IMX390 sensor driver is not probing
Hi all,
I’m using the jetson orin with a camera module, when i dmesg the terminal to check if drivers are probing, i am not having any output. I also tried to add the drivers which are compiled as modules (M) by adding them using :
$ sudo insmode <driver_name>.ko
I am see that the driver was loaded when i use lsmod but nothing happens in the terminal when i check with dmesg.
Hiw can make drivers probing sensors ?
hello chakibdace,
are you actually have IMX390 camera device connected to AGX Orin?
please see-also developer guide, Device-tree overlay. you should enable Jetson-IO to select DTB overlay to enable camera driver.
Hi @JerryChang
I guess that the V4L driver should probe even if the camera sensor is not connected, and am not seeing in video devices when i do :
ls /dev | grep video*
Also even if in the tegra234-camera-imx390-a00.dtsi there is nodes i2c in the modules as below
modules {
			module0 {
				badge = "imx390_rear";
				position = "rear";
				orientation = "1";
				drivernode0 {
					/* Declare PCL support driver (classically known as guid)  */
					pcl_id = "v4l2_sensor";
					/* Driver v4l2 device name */
					devname = "imx390 30-001b";
					/* Declare the device-tree hierarchy to driver instance */
					proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx390_a@1b";
			module1 {
				badge = "imx390_front";
				position = "front";
				orientation = "1";
				drivernode0 {
					devname = "imx390 30-001c";
					proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx390_b@1c";
When in the jetson i run the command
ls /dev | grep i2c*
I’m having the output below
i2c-0
i2c-1
i2c-2
i2c-3
i2c-4
i2c-5
i2c-6
i2c-7
i2c-8
i2c-9
Where is i2c-30 ?
Btw what’s the purpose of using Device tree overlay ?
I thought that to implement a driver device, we only need to implement dtsi files one for mapping with other components and second to add dev nodes.
Thank you for your support
hello chakibdace,
no, that’s incorrect.
there’ll be device registration process during kernel initialization stage. it’ll looking for camera nodes according to your device tree definition, and power-on/off camera devices in order to checking the functionality. register the device to sysfs as video node without errors.
reply couple of your questions…
(1) device tree overlay
it’s main device tree to define hardware connections, you may create a device-tree overlay file, to override the main device tree. the real use-case is for registering the camera module dynamically.
(2) >>Where is i2c-30 ?
you may refer to $public_sources/kernel_src/hardware/nvidia/platform/t23x/concord/kernel-dts/cvb/tegra234-p3737-0000-camera-imx390-a00.dtsi
as you can see, there’s i2c_mux. i.e. tca9546 as an i2c bus multiplexer/switch. you may see-also Topic 192486 for more details.
BTW,
may I know who’s your camera vendor?
had you test these IMX390 on other platform/L4T release before?
Hi @JerryChang
Thanks your for detailed explanations, i mean that there is no device registration process during kernel initialization stage even if the driver imx390 is enabled.
I’m using L4T 35.1 and the camera module is a custom one.
Hi @JerryChang
To summarize my issue, i could give an ar0820 sensor driver which i’ve tested in JetPack 4.3, when i run dmesg i can see that it registers to i2c bus 30 31 32 33 (4 cameras support), you can check the logs below
jetson@xavier:~$ dmesg | grep pca
[    1.949576] pca954x 2-0070: vcc-pullup regulator not found
[    1.949590] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[    1.949596] pca954x 2-0070: device detect skipped.
[    1.952478] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
jetson@xavier:~$ dmesg | grep i2c
[    0.807361] iommu: Adding device 3160000.i2c to group 12
[    0.807857] iommu: Adding device c240000.i2c to group 13
[    0.808470] iommu: Adding device 3180000.i2c to group 14
[    0.808986] iommu: Adding device 3190000.i2c to group 15
[    0.809564] iommu: Adding device 31b0000.i2c to group 16
[    0.809982] iommu: Adding device 31c0000.i2c to group 17
[    0.810375] iommu: Adding device c250000.i2c to group 18
[    0.810793] iommu: Adding device 31e0000.i2c to group 19
[    0.935718] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    1.947660] i2c /dev entries driver
[    1.950309] i2c i2c-2: Added multiplexed i2c bus 30
[    1.950944] i2c i2c-2: Added multiplexed i2c bus 31
[    1.951610] i2c i2c-2: Added multiplexed i2c bus 32
[    1.952469] i2c i2c-2: Added multiplexed i2c bus 33
[    1.982349] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    1.982496] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    1.982553] max9296 30-0048: max9296_write_reg:i2c write failed, 0x10 = 1
[    1.982942] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    1.983093] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    1.983146] max9296 30-0048: max9296_write_reg:i2c write failed, 0x10 = 21
[    2.090046] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.090206] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.090263] max9295 30-0040: max9295_write_reg:i2c write failed, 0x10 = 21
[    2.298019] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.298175] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.298230] max9295 30-0040: max9295_write_reg:i2c write failed, 0xd = 0
[    2.298637] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.298769] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.298845] max9295 30-0040: max9295_write_reg:i2c write failed, 0x2be = 90
[    2.299237] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.299371] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.299427] max9295 30-0040: max9295_write_reg:i2c write failed, 0x2bf = 60
[    2.299823] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.299978] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.300032] max9295 30-0040: max9295_write_reg:i2c write failed, 0x3f1 = 89
[    2.300515] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.300654] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.300707] max9295 30-0040: max9295_write_reg:i2c write failed, 0x1 = 8
[    2.301086] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.301244] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.301298] max9295 30-0040: max9295_write_reg:i2c write failed, 0x10 = 21
[    2.505999] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.506131] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.506188] max9295 30-0040: max9295_write_reg:i2c write failed, 0x330 = 0
[    2.506550] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.506680] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.506732] max9295 30-0040: max9295_write_reg:i2c write failed, 0x331 = 33
[    2.507080] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.507215] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.507268] max9295 30-0040: max9295_write_reg:i2c write failed, 0x332 = 20
[    2.507631] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.507760] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.507814] max9295 30-0040: max9295_write_reg:i2c write failed, 0x333 = d
[    2.508227] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.508358] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.508435] max9295 30-0040: max9295_write_reg:i2c write failed, 0x334 = 20
[    2.508821] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.508956] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.509008] max9295 30-0040: max9295_write_reg:i2c write failed, 0x335 = 7
[    2.509394] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.509550] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.509603] max9295 30-0040: max9295_write_reg:i2c write failed, 0x314 = 22
[    2.509990] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[    2.510121] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
jetson@xavier:~$ dmesg | grep ar0820
[    1.953704] ar0820 30-0010: probing v4l2 sensor.
[    1.954187] ar0820 30-0010: tegracam sensor driver:ar0820_v2.0.6
[    2.300424] ar0820 30-0010: Detected AR0820 sensor
[    2.610376] ar0820 31-0010: probing v4l2 sensor.
[    2.610628] ar0820 31-0010: tegracam sensor driver:ar0820_v2.0.6
[    2.956264] ar0820 31-0010: Detected AR0820 sensor
[    3.266394] ar0820 32-0010: probing v4l2 sensor.
[    3.266660] ar0820 32-0010: tegracam sensor driver:ar0820_v2.0.6
[    3.612253] ar0820 32-0010: Detected AR0820 sensor
[    3.922359] ar0820 33-0010: probing v4l2 sensor.
[    3.922588] ar0820 33-0010: tegracam sensor driver:ar0820_v2.0.6
[    4.268208] ar0820 33-0010: Detected AR0820 sensor
[    8.554532] tegra194-vi5 15c10000.vi: subdev ar0820 30-0010 bound
[    8.555183] tegra194-vi5 15c10000.vi: subdev ar0820 31-0010 bound
[    8.555710] tegra194-vi5 15c10000.vi: subdev ar0820 32-0010 bound
[    8.556262] tegra194-vi5 15c10000.vi: subdev ar0820 33-0010 bound
jetson@xavier:~$
But in Orin, when i try to use the imx390 driver, there is no i2c devices which are added, and there is no i2c registration process, check the logs below :
jetson@orin:~$ sudo dmesg | grep failed
[    2.522692] tegradccommon module_init failed
[    2.526962] tegradc module_init failed
[    6.824417] dce: dce_admin_setup_clients_ipc:518  Get queue info failed for [2]
[    9.670042] pca954x 2-0070: probe failed
[    9.680681] pca954x: probe of 2-0070 failed with error -121
[    9.756252] pca954x 2-0077: probe failed
[    9.760355] pca954x: probe of 2-0077 failed with error -121
[    9.819608] pca953x 2-0021: failed writing register
[    9.824692] pca953x: probe of 2-0021 failed with error -121
[   13.295555] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[   13.303718] nvethernet 6810000.ethernet: failed to read MDIO address
[   13.317177] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[   14.269895] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[   17.042788] ucsi_ccg 1-0008: request_threaded_irq failed - -5
[   17.044047] ucsi_ccg: probe of 1-0008 failed with error -5
[   29.238690] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[   29.239515] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[   32.549900] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[  438.578398] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
jetson@orin:~$ sudo dmesg | grep failure
[    9.843352] i2c i2c-2: of_i2c: modalias failure on /i2c@3180000/ov5693_c@36
[    9.864089] i2c i2c-2: of_i2c: modalias failure on /i2c@3180000/e2832@2b
jetson@orin:/$ sudo find -name *imx390*
find: ‘./proc/4962’: No such file or directory
./boot/tegra234-p3737-camera-imx390-overlay.dtbo
./boot/tegra194-p2822-camera-imx390-overlay.dtbo
./usr/lib/modules/5.10.104-tegra/kernel/drivers/media/i2c/nv_imx390.ko
./usr/src/linux-headers-5.10.104-tegra-ubuntu20.04_aarch64/kernel-5.10/include/config/nv/video/imx390.h
find: ‘./run/user/1000/gvfs’: Permission denied
./sys/bus/i2c/drivers/imx390
./sys/firmware/devicetree/base/i2c@3180000/tca9546@70/i2c@0/imx390_a@1b
./sys/firmware/devicetree/base/i2c@3180000/tca9546@70/i2c@0/imx390_b@1c
./sys/firmware/devicetree/base/__symbols__/imx390_csi_in1
./sys/firmware/devicetree/base/__symbols__/imx390_csi_out1
./sys/firmware/devicetree/base/__symbols__/imx390_imx390_out1
./sys/firmware/devicetree/base/__symbols__/imx390_vi_in1
./sys/firmware/devicetree/base/__symbols__/imx390_cam0
./sys/firmware/devicetree/base/__symbols__/imx390_csi_in0
./sys/firmware/devicetree/base/__symbols__/imx390_csi_out0
./sys/firmware/devicetree/base/__symbols__/imx390_imx390_out0
./sys/firmware/devicetree/base/__symbols__/imx390_cam1
./sys/firmware/devicetree/base/__symbols__/imx390_vi_in0
./sys/module/nv_imx390
./sys/module/nv_imx390/drivers/i2c:imx390
[    4.601003] i2c-core: driver [PEX9749 thermal sensor] registered
[    4.610981] i2c-core: driver [bd9571mwv] registered
[    4.615987] i2c-core: driver [rk808] registered
[    4.850390] i2c /dev entries driver
[    4.854077] tegra-i2c 3160000.i2c: Adding to iommu group 3
[    4.859887] tegra-i2c c240000.i2c: Adding to iommu group 3
[    4.865584] tegra-i2c 3180000.i2c: Adding to iommu group 3
[    4.871272] tegra-i2c 3190000.i2c: Adding to iommu group 3
[    4.876949] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[    4.882626] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[    4.888305] tegra-i2c c250000.i2c: Adding to iommu group 3
[    4.893981] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[    4.899857] i2c-core: driver [pca954x] registered
[    4.904702] i2c-core: driver [ir-kbd-i2c] registered
[    4.909791] i2c-core: driver [max9295] registered
[    4.914621] i2c-core: driver [max9296] registered
[    4.921541] i2c-core: driver [bq27xxx-battery] registered
[    4.968182] i2c-dev: adapter [Tegra BPMP I2C adapter] registered as minor 4
[    4.968229] i2c i2c-4: adapter [Tegra BPMP I2C adapter] registered
[    4.968237] i2c i2c-4: of_i2c: walking child nodes
[    4.968243] i2c i2c-4: of_i2c: register /bpmp/i2c/vrs@3c
[    5.040012] i2c i2c-4: client [vrs-pseq] registered with bus id 4-003c
[    5.046735] i2c i2c-4: of_i2c: register /bpmp/i2c/temp-sensor@4c
[    5.053017] i2c i2c-4: client [tmp451] registered with bus id 4-004c
[    5.059543] i2c i2c-4: of_i2c: register /bpmp/i2c/vrs11_1@20
[    5.065390] i2c i2c-4: client [vrs11] registered with bus id 4-0020
[    5.071813] i2c i2c-4: of_i2c: register /bpmp/i2c/vrs11_2@22
[    5.077656] i2c i2c-4: client [vrs11] registered with bus id 4-0022
[    9.456197] tegra-i2c 3160000.i2c: setting default prod
[    9.461599] tegra-i2c 3160000.i2c: setting prod: prod_c_fm
[    9.467281] tegra-i2c 3160000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[    9.479055] i2c-dev: adapter [3160000.i2c] registered as minor 0
[    9.485284] i2c i2c-0: adapter [3160000.i2c] registered
[    9.490676] i2c i2c-0: of_i2c: walking child nodes
[    9.496365] tegra-i2c c240000.i2c: setting default prod
[    9.501753] tegra-i2c c240000.i2c: setting prod: prod_c_sm
[    9.507406] tegra-i2c c240000.i2c: tlow 0x8, thigh 0x7, hs_tlow 0x8, hs_thigh 0x3, divisor 0x4f, divisor_hs 0x1
[    9.518769] i2c-dev: adapter [c240000.i2c] registered as minor 1
[    9.524968] i2c i2c-1: adapter [c240000.i2c] registered
[    9.530376] i2c i2c-1: of_i2c: walking child nodes
[    9.535326] i2c i2c-1: of_i2c: register /i2c@c240000/ina3221@40
[    9.541533] i2c i2c-1: client [ina3221] registered with bus id 1-0040
[    9.548171] i2c i2c-1: of_i2c: register /i2c@c240000/ina3221@41
[    9.554308] i2c i2c-1: client [ina3221] registered with bus id 1-0041
[    9.560949] i2c i2c-1: of_i2c: register /i2c@c240000/ucsi_ccg@8
[    9.567250] i2c i2c-1: client [ccgx-ucsi] registered with bus id 1-0008
[    9.575040] tegra-i2c 3180000.i2c: setting default prod
[    9.580432] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[    9.586106] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[    9.597514] i2c-dev: adapter [3180000.i2c] registered as minor 2
[    9.603705] i2c i2c-2: adapter [3180000.i2c] registered
[    9.609090] i2c i2c-2: of_i2c: walking child nodes
[    9.614038] i2c i2c-2: of_i2c: register /i2c@3180000/tca9546@70
[    9.637268] tegra-i2c 3180000.i2c: unmasked IRQ: 8c
[    9.642314] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[    9.648151] tegra-i2c 3180000.i2c: setting default prod
[    9.653530] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[    9.659178] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[    9.686519] i2c i2c-2: client [pca9546] registered with bus id 2-0070
[    9.693163] i2c i2c-2: of_i2c: register /i2c@3180000/tca9548@77
[    9.723453] tegra-i2c 3180000.i2c: unmasked IRQ: 8c
[    9.728492] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[    9.734328] tegra-i2c 3180000.i2c: setting default prod
[    9.739739] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[    9.745398] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[    9.766104] i2c i2c-2: client [pca9548] registered with bus id 2-0077
[    9.772741] i2c i2c-2: of_i2c: register /i2c@3180000/tca6408@21
[    9.786837] tegra-i2c 3180000.i2c: unmasked IRQ: 8c
[    9.791878] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[    9.797714] tegra-i2c 3180000.i2c: setting default prod
[    9.803096] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[    9.808743] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[    9.830453] i2c i2c-2: client [tca6408] registered with bus id 2-0021
[    9.837093] i2c i2c-2: of_i2c: register /i2c@3180000/ov5693_c@36
[    9.850567] i2c i2c-2: Failed to create I2C device for /i2c@3180000/ov5693_c@36
[    9.858131] i2c i2c-2: of_i2c: register /i2c@3180000/e2832@2b
[    9.871033] i2c i2c-2: Failed to create I2C device for /i2c@3180000/e2832@2b
[    9.879295] tegra-i2c 3190000.i2c: setting default prod
[    9.888271] tegra-i2c 3190000.i2c: setting prod: prod_c_sm
[    9.902342] tegra-i2c 3190000.i2c: tlow 0x8, thigh 0x7, hs_tlow 0x8, hs_thigh 0x3, divisor 0x4f, divisor_hs 0x1
[    9.930209] i2c-dev: adapter [3190000.i2c] registered as minor 3
[    9.940120] i2c i2c-3: adapter [3190000.i2c] registered
[    9.945501] i2c i2c-3: of_i2c: walking child nodes
[    9.946292] tegra-i2c 31b0000.i2c: setting default prod
[    9.960039] tegra-i2c 31b0000.i2c: setting prod: prod_c_sm
[    9.965705] tegra-i2c 31b0000.i2c: tlow 0x8, thigh 0x7, hs_tlow 0x8, hs_thigh 0x3, divisor 0x4f, divisor_hs 0x1
[    9.977036] i2c-dev: adapter [31b0000.i2c] registered as minor 5
[    9.983253] i2c i2c-5: adapter [31b0000.i2c] registered
[    9.988662] i2c i2c-5: of_i2c: walking child nodes
[    9.994319] tegra-i2c 31c0000.i2c: setting default prod
[    9.999705] tegra-i2c 31c0000.i2c: setting prod: prod_c_sm
[   10.005363] tegra-i2c 31c0000.i2c: tlow 0x8, thigh 0x7, hs_tlow 0x8, hs_thigh 0x3, divisor 0x4f, divisor_hs 0x1
[   10.017071] i2c-dev: adapter [31c0000.i2c] registered as minor 6
[   10.023270] i2c i2c-6: adapter [31c0000.i2c] registered
[   10.028652] i2c i2c-6: of_i2c: walking child nodes
[   10.035125] tegra-i2c c250000.i2c: setting default prod
[   10.046687] tegra-i2c c250000.i2c: setting prod: prod_c_fm
[   10.052341] tegra-i2c c250000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[   10.064066] i2c-dev: adapter [c250000.i2c] registered as minor 7
[   10.070264] i2c i2c-7: adapter [c250000.i2c] registered
[   10.075645] i2c i2c-7: of_i2c: walking child nodes
[   10.081421] tegra-i2c 31e0000.i2c: setting default prod
[   10.086809] tegra-i2c 31e0000.i2c: setting prod: prod_c_sm
[   10.092463] tegra-i2c 31e0000.i2c: tlow 0x8, thigh 0x7, hs_tlow 0x8, hs_thigh 0x3, divisor 0x4f, divisor_hs 0x1
[   10.103971] i2c-dev: adapter [31e0000.i2c] registered as minor 8
[   10.110222] i2c i2c-8: adapter [31e0000.i2c] registered
[   10.115642] i2c i2c-8: of_i2c: walking child nodes
[   15.314328] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.319375] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.325232] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   15.330267] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   15.336113] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.341149] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.346993] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.352029] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.357879] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.362914] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.368759] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   15.373796] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   15.373810] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.384681] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.384819] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.399067] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.399078] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   15.399387] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   15.415902] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.416293] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.426869] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   15.427260] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   15.437926] i2c-core: driver [ina3221] registered
[   16.214781] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.217558] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   16.226406] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.226807] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.235759] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.236157] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.238104] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.238502] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.580676] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.580886] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.580903] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   16.581222] tegra-i2c c240000.i2c: transfer complete: 24 0 0
[   16.581797] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.582233] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.609681] i2c-core: driver [nct1008_nct72] registered
[   16.980868] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.981302] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   16.981320] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.981853] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.981873] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.982244] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.982257] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   16.982602] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   16.982619] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.983048] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.993156] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.993483] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   16.993495] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   16.993892] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   16.993909] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   16.994327] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   17.005157] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   17.005494] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   17.005510] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   17.005895] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   17.005917] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   17.006344] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   17.006357] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   17.008785] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   17.008811] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   17.009134] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   17.009148] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   17.009906] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   17.009925] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   17.056115] i2c-core: driver [ucsi_ccg] registered
[   21.759878] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.760078] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.760090] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.760400] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.760474] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.760672] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.760684] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.760993] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.761042] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.761242] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.761256] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.761566] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.761653] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.761848] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.761860] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.762170] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.762266] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.762463] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.762475] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.762785] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.762848] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.763045] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.763057] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.763367] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.763425] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.763622] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.763634] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.763944] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.763995] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.764192] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.764204] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.764514] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.764612] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.764810] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.764823] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.765141] tegra-i2c c240000.i2c: transfer complete: 24 0 0
[   21.765251] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.765449] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.765462] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.765771] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.765856] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.766051] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.766064] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.766372] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.766430] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.766627] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.766640] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.766948] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.767182] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.767379] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.767392] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.767701] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.767763] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.767960] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.767972] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.768280] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.768351] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.768548] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[   21.768560] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.768869] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.768929] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[   21.769136] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   21.769149] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[   21.769457] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[   29.488092] i2c-dev: adapter [NVIDIA SOC i2c adapter 0] registered as minor 9
[   29.489794] i2c i2c-9: adapter [NVIDIA SOC i2c adapter 0] registered
[  440.288738] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[  440.289148] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[  440.290369] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[  440.290766] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[  440.295165] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[  440.295557] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[  440.296301] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[  440.296693] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[  440.320224] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[  440.320430] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[  440.320444] tegra-i2c c240000.i2c: unmasked IRQ: 8d
[  440.320756] tegra-i2c c240000.i2c: transfer complete: 25 0 0
[  440.321546] tegra-i2c c240000.i2c: unmasked IRQ: 8c
[  440.321942] tegra-i2c c240000.i2c: transfer complete: 26 0 0
[  450.384707] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffd8d77e58
[  450.384715] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.384718] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffd8d77d78
[  450.384738] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.384800] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.384809] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.384881] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.388991] i2c i2c-0: ioctl, cmd=0x705, arg=0xfffff52fb138
[  450.388997] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.389000] i2c i2c-0: ioctl, cmd=0x720, arg=0xfffff52fb058
[  450.389019] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.389086] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.389096] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.389345] tegra-i2c 3160000.i2c: transfer complete: 24 0 0
[  450.393433] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffdd87ab48
[  450.393439] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.393443] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffdd87aa68
[  450.393462] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.393528] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.393537] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.393603] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.398216] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffe3926108
[  450.398223] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.398227] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffe3926028
[  450.398252] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.398313] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.398323] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.398385] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.403324] i2c i2c-0: ioctl, cmd=0x705, arg=0xfffffd02ea38
[  450.403334] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.403341] i2c i2c-0: ioctl, cmd=0x720, arg=0xfffffd02e958
[  450.403368] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.403435] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.403448] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.403509] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.407521] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffe47f5408
[  450.407527] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.407531] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffe47f5328
[  450.407551] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.407616] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.407625] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.407688] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.411961] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffed201b08
[  450.411968] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.411972] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffed201a28
[  450.411991] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.412054] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.412063] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.412127] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.416311] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffe9bd4a78
[  450.416318] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.416322] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffe9bd4998
[  450.416340] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.416407] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.416416] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.416479] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.420191] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffd069a118
[  450.420197] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.420201] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffd069a038
[  450.420221] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.420287] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.420297] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.420363] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.424770] i2c i2c-0: ioctl, cmd=0x705, arg=0xfffffdbd9e98
[  450.424779] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.424783] i2c i2c-0: ioctl, cmd=0x720, arg=0xfffffdbd9db8
[  450.424817] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.424884] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.424894] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.424956] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.430880] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffe6efb428
[  450.430893] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.430899] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffe6efb348
[  450.430934] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.431008] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.431018] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.431085] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.435425] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffc687d0f8
[  450.435432] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.435436] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffc687d018
[  450.435461] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.435529] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.435539] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.435604] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.441193] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffc970bbd8
[  450.441200] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.441204] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffc970baf8
[  450.441228] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.441527] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.441542] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.441609] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.446346] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffc6662ea8
[  450.446357] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.446361] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffc6662dc8
[  450.446391] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.446454] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.446464] tegra-i2c 3160000.i2c: unmasked IRQ: 8d
[  450.446528] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[  450.451183] i2c i2c-0: ioctl, cmd=0x705, arg=0xffffcc1082f8
[  450.451192] i2c i2c-0: ioctl, cmd=0x706, arg=0x50
[  450.451196] i2c i2c-0: ioctl, cmd=0x720, arg=0xffffcc108218
[  450.451220] tegra-i2c 3160000.i2c: unmasked IRQ: 8c
[  450.451300] tegra-i2c 3160000.i2c: transfer complete: 25 0 0
[ 1154.566745] i2c i2c-2: ioctl, cmd=0x703, arg=0x22
[ 1154.566751] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.566765] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.566817] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.566834] tegra-i2c 3180000.i2c: setting default prod
[ 1154.566844] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.566850] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.567145] i2c i2c-2: ioctl, cmd=0x703, arg=0x23
[ 1154.567150] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.567164] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.567216] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.567237] tegra-i2c 3180000.i2c: setting default prod
[ 1154.567244] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.567251] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.567643] i2c i2c-2: ioctl, cmd=0x703, arg=0x24
[ 1154.567648] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.567661] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.567712] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.567729] tegra-i2c 3180000.i2c: setting default prod
[ 1154.567736] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.567742] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.568748] i2c i2c-2: ioctl, cmd=0x703, arg=0x25
[ 1154.568750] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.568761] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.568808] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.568835] tegra-i2c 3180000.i2c: setting default prod
[ 1154.568842] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.568847] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.569140] i2c i2c-2: ioctl, cmd=0x703, arg=0x26
[ 1154.569143] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.569154] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.569202] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.569216] tegra-i2c 3180000.i2c: setting default prod
[ 1154.569222] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.569227] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.569514] i2c i2c-2: ioctl, cmd=0x703, arg=0x27
[ 1154.569518] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.569530] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.569580] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.569598] tegra-i2c 3180000.i2c: setting default prod
[ 1154.569605] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.569612] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.570242] i2c i2c-2: ioctl, cmd=0x703, arg=0x28
[ 1154.570247] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.570261] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.570314] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.570331] tegra-i2c 3180000.i2c: setting default prod
[ 1154.570340] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.570352] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.570668] i2c i2c-2: ioctl, cmd=0x703, arg=0x29
[ 1154.570673] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.570686] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.570739] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.570756] tegra-i2c 3180000.i2c: setting default prod
[ 1154.570763] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.570769] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.571076] i2c i2c-2: ioctl, cmd=0x703, arg=0x2a
[ 1154.571082] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.571094] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.571146] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.571162] tegra-i2c 3180000.i2c: setting default prod
[ 1154.571170] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.571176] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.571488] i2c i2c-2: ioctl, cmd=0x703, arg=0x2b
[ 1154.571493] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.571506] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.571558] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.571574] tegra-i2c 3180000.i2c: setting default prod
[ 1154.571582] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.571588] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.571892] i2c i2c-2: ioctl, cmd=0x703, arg=0x2c
[ 1154.571897] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.571911] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.571962] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.571979] tegra-i2c 3180000.i2c: setting default prod
[ 1154.571986] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.571992] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.572352] i2c i2c-2: ioctl, cmd=0x703, arg=0x2d
[ 1154.572357] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.572370] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.572422] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.572438] tegra-i2c 3180000.i2c: setting default prod
[ 1154.572445] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.572451] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.573383] i2c i2c-2: ioctl, cmd=0x703, arg=0x2e
[ 1154.573402] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.573426] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.573483] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.573505] tegra-i2c 3180000.i2c: setting default prod
[ 1154.573514] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.573524] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.573843] i2c i2c-2: ioctl, cmd=0x703, arg=0x2f
[ 1154.573849] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.573864] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.573918] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.573935] tegra-i2c 3180000.i2c: setting default prod
[ 1154.573943] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.573950] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.574272] i2c i2c-2: ioctl, cmd=0x703, arg=0x30
[ 1154.574277] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.574292] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.574344] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.574361] tegra-i2c 3180000.i2c: setting default prod
[ 1154.574368] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.574375] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.574680] i2c i2c-2: ioctl, cmd=0x703, arg=0x31
[ 1154.574685] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.574699] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.574751] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.574768] tegra-i2c 3180000.i2c: setting default prod
[ 1154.574776] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.574783] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.575084] i2c i2c-2: ioctl, cmd=0x703, arg=0x32
[ 1154.575089] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.575102] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.575153] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.575170] tegra-i2c 3180000.i2c: setting default prod
[ 1154.575178] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.575185] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.575481] i2c i2c-2: ioctl, cmd=0x703, arg=0x33
[ 1154.575486] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.575499] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.575550] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.575567] tegra-i2c 3180000.i2c: setting default prod
[ 1154.575575] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.575582] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.575892] i2c i2c-2: ioctl, cmd=0x703, arg=0x34
[ 1154.575897] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.575910] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.575962] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.575981] tegra-i2c 3180000.i2c: setting default prod
[ 1154.575989] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.575995] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.576866] i2c i2c-2: ioctl, cmd=0x703, arg=0x35
[ 1154.576879] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.576902] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.576950] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.576969] tegra-i2c 3180000.i2c: setting default prod
[ 1154.576979] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.576989] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.577669] i2c i2c-2: ioctl, cmd=0x703, arg=0x36
[ 1154.577672] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.577682] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.577729] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.577744] tegra-i2c 3180000.i2c: setting default prod
[ 1154.577750] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.577754] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.578040] i2c i2c-2: ioctl, cmd=0x703, arg=0x37
[ 1154.578043] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.578053] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.578100] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.578114] tegra-i2c 3180000.i2c: setting default prod
[ 1154.578120] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.578124] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.578471] i2c i2c-2: ioctl, cmd=0x703, arg=0x38
[ 1154.578475] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.578487] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.578537] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.578553] tegra-i2c 3180000.i2c: setting default prod
[ 1154.578560] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.578567] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.578864] i2c i2c-2: ioctl, cmd=0x703, arg=0x39
[ 1154.578873] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.578885] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.578935] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.578950] tegra-i2c 3180000.i2c: setting default prod
[ 1154.578957] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.578962] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.579262] i2c i2c-2: ioctl, cmd=0x703, arg=0x3a
[ 1154.579266] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.579278] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.579328] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.579344] tegra-i2c 3180000.i2c: setting default prod
[ 1154.579351] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.579356] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.579764] i2c i2c-2: ioctl, cmd=0x703, arg=0x3b
[ 1154.579768] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.579780] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.579831] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.579853] tegra-i2c 3180000.i2c: setting default prod
[ 1154.579860] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.579865] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.580161] i2c i2c-2: ioctl, cmd=0x703, arg=0x3c
[ 1154.580170] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.580182] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.580233] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.580249] tegra-i2c 3180000.i2c: setting default prod
[ 1154.580256] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.580261] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.580557] i2c i2c-2: ioctl, cmd=0x703, arg=0x3d
[ 1154.580561] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.580573] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.580624] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.580640] tegra-i2c 3180000.i2c: setting default prod
[ 1154.580647] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.580652] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.581762] i2c i2c-2: ioctl, cmd=0x703, arg=0x3e
[ 1154.581768] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.581780] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.581832] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.581848] tegra-i2c 3180000.i2c: setting default prod
[ 1154.581855] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.581861] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.582163] i2c i2c-2: ioctl, cmd=0x703, arg=0x3f
[ 1154.582168] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.582180] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.582230] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.582246] tegra-i2c 3180000.i2c: setting default prod
[ 1154.582253] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.582259] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.582559] i2c i2c-2: ioctl, cmd=0x703, arg=0x40
[ 1154.582563] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.582575] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.582627] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.582643] tegra-i2c 3180000.i2c: setting default prod
[ 1154.582650] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.582655] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.582945] i2c i2c-2: ioctl, cmd=0x703, arg=0x41
[ 1154.582948] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.582960] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.583010] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.583026] tegra-i2c 3180000.i2c: setting default prod
[ 1154.583032] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.583038] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.583529] i2c i2c-2: ioctl, cmd=0x703, arg=0x42
[ 1154.583534] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.583546] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.583595] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.583611] tegra-i2c 3180000.i2c: setting default prod
[ 1154.583618] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.583623] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.583910] i2c i2c-2: ioctl, cmd=0x703, arg=0x43
[ 1154.583914] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.583925] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.583975] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.583990] tegra-i2c 3180000.i2c: setting default prod
[ 1154.583997] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.584002] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.584385] i2c i2c-2: ioctl, cmd=0x703, arg=0x44
[ 1154.584388] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.584399] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.584449] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.584465] tegra-i2c 3180000.i2c: setting default prod
[ 1154.584472] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.584477] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.584771] i2c i2c-2: ioctl, cmd=0x703, arg=0x45
[ 1154.584775] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.584787] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.584851] tegra-i2c 3180000.i2c: transfer complete: 24 0 1
[ 1154.584877] tegra-i2c 3180000.i2c: setting default prod
[ 1154.584894] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.584909] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.585594] i2c i2c-2: ioctl, cmd=0x703, arg=0x46
[ 1154.585599] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.585612] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.585666] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.585682] tegra-i2c 3180000.i2c: setting default prod
[ 1154.585689] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.585693] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.586438] i2c i2c-2: ioctl, cmd=0x703, arg=0x47
[ 1154.586443] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.586454] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.586503] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.586519] tegra-i2c 3180000.i2c: setting default prod
[ 1154.586525] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.586529] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.586897] i2c i2c-2: ioctl, cmd=0x703, arg=0x48
[ 1154.586900] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.586911] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.586961] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.586976] tegra-i2c 3180000.i2c: setting default prod
[ 1154.586982] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.586986] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.587473] i2c i2c-2: ioctl, cmd=0x703, arg=0x49
[ 1154.587482] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.587498] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.587551] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.587568] tegra-i2c 3180000.i2c: setting default prod
[ 1154.587575] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.587580] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.587887] i2c i2c-2: ioctl, cmd=0x703, arg=0x4a
[ 1154.587891] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.587904] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.587955] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.587971] tegra-i2c 3180000.i2c: setting default prod
[ 1154.587977] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.587983] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.588331] i2c i2c-2: ioctl, cmd=0x703, arg=0x4b
[ 1154.588336] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.588348] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.588398] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.588413] tegra-i2c 3180000.i2c: setting default prod
[ 1154.588420] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.588426] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.588725] i2c i2c-2: ioctl, cmd=0x703, arg=0x4c
[ 1154.588728] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.588740] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.588790] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.588805] tegra-i2c 3180000.i2c: setting default prod
[ 1154.588812] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.588818] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.589217] i2c i2c-2: ioctl, cmd=0x703, arg=0x4d
[ 1154.589221] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.589233] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.589284] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.589301] tegra-i2c 3180000.i2c: setting default prod
[ 1154.589307] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.589312] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.589786] i2c i2c-2: ioctl, cmd=0x703, arg=0x4e
[ 1154.589794] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.589810] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.589864] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.589880] tegra-i2c 3180000.i2c: setting default prod
[ 1154.589886] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.589890] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.590185] i2c i2c-2: ioctl, cmd=0x703, arg=0x4f
[ 1154.590188] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.590199] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.590248] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.590263] tegra-i2c 3180000.i2c: setting default prod
[ 1154.590269] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.590274] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.590977] i2c i2c-2: ioctl, cmd=0x703, arg=0x50
[ 1154.590980] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.590990] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.591041] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.591056] tegra-i2c 3180000.i2c: setting default prod
[ 1154.591062] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.591066] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.591429] i2c i2c-2: ioctl, cmd=0x703, arg=0x51
[ 1154.591432] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.591443] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.591491] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.591510] tegra-i2c 3180000.i2c: setting default prod
[ 1154.591516] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.591521] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.591837] i2c i2c-2: ioctl, cmd=0x703, arg=0x52
[ 1154.591840] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.591852] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.591899] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.591915] tegra-i2c 3180000.i2c: setting default prod
[ 1154.591922] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.591927] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.592216] i2c i2c-2: ioctl, cmd=0x703, arg=0x53
[ 1154.592219] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.592230] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.592278] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.592293] tegra-i2c 3180000.i2c: setting default prod
[ 1154.592300] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.592304] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.592751] i2c i2c-2: ioctl, cmd=0x703, arg=0x54
[ 1154.592754] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.592768] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.592816] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.592871] tegra-i2c 3180000.i2c: setting default prod
[ 1154.592884] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.592893] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.593555] i2c i2c-2: ioctl, cmd=0x703, arg=0x55
[ 1154.593560] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.593571] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.593623] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.593640] tegra-i2c 3180000.i2c: setting default prod
[ 1154.593647] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.593651] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.594064] i2c i2c-2: ioctl, cmd=0x703, arg=0x56
[ 1154.594071] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.594100] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.594145] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.594160] tegra-i2c 3180000.i2c: setting default prod
[ 1154.594166] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.594172] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.594480] i2c i2c-2: ioctl, cmd=0x703, arg=0x57
[ 1154.594484] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.594496] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.594543] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.594558] tegra-i2c 3180000.i2c: setting default prod
[ 1154.594564] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.594569] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.594850] i2c i2c-2: ioctl, cmd=0x703, arg=0x58
[ 1154.594854] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.594865] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.594914] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.594929] tegra-i2c 3180000.i2c: setting default prod
[ 1154.594935] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.594940] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.595539] i2c i2c-2: ioctl, cmd=0x703, arg=0x59
[ 1154.595541] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.595551] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.595599] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.595613] tegra-i2c 3180000.i2c: setting default prod
[ 1154.595620] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.595624] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.596052] i2c i2c-2: ioctl, cmd=0x703, arg=0x5a
[ 1154.596055] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.596065] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.596113] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.596130] tegra-i2c 3180000.i2c: setting default prod
[ 1154.596136] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.596141] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.596426] i2c i2c-2: ioctl, cmd=0x703, arg=0x5b
[ 1154.596429] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.596439] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.596488] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.596503] tegra-i2c 3180000.i2c: setting default prod
[ 1154.596509] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.596513] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.596792] i2c i2c-2: ioctl, cmd=0x703, arg=0x5c
[ 1154.596794] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.596804] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.596856] tegra-i2c 3180000.i2c: transfer complete: 24 0 1
[ 1154.596872] tegra-i2c 3180000.i2c: setting default prod
[ 1154.596878] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.596882] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.597591] i2c i2c-2: ioctl, cmd=0x703, arg=0x5d
[ 1154.597595] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.597606] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.597654] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.597670] tegra-i2c 3180000.i2c: setting default prod
[ 1154.597676] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.597681] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.598241] i2c i2c-2: ioctl, cmd=0x703, arg=0x5e
[ 1154.598249] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.598261] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.598311] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.598326] tegra-i2c 3180000.i2c: setting default prod
[ 1154.598332] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.598337] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.598644] i2c i2c-2: ioctl, cmd=0x703, arg=0x5f
[ 1154.598647] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.598657] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.598705] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.598720] tegra-i2c 3180000.i2c: setting default prod
[ 1154.598726] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.598730] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.599020] i2c i2c-2: ioctl, cmd=0x703, arg=0x60
[ 1154.599023] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.599033] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.599081] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.599096] tegra-i2c 3180000.i2c: setting default prod
[ 1154.599102] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.599106] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.599384] i2c i2c-2: ioctl, cmd=0x703, arg=0x61
[ 1154.599387] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.599397] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.599445] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.599460] tegra-i2c 3180000.i2c: setting default prod
[ 1154.599466] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.599471] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.599808] i2c i2c-2: ioctl, cmd=0x703, arg=0x62
[ 1154.599810] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.599821] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.599869] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.599884] tegra-i2c 3180000.i2c: setting default prod
[ 1154.599891] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.599895] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.600533] i2c i2c-2: ioctl, cmd=0x703, arg=0x63
[ 1154.600535] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.600545] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.600593] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.600608] tegra-i2c 3180000.i2c: setting default prod
[ 1154.600614] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.600618] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.601098] i2c i2c-2: ioctl, cmd=0x703, arg=0x64
[ 1154.601101] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.601112] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.601162] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.601177] tegra-i2c 3180000.i2c: setting default prod
[ 1154.601183] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.601187] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.601476] i2c i2c-2: ioctl, cmd=0x703, arg=0x65
[ 1154.601478] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.601488] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.601705] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.601722] tegra-i2c 3180000.i2c: setting default prod
[ 1154.601751] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.601758] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.602099] i2c i2c-2: ioctl, cmd=0x703, arg=0x66
[ 1154.602122] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.602173] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.602221] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.602236] tegra-i2c 3180000.i2c: setting default prod
[ 1154.602242] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.602247] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.602592] i2c i2c-2: ioctl, cmd=0x703, arg=0x67
[ 1154.602596] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.602608] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.602656] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.602687] tegra-i2c 3180000.i2c: setting default prod
[ 1154.602694] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.602699] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.603000] i2c i2c-2: ioctl, cmd=0x703, arg=0x68
[ 1154.603006] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.603020] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.603070] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.603085] tegra-i2c 3180000.i2c: setting default prod
[ 1154.603091] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.603096] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.603374] i2c i2c-2: ioctl, cmd=0x703, arg=0x69
[ 1154.603377] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.603389] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.603436] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.603451] tegra-i2c 3180000.i2c: setting default prod
[ 1154.603457] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.603461] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.603744] i2c i2c-2: ioctl, cmd=0x703, arg=0x6a
[ 1154.603746] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.603757] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.603804] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.603819] tegra-i2c 3180000.i2c: setting default prod
[ 1154.603825] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.603830] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.604108] i2c i2c-2: ioctl, cmd=0x703, arg=0x6b
[ 1154.604110] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.604120] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.604169] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.604183] tegra-i2c 3180000.i2c: setting default prod
[ 1154.604189] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.604193] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.604468] i2c i2c-2: ioctl, cmd=0x703, arg=0x6c
[ 1154.604470] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.604481] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.604528] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.604542] tegra-i2c 3180000.i2c: setting default prod
[ 1154.604549] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.604556] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.604845] i2c i2c-2: ioctl, cmd=0x703, arg=0x6d
[ 1154.604848] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.604862] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.604910] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.604927] tegra-i2c 3180000.i2c: setting default prod
[ 1154.604935] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.604940] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.605672] i2c i2c-2: ioctl, cmd=0x703, arg=0x6e
[ 1154.605677] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.605689] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.605739] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.605755] tegra-i2c 3180000.i2c: setting default prod
[ 1154.605762] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.605766] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.606060] i2c i2c-2: ioctl, cmd=0x703, arg=0x6f
[ 1154.606063] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.606074] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.606122] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.606137] tegra-i2c 3180000.i2c: setting default prod
[ 1154.606143] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.606147] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.606455] i2c i2c-2: ioctl, cmd=0x703, arg=0x70
[ 1154.606460] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.606472] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.606521] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.606537] tegra-i2c 3180000.i2c: setting default prod
[ 1154.606543] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.606548] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.606834] i2c i2c-2: ioctl, cmd=0x703, arg=0x71
[ 1154.606837] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.606848] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.606896] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.606911] tegra-i2c 3180000.i2c: setting default prod
[ 1154.606917] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.606921] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.607211] i2c i2c-2: ioctl, cmd=0x703, arg=0x72
[ 1154.607214] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.607224] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.607272] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.607287] tegra-i2c 3180000.i2c: setting default prod
[ 1154.607293] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.607297] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.607588] i2c i2c-2: ioctl, cmd=0x703, arg=0x73
[ 1154.607590] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.607601] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.607648] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.607663] tegra-i2c 3180000.i2c: setting default prod
[ 1154.607669] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.607673] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.607951] i2c i2c-2: ioctl, cmd=0x703, arg=0x74
[ 1154.607953] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.607963] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.608011] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.608025] tegra-i2c 3180000.i2c: setting default prod
[ 1154.608032] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.608036] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.608311] i2c i2c-2: ioctl, cmd=0x703, arg=0x75
[ 1154.608313] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.608323] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.608382] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.608424] tegra-i2c 3180000.i2c: setting default prod
[ 1154.608430] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.608435] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.608878] i2c i2c-2: ioctl, cmd=0x703, arg=0x76
[ 1154.608883] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.608898] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.608947] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.608962] tegra-i2c 3180000.i2c: setting default prod
[ 1154.608969] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.608975] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1154.609276] i2c i2c-2: ioctl, cmd=0x703, arg=0x77
[ 1154.609279] i2c i2c-2: ioctl, cmd=0x720, arg=0xffffdcc760b8
[ 1154.609289] tegra-i2c 3180000.i2c: unmasked IRQ: 8d
[ 1154.609337] tegra-i2c 3180000.i2c: transfer complete: 25 0 1
[ 1154.609351] tegra-i2c 3180000.i2c: setting default prod
[ 1154.609357] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 1154.609362] tegra-i2c 3180000.i2c: tlow 0x2, thigh 0x2, hs_tlow 0x8, hs_thigh 0x3, divisor 0x3c, divisor_hs 0x1
[ 1437.152986] i2c-core: driver [imx390] registered
Why there is no i2c registration process ? I can’t find any i2c bus regarding to i2c-30 and that’s weird in fact that the DT is implemented.
Thank you for your support
hello chakibdace,
there should be an issue, because we by default using i2c bus multiplexer/switch, i.e. pca9546 i2c mux
please dig into your product design, for example, have you providing regulator settings correctly?
Hello @JerryChang
It’s weird in fact that when i dont enable imx390, probing pca954x doesn’t fail, but i dunno why the DT doesn’t create i2c nodes neither video channels, do you have any idea how to create the /dev/video0 … ?
as I mentioned, it’ll register the device to sysfs as video node without errors.
