Hello, I am trying to acquire a raw frame from IMX297 MIPI sensor connected to Xavier devkit MIPI port 0.
A CSI 2:1 aggregator is connected between sensor and Jetson port. Just a single sensor is enabled for streaming, transmitting to virtual channel 0.
Here the command, already verified in other setups, which unfortunately results in acquisition timeout, and a properly sized but full black raw output:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1440,height=1080,pixelformat='Y10 ' --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
Trace output:
# tracer: nop
# entries-in-buffer/entries-written: 500/500 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-5524 [004] .... 199.286637: tegra_channel_open: vi-output, vc_mipi 2-001a
v4l2-ctl-5524 [000] .... 199.288866: tegra_channel_set_power: vc_mipi 2-001a : 0x1
v4l2-ctl-5524 [000] .... 199.288877: camera_common_s_power: status : 0x1
v4l2-ctl-5524 [000] .... 199.288908: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
v4l2-ctl-5524 [000] .... 199.288911: csi_s_power: enable : 0x1
v4l2-ctl-5524 [000] .... 199.292967: tegra_channel_capture_setup: vnc_id 0 W 736 H 540 fmt c5
v4l2-ctl-5524 [000] .... 199.304581: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-5524 [002] .... 199.312064: tegra_channel_set_stream: 15a00000.nvcsi--3 : 0x1
v4l2-ctl-5524 [002] .... 199.312070: csi_s_stream: enable : 0x1
v4l2-ctl-5524 [002] .... 199.312081: tegra_channel_set_stream: vc_mipi 2-001a : 0x1
kworker/0:4-4503 [000] .... 199.322209: rtos_queue_peek_from_isr_failed: tstamp:6603589454 queue:0x0bcbbbb8
kworker/0:4-4503 [000] .... 199.322214: rtcpu_start: tstamp:6603590795
kworker/0:4-4503 [000] .... 199.322215: rtos_queue_send_from_isr_failed: tstamp:6603730583 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 199.322217: rtos_queue_send_from_isr_failed: tstamp:6603730736 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 199.322218: rtos_queue_send_from_isr_failed: tstamp:6603730885 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 199.322219: rtos_queue_send_from_isr_failed: tstamp:6603731032 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 199.322220: rtos_queue_send_from_isr_failed: tstamp:6603731177 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 199.322222: rtcpu_string: tstamp:6603731618 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-4503 [000] .... 199.322236: rtcpu_string: tstamp:6603731824 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-4503 [000] .... 199.322241: rtcpu_string: tstamp:6603732076 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-4503 [000] .... 199.322246: rtcpu_string: tstamp:6603732317 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-4503 [000] .... 199.322252: rtcpu_string: tstamp:6603732549 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-4503 [000] .... 199.322256: rtcpu_string: tstamp:6603732798 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-4503 [000] .... 199.322261: rtcpu_string: tstamp:6603733030 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-4503 [000] .... 199.322265: rtcpu_string: tstamp:6603741815 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:4-4503 [000] .... 199.322269: rtcpu_string: tstamp:6603741947 id:0x04010000 str:"on 2.2
kworker/0:4-4503 [000] .... 199.322274: rtos_queue_send_from_isr_failed: tstamp:6603755234 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 199.322275: rtos_queue_send_from_isr_failed: tstamp:6603755386 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 199.322276: rtos_queue_send_from_isr_failed: tstamp:6603755540 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 199.322298: rtos_queue_send_from_isr_failed: tstamp:6603755688 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 199.322298: rtos_queue_send_from_isr_failed: tstamp:6603755834 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 199.322299: rtcpu_string: tstamp:6603756776 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:4-4503 [000] .... 199.322305: rtos_queue_send_from_isr_failed: tstamp:6603990582 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 199.322306: rtos_queue_send_from_isr_failed: tstamp:6603990739 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 199.322307: rtos_queue_send_from_isr_failed: tstamp:6603990885 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 199.322308: rtos_queue_send_from_isr_failed: tstamp:6603991024 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 199.322309: rtos_queue_send_from_isr_failed: tstamp:6603991164 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 199.322311: rtcpu_vinotify_event: tstamp:6604129984 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5161826080 data:0x10000000
kworker/0:4-4503 [000] .... 199.322312: rtcpu_vinotify_event: tstamp:6604130136 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5161834272 data:0x31000001
kworker/0:4-4503 [000] .... 199.322313: rtcpu_vinotify_event: tstamp:6604130288 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:5161836416 data:0x07020001
kworker/0:4-4503 [000] .... 199.322314: rtcpu_vinotify_event: tstamp:6604130416 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5161876096 data:0x10000000
kworker/0:4-4503 [000] .... 199.322315: rtcpu_vinotify_event: tstamp:6604130563 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:5161884352 data:0x31000002
vi-output, vc_m-5526 [000] .... 199.364116: tegra_channel_capture_frame: sof:0.0
vi-output, vc_m-5526 [000] .... 199.364120: tegra_channel_capture_frame: eof:6764.145223680
kworker/0:4-4503 [000] .... 199.378193: rtcpu_vinotify_event: tstamp:6605286269 tag:FS channel:0x00 frame:2 vi_tstamp:6605106840 data:0x00000010
kworker/0:4-4503 [000] .... 199.378195: rtcpu_vinotify_event: tstamp:6605286426 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:6605106842 data:0x00000000
kworker/0:4-4503 [000] .... 199.378197: rtcpu_nvcsi_intr: tstamp:6605614219 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.378198: rtcpu_nvcsi_intr: tstamp:6605614219 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.378199: rtcpu_vinotify_event: tstamp:6605671902 tag:CHANSEL_EMBED_SOF channel:0x23 frame:2 vi_tstamp:6605610314 data:0x00000004
kworker/0:4-4503 [000] .... 199.378200: rtcpu_vinotify_event: tstamp:6605672054 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:6605610468 data:0x00002000
kworker/0:4-4503 [000] .... 199.378201: rtcpu_vinotify_event: tstamp:6605672186 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:5221108480 data:0x01020001
kworker/0:4-4503 [000] .... 199.434590: rtcpu_nvcsi_intr: tstamp:6606621164 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.434596: rtcpu_nvcsi_intr: tstamp:6606621164 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.434600: rtcpu_vinotify_event: tstamp:6606828234 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:6606617412 data:0x00013008
kworker/0:4-4503 [000] .... 199.434604: rtcpu_vinotify_event: tstamp:6606828366 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:5253330752 data:0x01020001
kworker/0:4-4503 [000] .... 199.434607: rtcpu_vinotify_event: tstamp:6606828515 tag:ATOMP_EMB_DATA_DONE channel:0x23 frame:2 vi_tstamp:6606617428 data:0x00000000
kworker/0:4-4503 [000] .... 199.434609: rtcpu_vinotify_event: tstamp:6606828642 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:5253333056 data:0x03020001
kworker/0:4-4503 [000] .... 199.434612: rtcpu_vinotify_event: tstamp:6607625649 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:6607624202 data:0x00023800
kworker/0:4-4503 [000] .... 199.434615: rtcpu_vinotify_event: tstamp:6607625783 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:5285548160 data:0x01020001
kworker/0:4-4503 [000] .... 199.434618: rtcpu_nvcsi_intr: tstamp:6607628104 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.434621: rtcpu_nvcsi_intr: tstamp:6607628104 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.490488: rtos_queue_peek_from_isr_failed: tstamp:6608589797 queue:0x0bcbbbb8
kworker/0:4-4503 [000] .... 199.490510: rtcpu_nvcsi_intr: tstamp:6608635054 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.490523: rtcpu_nvcsi_intr: tstamp:6608635054 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.546297: rtcpu_nvcsi_intr: tstamp:6609641995 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.546299: rtcpu_nvcsi_intr: tstamp:6609641995 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.546300: rtcpu_nvcsi_intr: tstamp:6610648942 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.546301: rtcpu_nvcsi_intr: tstamp:6610648942 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.602538: rtcpu_nvcsi_intr: tstamp:6611655885 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.602543: rtcpu_nvcsi_intr: tstamp:6611655885 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.602547: rtos_queue_send_from_isr_failed: tstamp:6611901763 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 199.602549: rtos_queue_send_from_isr_failed: tstamp:6611901911 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 199.602551: rtos_queue_send_from_isr_failed: tstamp:6611902056 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 199.602553: rtos_queue_send_from_isr_failed: tstamp:6611902196 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 199.602555: rtos_queue_send_from_isr_failed: tstamp:6611902336 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 199.602556: rtcpu_nvcsi_intr: tstamp:6612662829 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.602558: rtcpu_nvcsi_intr: tstamp:6612662829 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.658579: rtos_queue_peek_from_isr_failed: tstamp:6613589797 queue:0x0bcbbbb8
kworker/0:4-4503 [000] .... 199.658588: rtcpu_nvcsi_intr: tstamp:6613669773 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.658594: rtcpu_nvcsi_intr: tstamp:6613669773 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.658599: rtcpu_nvcsi_intr: tstamp:6614676718 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.658603: rtcpu_nvcsi_intr: tstamp:6614676718 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.714440: rtcpu_nvcsi_intr: tstamp:6615683660 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.714466: rtcpu_nvcsi_intr: tstamp:6615683660 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.770405: rtcpu_nvcsi_intr: tstamp:6616690604 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.770424: rtcpu_nvcsi_intr: tstamp:6616690604 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.770479: rtcpu_nvcsi_intr: tstamp:6617697549 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.770494: rtcpu_nvcsi_intr: tstamp:6617697549 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.826367: rtos_queue_peek_from_isr_failed: tstamp:6618589796 queue:0x0bcbbbb8
kworker/0:4-4503 [000] .... 199.826388: rtcpu_nvcsi_intr: tstamp:6618704494 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.826401: rtcpu_nvcsi_intr: tstamp:6618704494 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.826412: rtcpu_nvcsi_intr: tstamp:6619711438 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.826424: rtcpu_nvcsi_intr: tstamp:6619711438 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.882347: rtcpu_nvcsi_intr: tstamp:6620718383 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.882365: rtcpu_nvcsi_intr: tstamp:6620718383 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.882377: rtcpu_nvcsi_intr: tstamp:6621725328 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.882389: rtcpu_nvcsi_intr: tstamp:6621725328 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.938546: rtcpu_nvcsi_intr: tstamp:6622732273 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.938571: rtcpu_nvcsi_intr: tstamp:6622732273 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.994355: rtos_queue_peek_from_isr_failed: tstamp:6623589797 queue:0x0bcbbbb8
kworker/0:4-4503 [000] .... 199.994377: rtcpu_nvcsi_intr: tstamp:6623739215 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.994390: rtcpu_nvcsi_intr: tstamp:6623739215 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.994401: rtcpu_nvcsi_intr: tstamp:6624746160 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 199.994413: rtcpu_nvcsi_intr: tstamp:6624746160 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 200.050450: rtcpu_nvcsi_intr: tstamp:6625753103 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 200.050469: rtcpu_nvcsi_intr: tstamp:6625753103 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 204.362088: rtcpu_nvcsi_intr: tstamp:6760683616 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 204.362111: rtcpu_nvcsi_intr: tstamp:6760683616 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 204.362127: rtcpu_nvcsi_intr: tstamp:6761690561 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 204.362142: rtcpu_nvcsi_intr: tstamp:6761690561 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
vi-output, vc_m-5526 [000] .... 204.398198: tegra_channel_capture_setup: vnc_id 0 W 736 H 540 fmt c5
v4l2-ctl-5524 [000] .... 204.400556: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-5524 [000] .... 204.400590: tegra_channel_set_stream: vc_mipi 2-001a : 0x0
kworker/0:4-4503 [000] .... 204.422260: rtcpu_nvcsi_intr: tstamp:6762697505 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 204.422280: rtcpu_nvcsi_intr: tstamp:6762697505 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-4503 [000] .... 204.422298: rtos_queue_send_from_isr_failed: tstamp:6762782815 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.422309: rtos_queue_send_from_isr_failed: tstamp:6762782961 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.422319: rtos_queue_send_from_isr_failed: tstamp:6762783105 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.422328: rtos_queue_send_from_isr_failed: tstamp:6762783245 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.422338: rtos_queue_send_from_isr_failed: tstamp:6762783385 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.422349: rtos_queue_send_failed: tstamp:6762783996 queue:0x0bcb6938
kworker/0:4-4503 [000] .... 204.422359: rtos_queue_send_from_isr_failed: tstamp:6762784599 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.422368: rtos_queue_send_from_isr_failed: tstamp:6762784757 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.422379: rtos_queue_send_from_isr_failed: tstamp:6762784899 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.422388: rtos_queue_send_from_isr_failed: tstamp:6762785032 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.422397: rtos_queue_send_from_isr_failed: tstamp:6762785162 queue:0x0bcbad38
kworker/0:4-4503 [000] .... 204.422406: rtos_queue_send_from_isr_failed: tstamp:6762785290 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.422419: rtcpu_vinotify_event: tstamp:6762797076 tag:FE channel:0x00 frame:2 vi_tstamp:6762786123 data:0x00000020
kworker/0:4-4503 [000] .... 204.422430: rtcpu_vinotify_event: tstamp:6762797213 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:6762786124 data:0x01000000
kworker/0:4-4503 [000] .... 204.422573: rtcpu_vinotify_event: tstamp:6762797369 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:6762786125 data:0x00000000
kworker/0:4-4503 [000] .... 204.422584: rtos_queue_send_from_isr_failed: tstamp:6762832195 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.422594: rtos_queue_send_from_isr_failed: tstamp:6762832340 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.422604: rtos_queue_send_from_isr_failed: tstamp:6762832485 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.422613: rtos_queue_send_from_isr_failed: tstamp:6762832626 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.422622: rtos_queue_send_from_isr_failed: tstamp:6762832764 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.422632: rtos_queue_send_from_isr_failed: tstamp:6762894394 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.422641: rtos_queue_send_from_isr_failed: tstamp:6762894537 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.422650: rtos_queue_send_from_isr_failed: tstamp:6762894679 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.422659: rtos_queue_send_from_isr_failed: tstamp:6762894820 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.422669: rtos_queue_send_from_isr_failed: tstamp:6762894960 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.422678: rtos_queue_send_from_isr_failed: tstamp:6762906732 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.422687: rtos_queue_send_from_isr_failed: tstamp:6762906872 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.422696: rtos_queue_send_from_isr_failed: tstamp:6762907012 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.422706: rtos_queue_send_from_isr_failed: tstamp:6762907151 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.422715: rtos_queue_send_from_isr_failed: tstamp:6762907290 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.422724: rtos_queue_send_from_isr_failed: tstamp:6762958066 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.422733: rtos_queue_send_from_isr_failed: tstamp:6762958210 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.422743: rtos_queue_send_from_isr_failed: tstamp:6762958354 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.422752: rtos_queue_send_from_isr_failed: tstamp:6762958493 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.422761: rtos_queue_send_from_isr_failed: tstamp:6762958629 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.422772: rtcpu_string: tstamp:6762959104 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-4503 [000] .... 204.422847: rtcpu_string: tstamp:6762959315 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-4503 [000] .... 204.422891: rtcpu_string: tstamp:6762959560 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-4503 [000] .... 204.422933: rtcpu_string: tstamp:6762959795 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-4503 [000] .... 204.422972: rtcpu_string: tstamp:6762960019 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-4503 [000] .... 204.423011: rtcpu_string: tstamp:6762960259 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-4503 [000] .... 204.423188: rtcpu_string: tstamp:6762960482 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-4503 [000] .... 204.423252: rtos_queue_peek_from_isr_failed: tstamp:6763589795 queue:0x0bcbbbb8
v4l2-ctl-5524 [001] .... 204.454222: tegra_channel_set_stream: 15a00000.nvcsi--3 : 0x0
v4l2-ctl-5524 [001] .... 204.454266: csi_s_stream: enable : 0x0
v4l2-ctl-5524 [000] .... 204.475573: tegra_channel_close: vi-output, vc_mipi 2-001a
v4l2-ctl-5524 [000] .... 204.475593: tegra_channel_set_power: vc_mipi 2-001a : 0x0
v4l2-ctl-5524 [000] .... 204.475612: camera_common_s_power: status : 0x0
v4l2-ctl-5524 [000] .... 204.475845: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
v4l2-ctl-5524 [000] .... 204.475854: csi_s_power: enable : 0x0
kworker/0:4-4503 [000] .... 204.477807: rtos_queue_send_from_isr_failed: tstamp:6764685456 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.477817: rtos_queue_send_from_isr_failed: tstamp:6764685600 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.477822: rtos_queue_send_from_isr_failed: tstamp:6764685744 queue:0x0bcb9220
kworker/0:4-4503 [000] .... 204.477830: rtos_queue_send_from_isr_failed: tstamp:6764685884 queue:0x0bcb9fe0
kworker/0:4-4503 [000] .... 204.477835: rtos_queue_send_from_isr_failed: tstamp:6764686037 queue:0x0bcbada0
kworker/0:4-4503 [000] .... 204.477840: rtos_queue_send_from_isr_failed: tstamp:6764935675 queue:0x0bcb2e38
kworker/0:4-4503 [000] .... 204.477845: rtos_queue_send_from_isr_failed: tstamp:6764935824 queue:0x0bcb76a0
kworker/0:4-4503 [000] .... 204.477851: rtos_queue_send_from_isr_failed: tstamp:6764935976 queue:0x0bcb9220
Many thanks in advance
Andrea
