Hello, I am trying to acquire a frame from an IMX297 sensor connected to Xavier devkit MIPI port 0.
This is the command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1440,height=1080,pixelformat='Y10 ' --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
The procedure was already tested and known to be working fine. Now we switched to another setup, including a CSI aggregator between sensor and Jetson, and stream acquisition does not work anymore.
Here dmesg log:
1 [ 167.437818] i2c 2-0010: vc_mod_set_mode(): Set module mode: 0 (lanes: 1, format: Y10 , type: STREAM)
2 [ 167.438179] i2c 2-0010: vc_mod_set_power(): Set module power: down
3 [ 167.438546] i2c 2-0010: vc_mod_set_power(): Set module power: up
4 [ 167.450503] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
5 [ 167.840595] vc_mipi 2-001a: vc_sen_set_roi(): Set sensor roi: (x: 0, y: 0, width: 736, height: 540)
6 [ 167.850288] vc_mipi 2-001a: vc_sen_set_exposure(): Set sensor exposure: 10000 us
7 [ 167.853263] vc_mipi 2-001a: vc_sen_set_gain(): Set sensor gain: 0
8 [ 167.854253] vc_mipi 2-001a: vc_sen_set_blacklevel(): Set sensor black level: 60
9 [ 167.855998] vc_mipi 2-001a: vc_sen_start_stream(): Start streaming
10 [ 172.458657] tegra194-vi5 15c10000.vi: no reply from camera processor
11 [ 172.459245] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 5000 ms
12 [ 172.460196] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
13 [ 172.470642] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
14 [ 177.578237] tegra194-vi5 15c10000.vi: no reply from camera processor
15 [ 177.578743] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 5000 ms
16 [ 177.579602] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
17 [ 177.590584] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
18 [ 182.698213] tegra194-vi5 15c10000.vi: no reply from camera processor
19 [ 182.699021] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 5000 ms
20 [ 182.699615] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
21 [ 182.708986] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
22 [ 182.712568] vc_mipi 2-001a: vc_sen_stop_stream(): Stop streaming
[ 2067.597733] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2067.598196] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 5000 ms
[ 2067.598973] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 2067.606837] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 2067.626182] [RCE] Configuring VI GoS.
[ 2067.626280] [RCE] VM GOS[#0] addr=0xc2100000
[ 2067.626352] [RCE] VM GOS[#1] addr=0xc2101000
[ 2067.626417] [RCE] VM GOS[#2] addr=0xc2102000
[ 2067.626486] [RCE] VM GOS[#3] addr=0xc2103000
[ 2067.626550] [RCE] VM GOS[#4] addr=0xc2104000
[ 2067.626614] [RCE] VM GOS[#5] addr=0xc2105000
Trace log:
# tracer: nop
# entries-in-buffer/entries-written: 201/201 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-5428 [003] .... 240.012976: tegra_channel_open: vi-output, vc_mipi 2-001a
v4l2-ctl-5428 [005] .... 240.016525: tegra_channel_set_power: vc_mipi 2-001a : 0x1
v4l2-ctl-5428 [005] .... 240.016538: camera_common_s_power: status : 0x1
v4l2-ctl-5428 [005] .... 240.016577: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
v4l2-ctl-5428 [005] .... 240.016580: csi_s_power: enable : 0x1
v4l2-ctl-5428 [005] .... 240.020338: tegra_channel_capture_setup: vnc_id 0 W 736 H 540 fmt c5
v4l2-ctl-5428 [000] .... 240.036505: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-5428 [005] .... 240.043683: tegra_channel_set_stream: 15a00000.nvcsi--3 : 0x1
v4l2-ctl-5428 [005] .... 240.043688: csi_s_stream: enable : 0x1
v4l2-ctl-5428 [005] .... 240.043700: tegra_channel_set_stream: vc_mipi 2-001a : 0x1
kworker/0:1-758 [000] .... 240.054705: rtos_queue_peek_from_isr_failed: tstamp:7876663918 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 240.054710: rtcpu_start: tstamp:7876665513
kworker/0:1-758 [000] .... 240.054713: rtos_queue_send_from_isr_failed: tstamp:7876796369 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 240.054715: rtos_queue_send_from_isr_failed: tstamp:7876796521 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 240.054717: rtos_queue_send_from_isr_failed: tstamp:7876796671 queue:0x0bcb9220
kworker/0:1-758 [000] .... 240.054718: rtos_queue_send_from_isr_failed: tstamp:7876796818 queue:0x0bcb9fe0
kworker/0:1-758 [000] .... 240.054719: rtos_queue_send_from_isr_failed: tstamp:7876796964 queue:0x0bcbada0
kworker/0:1-758 [000] .... 240.054722: rtcpu_string: tstamp:7876797397 id:0x04010000 str:"Configuring VI GoS."
kworker/0:1-758 [000] .... 240.054770: rtcpu_string: tstamp:7876797597 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000"
kworker/0:1-758 [000] .... 240.054833: rtcpu_string: tstamp:7876797854 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000"
kworker/0:1-758 [000] .... 240.054858: rtcpu_string: tstamp:7876798099 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000"
kworker/0:1-758 [000] .... 240.054878: rtcpu_string: tstamp:7876798335 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000"
kworker/0:1-758 [000] .... 240.054899: rtcpu_string: tstamp:7876798584 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000"
kworker/0:1-758 [000] .... 240.054921: rtcpu_string: tstamp:7876798815 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000"
kworker/0:1-758 [000] .... 240.054942: rtcpu_string: tstamp:7876807243 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:1-758 [000] .... 240.054946: rtcpu_string: tstamp:7876807361 id:0x04010000 str:"on 2.2"
kworker/0:1-758 [000] .... 240.054968: rtos_queue_send_from_isr_failed: tstamp:7876824721 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 240.054969: rtos_queue_send_from_isr_failed: tstamp:7876824892 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 240.055002: rtos_queue_send_from_isr_failed: tstamp:7876825048 queue:0x0bcb9220
kworker/0:1-758 [000] .... 240.055003: rtos_queue_send_from_isr_failed: tstamp:7876825198 queue:0x0bcb9fe0
kworker/0:1-758 [000] .... 240.055005: rtos_queue_send_from_isr_failed: tstamp:7876825343 queue:0x0bcbada0
kworker/0:1-758 [000] .... 240.055006: rtcpu_string: tstamp:7876826264 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000"
kworker/0:1-758 [000] .... 240.055031: rtos_queue_send_from_isr_failed: tstamp:7877051702 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 240.055032: rtos_queue_send_from_isr_failed: tstamp:7877051845 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 240.055034: rtos_queue_send_from_isr_failed: tstamp:7877051990 queue:0x0bcb9220
kworker/0:1-758 [000] .... 240.055035: rtos_queue_send_from_isr_failed: tstamp:7877052129 queue:0x0bcb9fe0
kworker/0:1-758 [000] .... 240.055037: rtos_queue_send_from_isr_failed: tstamp:7877052266 queue:0x0bcbada0
kworker/0:1-758 [000] .... 240.055040: rtcpu_vinotify_event: tstamp:7877146239 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7245343840 data:0x10000000
kworker/0:1-758 [000] .... 240.055042: rtcpu_vinotify_event: tstamp:7877146392 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7245352000 data:0x31000001
kworker/0:1-758 [000] .... 240.055043: rtcpu_vinotify_event: tstamp:7877146545 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:7245354144 data:0x07020001
kworker/0:1-758 [000] .... 240.055044: rtcpu_vinotify_event: tstamp:7877146675 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7245387520 data:0x10000000
kworker/0:1-758 [000] .... 240.055046: rtcpu_vinotify_event: tstamp:7877146823 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7245395776 data:0x31000002
kworker/0:1-758 [000] .... 240.222945: rtos_queue_peek_from_isr_failed: tstamp:7881664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 240.390906: rtos_queue_peek_from_isr_failed: tstamp:7886664280 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 240.559031: rtos_queue_peek_from_isr_failed: tstamp:7891664279 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 240.726970: rtos_queue_peek_from_isr_failed: tstamp:7896664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 240.839079: rtos_queue_peek_from_isr_failed: tstamp:7901664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.007097: rtos_queue_peek_from_isr_failed: tstamp:7906664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.175225: rtos_queue_peek_from_isr_failed: tstamp:7911664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.342895: rtos_queue_peek_from_isr_failed: tstamp:7916664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.510878: rtos_queue_peek_from_isr_failed: tstamp:7921664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.679246: rtos_queue_peek_from_isr_failed: tstamp:7926664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.847606: rtos_queue_peek_from_isr_failed: tstamp:7931664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 241.958893: rtos_queue_peek_from_isr_failed: tstamp:7936664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 242.126875: rtos_queue_peek_from_isr_failed: tstamp:7941664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 242.295110: rtos_queue_peek_from_isr_failed: tstamp:7946664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 242.462882: rtos_queue_peek_from_isr_failed: tstamp:7951664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 242.630922: rtos_queue_peek_from_isr_failed: tstamp:7956664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 242.798872: rtos_queue_peek_from_isr_failed: tstamp:7961664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 242.966867: rtos_queue_peek_from_isr_failed: tstamp:7966664280 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 243.078903: rtos_queue_peek_from_isr_failed: tstamp:7971664280 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 243.246874: rtos_queue_peek_from_isr_failed: tstamp:7976664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 243.415009: rtos_queue_peek_from_isr_failed: tstamp:7981664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 243.582905: rtos_queue_peek_from_isr_failed: tstamp:7986664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 243.751060: rtos_queue_peek_from_isr_failed: tstamp:7991664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 243.918879: rtos_queue_peek_from_isr_failed: tstamp:7996664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 244.086882: rtos_queue_peek_from_isr_failed: tstamp:8001664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 244.198884: rtos_queue_peek_from_isr_failed: tstamp:8006664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 244.366876: rtos_queue_peek_from_isr_failed: tstamp:8011664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 244.534923: rtos_queue_peek_from_isr_failed: tstamp:8016664277 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 244.702998: rtos_queue_peek_from_isr_failed: tstamp:8021664276 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 244.870896: rtos_queue_peek_from_isr_failed: tstamp:8026664280 queue:0x0bcbbbb8
kworker/0:1-758 [000] .... 245.038922: rtos_queue_peek_from_isr_failed: tstamp:8031664276 queue:0x0bcbbbb8
vi-output, vc_m-5430 [000] .... 245.145839: tegra_channel_capture_setup: vnc_id 0 W 736 H 540 fmt c5
kworker/0:1-758 [000] .... 245.150749: rtos_queue_send_from_isr_failed: tstamp:8036384695 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 245.150761: rtos_queue_send_from_isr_failed: tstamp:8036384848 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 245.150766: rtos_queue_send_from_isr_failed: tstamp:8036384993 queue:0x0bcb9220
kworker/0:1-758 [000] .... 245.150772: rtos_queue_send_from_isr_failed: tstamp:8036385142 queue:0x0bcb9fe0
kworker/0:1-758 [000] .... 245.150777: rtos_queue_send_from_isr_failed: tstamp:8036385282 queue:0x0bcbada0
kworker/0:1-758 [000] .... 245.150782: rtos_queue_send_from_isr_failed: tstamp:8036385482 queue:0x0bcb2dd0
kworker/0:1-758 [000] .... 245.150787: rtos_queue_send_from_isr_failed: tstamp:8036385609 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 245.150819: rtos_queue_send_from_isr_failed: tstamp:8036385738 queue:0x0bcb7638
kworker/0:1-758 [000] .... 245.150824: rtos_queue_send_from_isr_failed: tstamp:8036385867 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 245.150849: rtos_queue_send_from_isr_failed: tstamp:8036385998 queue:0x0bcb91b8
kworker/0:1-758 [000] .... 245.150853: rtos_queue_send_from_isr_failed: tstamp:8036386124 queue:0x0bcb9220
kworker/0:1-758 [000] .... 245.150856: rtos_queue_send_from_isr_failed: tstamp:8036386252 queue:0x0bcb9f78
kworker/0:1-758 [000] .... 245.150860: rtos_queue_send_from_isr_failed: tstamp:8036386378 queue:0x0bcb9fe0
kworker/0:1-758 [000] .... 245.150863: rtos_queue_send_from_isr_failed: tstamp:8036386505 queue:0x0bcbad38
kworker/0:1-758 [000] .... 245.150867: rtos_queue_send_from_isr_failed: tstamp:8036386631 queue:0x0bcbada0
kworker/0:1-758 [000] .... 245.150870: rtos_queue_send_from_isr_failed: tstamp:8036434166 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 245.150874: rtos_queue_send_from_isr_failed: tstamp:8036434310 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 245.150877: rtos_queue_send_from_isr_failed: tstamp:8036434454 queue:0x0bcb9220
kworker/0:1-758 [000] .... 245.150880: rtos_queue_send_from_isr_failed: tstamp:8036434593 queue:0x0bcb9fe0
kworker/0:1-758 [000] .... 245.150883: rtos_queue_send_from_isr_failed: tstamp:8036434735 queue:0x0bcbada0
kworker/0:1-758 [000] .... 245.150886: rtos_queue_send_from_isr_failed: tstamp:8036480102 queue:0x0bcb2e38
kworker/0:1-758 [000] .... 245.150890: rtos_queue_send_from_isr_failed: tstamp:8036480245 queue:0x0bcb76a0
kworker/0:1-758 [000] .... 245.150893: rtos_queue_send_from_isr_failed: tstamp:8036480387 queue:0x0bcb9220
kworker/0:1-758 [000] .... 245.150896: rtos_queue_send_from_isr_failed: tstamp:8036480527 queue:0x0bcb9fe0
Many thanks in advance
Andrea
