek_from_isr_failed: tstamp:60289049504 queue:0x0b4b4940
vi-output, imx2-8919 [000] … 1920.958332: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [000] … 1920.958363: tegra_channel_capture_frame: sof:1920.612559552
vi-output, imx2-8919 [000] .n… 1920.969217: tegra_channel_capture_frame: sof:1920.859659456
kworker/4:2-8584 [004] … 1920.997561: rtos_queue_send_from_isr_failed: tstamp:60292260817 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997567: rtos_queue_send_from_isr_failed: tstamp:60292260926 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.997569: rtos_queue_send_from_isr_failed: tstamp:60292261035 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.997571: rtos_queue_send_from_isr_failed: tstamp:60292261142 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.997573: rtos_queue_send_from_isr_failed: tstamp:60292261246 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.997576: rtos_queue_send_from_isr_failed: tstamp:60292261351 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.997578: rtos_queue_send_from_isr_failed: tstamp:60292261457 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.997581: rtos_queue_send_failed: tstamp:60292261988 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997583: rtos_queue_send_from_isr_failed: tstamp:60292265110 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997585: rtos_queue_send_from_isr_failed: tstamp:60292265217 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.997588: rtos_queue_send_from_isr_failed: tstamp:60292265323 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.997590: rtos_queue_send_from_isr_failed: tstamp:60292265431 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.997592: rtos_queue_send_from_isr_failed: tstamp:60292265535 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.997594: rtos_queue_send_from_isr_failed: tstamp:60292265639 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.997596: rtos_queue_send_from_isr_failed: tstamp:60292265743 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.997598: rtos_queue_send_failed: tstamp:60292266166 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997601: rtos_queue_send_from_isr_failed: tstamp:60292774162 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997603: rtos_queue_send_from_isr_failed: tstamp:60292774270 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.997605: rtos_queue_send_from_isr_failed: tstamp:60292774376 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.997607: rtos_queue_send_from_isr_failed: tstamp:60292774484 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.997609: rtos_queue_send_from_isr_failed: tstamp:60292774598 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.997611: rtos_queue_send_from_isr_failed: tstamp:60292774702 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.997613: rtos_queue_send_from_isr_failed: tstamp:60292774816 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.997616: rtos_queue_send_failed: tstamp:60292775302 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997618: rtos_queue_send_from_isr_failed: tstamp:60292777029 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997620: rtos_queue_send_from_isr_failed: tstamp:60292777135 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1920.997622: rtos_queue_send_from_isr_failed: tstamp:60292777246 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1920.997624: rtos_queue_send_from_isr_failed: tstamp:60292777353 queue:0x0b4af718
kworker/4:2-8584 [004] … 1920.997626: rtos_queue_send_from_isr_failed: tstamp:60292777458 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1920.997628: rtos_queue_send_from_isr_failed: tstamp:60292777562 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1920.997630: rtos_queue_send_from_isr_failed: tstamp:60292777666 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1920.997633: rtos_queue_send_failed: tstamp:60292778581 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1920.997636: rtcpu_vinotify_event: tstamp:60293110655 tag:ATOMP_FS channel:0x00 frame:91 vi_tstamp:60293110278 data:0x00000000
kworker/4:2-8584 [004] … 1920.997638: rtcpu_vinotify_event: tstamp:60293116188 tag:CHANSEL_PXL_SOF channel:0x00 frame:91 vi_tstamp:60293115823 data:0x00000001
kworker/4:2-8584 [004] … 1920.997640: rtcpu_vinotify_event: tstamp:60293121752 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:91 vi_tstamp:60293121379 data:0x08000000
kworker/4:2-8584 [004] … 1920.997642: rtcpu_vinotify_event: tstamp:60293620078 tag:CHANSEL_PXL_EOF channel:0x00 frame:91 vi_tstamp:60293619453 data:0x043f0002
kworker/4:2-8584 [004] … 1920.997644: rtcpu_vinotify_event: tstamp:60293620196 tag:CHANSEL_FAULT channel:0x00 frame:91 vi_tstamp:60293619536 data:0x04400040
kworker/4:2-8584 [004] … 1920.997649: rtcpu_vinotify_event: tstamp:60293620702 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:91 vi_tstamp:60293620336 data:0x08000000
kworker/4:2-8584 [004] … 1920.997651: rtcpu_vinotify_event: tstamp:60293699610 tag:ATOMP_FE channel:0x00 frame:91 vi_tstamp:60293699160 data:0x00000000
kworker/4:2-8584 [004] … 1921.053559: rtos_queue_peek_from_isr_failed: tstamp:60294049492 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1921.165568: rtos_queue_peek_from_isr_failed: tstamp:60299049488 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1921.204555: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1921.204593: tegra_channel_capture_frame: sof:1920.859659456
vi-output, imx2-8919 [005] … 1921.216330: tegra_channel_capture_frame: sof:1921.106758944
kworker/4:2-8584 [004] … 1921.221573: rtos_queue_send_from_isr_failed: tstamp:60299950876 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221579: rtos_queue_send_from_isr_failed: tstamp:60299950988 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.221581: rtos_queue_send_from_isr_failed: tstamp:60299951097 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.221583: rtos_queue_send_from_isr_failed: tstamp:60299951203 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.221585: rtos_queue_send_from_isr_failed: tstamp:60299951308 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.221588: rtos_queue_send_from_isr_failed: tstamp:60299951413 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.221590: rtos_queue_send_from_isr_failed: tstamp:60299951518 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.221593: rtos_queue_send_failed: tstamp:60299952068 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221595: rtos_queue_send_from_isr_failed: tstamp:60299954366 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221597: rtos_queue_send_from_isr_failed: tstamp:60299954472 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.221600: rtos_queue_send_from_isr_failed: tstamp:60299954581 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.221602: rtos_queue_send_from_isr_failed: tstamp:60299954689 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.221604: rtos_queue_send_from_isr_failed: tstamp:60299954803 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.221606: rtos_queue_send_from_isr_failed: tstamp:60299954909 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.221608: rtos_queue_send_from_isr_failed: tstamp:60299955014 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.221610: rtos_queue_send_failed: tstamp:60299955442 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221613: rtos_queue_send_from_isr_failed: tstamp:60300467102 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221615: rtos_queue_send_from_isr_failed: tstamp:60300467208 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.221617: rtos_queue_send_from_isr_failed: tstamp:60300467325 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.221619: rtos_queue_send_from_isr_failed: tstamp:60300467431 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.221621: rtos_queue_send_from_isr_failed: tstamp:60300467535 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.221623: rtos_queue_send_from_isr_failed: tstamp:60300467638 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.221625: rtos_queue_send_from_isr_failed: tstamp:60300467742 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.221628: rtos_queue_send_failed: tstamp:60300468175 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221630: rtos_queue_send_from_isr_failed: tstamp:60300470608 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221632: rtos_queue_send_from_isr_failed: tstamp:60300470714 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.221634: rtos_queue_send_from_isr_failed: tstamp:60300470821 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.221636: rtos_queue_send_from_isr_failed: tstamp:60300470928 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.221638: rtos_queue_send_from_isr_failed: tstamp:60300471033 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.221640: rtos_queue_send_from_isr_failed: tstamp:60300471140 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.221643: rtos_queue_send_from_isr_failed: tstamp:60300471243 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.221645: rtos_queue_send_failed: tstamp:60300472160 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.221649: rtcpu_vinotify_event: tstamp:60300832515 tag:ATOMP_FS channel:0x00 frame:104 vi_tstamp:60300832137 data:0x00000000
kworker/4:2-8584 [004] … 1921.221651: rtcpu_vinotify_event: tstamp:60300838059 tag:CHANSEL_PXL_SOF channel:0x00 frame:104 vi_tstamp:60300837683 data:0x00000001
kworker/4:2-8584 [004] … 1921.221653: rtcpu_vinotify_event: tstamp:60300842835 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:104 vi_tstamp:60300842468 data:0x08000000
kworker/4:2-8584 [004] … 1921.277550: rtcpu_vinotify_event: tstamp:60301341938 tag:CHANSEL_PXL_EOF channel:0x00 frame:104 vi_tstamp:60301341314 data:0x043f0002
kworker/4:2-8584 [004] … 1921.277555: rtcpu_vinotify_event: tstamp:60301342057 tag:CHANSEL_FAULT channel:0x00 frame:104 vi_tstamp:60301341397 data:0x04400040
kworker/4:2-8584 [004] … 1921.277557: rtcpu_vinotify_event: tstamp:60301342561 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:104 vi_tstamp:60301342196 data:0x08000000
kworker/4:2-8584 [004] … 1921.277560: rtcpu_vinotify_event: tstamp:60301421468 tag:ATOMP_FE channel:0x00 frame:104 vi_tstamp:60301421021 data:0x00000000
kworker/4:2-8584 [004] … 1921.333608: rtos_queue_peek_from_isr_failed: tstamp:60304049480 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1921.435590: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1921.435622: tegra_channel_capture_frame: sof:1921.106758944
vi-output, imx2-8919 [004] … 1921.444435: tegra_channel_capture_frame: sof:1921.334850592
kworker/4:2-8584 [004] … 1921.445581: rtos_queue_send_from_isr_failed: tstamp:60307680262 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445585: rtos_queue_send_from_isr_failed: tstamp:60307680372 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.445588: rtos_queue_send_from_isr_failed: tstamp:60307680481 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.445590: rtos_queue_send_from_isr_failed: tstamp:60307680599 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.445593: rtos_queue_send_from_isr_failed: tstamp:60307680703 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.445595: rtos_queue_send_from_isr_failed: tstamp:60307680817 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.445597: rtos_queue_send_from_isr_failed: tstamp:60307680920 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.445601: rtos_queue_send_failed: tstamp:60307681503 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445603: rtos_queue_send_from_isr_failed: tstamp:60307683354 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445605: rtos_queue_send_from_isr_failed: tstamp:60307683461 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.445607: rtos_queue_send_from_isr_failed: tstamp:60307683566 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.445609: rtos_queue_send_from_isr_failed: tstamp:60307683673 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.445612: rtos_queue_send_from_isr_failed: tstamp:60307683778 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.445614: rtos_queue_send_from_isr_failed: tstamp:60307683882 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.445616: rtos_queue_send_from_isr_failed: tstamp:60307683986 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.445618: rtos_queue_send_failed: tstamp:60307684424 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445620: rtos_queue_send_from_isr_failed: tstamp:60307688207 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445623: rtos_queue_send_from_isr_failed: tstamp:60307688313 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.445626: rtos_queue_send_from_isr_failed: tstamp:60307688419 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.445628: rtos_queue_send_from_isr_failed: tstamp:60307688528 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.445630: rtos_queue_send_from_isr_failed: tstamp:60307688633 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.445632: rtos_queue_send_from_isr_failed: tstamp:60307688739 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.445634: rtos_queue_send_from_isr_failed: tstamp:60307688843 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.445636: rtos_queue_send_failed: tstamp:60307689275 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445638: rtos_queue_send_from_isr_failed: tstamp:60307690883 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445641: rtos_queue_send_from_isr_failed: tstamp:60307690989 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.445643: rtos_queue_send_from_isr_failed: tstamp:60307691096 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.445645: rtos_queue_send_from_isr_failed: tstamp:60307691203 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.445647: rtos_queue_send_from_isr_failed: tstamp:60307691308 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.445649: rtos_queue_send_from_isr_failed: tstamp:60307691413 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.445651: rtos_queue_send_from_isr_failed: tstamp:60307691517 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.445653: rtos_queue_send_failed: tstamp:60307692436 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.445657: rtcpu_vinotify_event: tstamp:60307960386 tag:ATOMP_FS channel:0x00 frame:116 vi_tstamp:60307960006 data:0x00000000
kworker/4:2-8584 [004] … 1921.445659: rtcpu_vinotify_event: tstamp:60307965929 tag:CHANSEL_PXL_SOF channel:0x00 frame:116 vi_tstamp:60307965551 data:0x00000001
kworker/4:2-8584 [004] … 1921.445661: rtcpu_vinotify_event: tstamp:60307971107 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:116 vi_tstamp:60307970742 data:0x08000000
kworker/4:2-8584 [004] … 1921.501564: rtcpu_vinotify_event: tstamp:60308469808 tag:CHANSEL_PXL_EOF channel:0x00 frame:116 vi_tstamp:60308469182 data:0x043f0002
kworker/4:2-8584 [004] … 1921.501569: rtcpu_vinotify_event: tstamp:60308469926 tag:CHANSEL_FAULT channel:0x00 frame:116 vi_tstamp:60308469265 data:0x04400040
kworker/4:2-8584 [004] … 1921.501571: rtcpu_vinotify_event: tstamp:60308470433 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:116 vi_tstamp:60308470065 data:0x08000000
kworker/4:2-8584 [004] … 1921.501573: rtcpu_vinotify_event: tstamp:60308549339 tag:ATOMP_FE channel:0x00 frame:116 vi_tstamp:60308548889 data:0x00000000
kworker/4:2-8584 [004] … 1921.501577: rtos_queue_peek_from_isr_failed: tstamp:60309049479 queue:0x0b4b4940
vi-output, imx2-8919 [005] … 1921.664585: tegra_channel_capture_setup: vnc_id 0 W 1456 H 1088 fmt 10
vi-output, imx2-8919 [005] … 1921.664622: tegra_channel_capture_frame: sof:1921.334850592
kworker/4:2-8584 [004] … 1921.669513: rtos_queue_peek_from_isr_failed: tstamp:60314049464 queue:0x0b4b4940
kworker/4:2-8584 [004] … 1921.669519: rtos_queue_send_from_isr_failed: tstamp:60314834706 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669520: rtos_queue_send_from_isr_failed: tstamp:60314834816 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.669521: rtos_queue_send_from_isr_failed: tstamp:60314834926 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.669522: rtos_queue_send_from_isr_failed: tstamp:60314835036 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.669523: rtos_queue_send_from_isr_failed: tstamp:60314835142 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.669523: rtos_queue_send_from_isr_failed: tstamp:60314835246 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.669524: rtos_queue_send_from_isr_failed: tstamp:60314835350 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.669526: rtos_queue_send_failed: tstamp:60314835882 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669527: rtos_queue_send_from_isr_failed: tstamp:60314838432 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669528: rtos_queue_send_from_isr_failed: tstamp:60314838548 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.669529: rtos_queue_send_from_isr_failed: tstamp:60314838653 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.669530: rtos_queue_send_from_isr_failed: tstamp:60314838760 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.669530: rtos_queue_send_from_isr_failed: tstamp:60314838867 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.669531: rtos_queue_send_from_isr_failed: tstamp:60314838970 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.669532: rtos_queue_send_from_isr_failed: tstamp:60314839074 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.669533: rtos_queue_send_failed: tstamp:60314839506 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669534: rtos_queue_send_from_isr_failed: tstamp:60314843736 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669535: rtos_queue_send_from_isr_failed: tstamp:60314843842 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.669536: rtos_queue_send_from_isr_failed: tstamp:60314843948 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.669536: rtos_queue_send_from_isr_failed: tstamp:60314844056 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.669537: rtos_queue_send_from_isr_failed: tstamp:60314844161 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.669538: rtos_queue_send_from_isr_failed: tstamp:60314844266 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.669539: rtos_queue_send_from_isr_failed: tstamp:60314844371 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.669540: rtos_queue_send_failed: tstamp:60314844804 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669541: rtos_queue_send_from_isr_failed: tstamp:60314846757 queue:0x0b4a7698
kworker/4:2-8584 [004] … 1921.669541: rtos_queue_send_from_isr_failed: tstamp:60314846863 queue:0x0b4ab1a8
kworker/4:2-8584 [004] … 1921.669542: rtos_queue_send_from_isr_failed: tstamp:60314846970 queue:0x0b4acdd8
kworker/4:2-8584 [004] … 1921.669543: rtos_queue_send_from_isr_failed: tstamp:60314847077 queue:0x0b4af718
kworker/4:2-8584 [004] … 1921.669544: rtos_queue_send_from_isr_failed: tstamp:60314847203 queue:0x0b4b04d8
kworker/4:2-8584 [004] … 1921.669545: rtos_queue_send_from_isr_failed: tstamp:60314847308 queue:0x0b4b1298
kworker/4:2-8584 [004] … 1921.669546: rtos_queue_send_from_isr_failed: tstamp:60314847413 queue:0x0b4b2058
kworker/4:2-8584 [004] … 1921.669546: rtos_queue_send_failed: tstamp:60314848344 queue:0x0b4a7698
vi-output, imx2-8919 [000] … 1921.672476: tegra_channel_capture_frame: sof:1921.562942208
