please check the sensor specification, you may expect the active pixels as your actual frame-size.
you could dump the VI registers to check the signaling reporting. please also refer to TRM for descriptions.
for example, VI_CSI_0_CSI_IMAGE_SIZE_0.
that’s not correct,
TX1 and Nano were sharing same VI driver.
you could also refer to Nano’s reference driver as below which using embedded_metadata_height.
for example,
