Imx327 camera on TX2
I use an IMX327 camera on the TX2 DevKit,The camera adapter used directly leads the camera interface pin out, without the PCA95X module.
I measured the camera interface and found that there was no 1.2V output, but has 1.8V and 2.8V .
Is the problem shown in log caused by the absence of 1.2V?
imx327-log.txt (67.7 KB)
[ 11.596544] tegra-i2c 3180000.i2c: pio timed out addr: 0x10 tlen:12 rlen:4
[ 11.603486] tegra-i2c 3180000.i2c: — register dump for debugging ----
[ 11.610171] tegra-i2c 3180000.i2c: I2C_CNFG - 0x22c00
[ 11.615266] tegra-i2c 3180000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.621927] tegra-i2c 3180000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 11.627458] tegra-i2c 3180000.i2c: I2C_FIFO_STATUS - 0x800080
[ 11.633247] tegra-i2c 3180000.i2c: I2C_INT_MASK - 0x7d
[ 11.638423] tegra-i2c 3180000.i2c: I2C_INT_STATUS - 0x2
[ 11.643692] tegra-i2c 3180000.i2c: i2c transfer timed out addr: 0x10
[ 1.422503] imx327 2-001a: imx_probe: Probing v4l2 sensor at addr 0x1a - Aug 29 2022/08:46:28
[ 1.422519] imx327 2-001a: imx_probe: of_match_device() OK
[ 1.422574] imx327 2-001a: imx_probe: devm_kzalloc() OK
[ 1.424108] imx327 2-001a: imx_parse_dt: external-trigger-mode not present in DT, def=-1
[ 1.424133] imx327 2-001a: imx_parse_dt: flash-output=1
[ 1.424140] imx327 2-001a: imx_parse_dt: fpga_addr not present in DT, def=0x10
[ 1.426343] imx327 2-001a: imx_power_get: Get regulator avdd
[ 1.427564] imx327 2-001a: imx_power_get: Get regulator iovdd
[ 1.428015] imx327 2-001a: imx_power_get: Get regulator dvdd
[ 1.430726] imx327 2-001a: tegracam sensor driver:vc_mipi_v2.0.6
[ 1.430736] imx327 2-001a: imx_probe: tegracam_device_register() OK
[ 1.430761] imx327 2-001a: imx_board_setup: mclk_freq=24000 pixel_clock=801907200 cil_settletime=0 discontinuous_clk=0
[ 1.430771] imx327 2-001a: imx_board_setup: width,height,line_length=1920,1080,2200 pix_fmt=0x30314752 ‘RG10’ embedded_metadata_height=1
It’s depend on HW design. You may need to confirm with HW to confirm if need 1.2V or not.
