I have custom carrier board NANO.
I am trying to mount an IMX477 on the board.
L4T is 32.5.
An error is displayed when the following command is executed.
nvidia@linux:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)4056, height=(int)3040, framerate=15/1' ! nvvidconv flip-method=0 ! 'video/x-raw, format=(string)I420' ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4032 x 3040 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 11000, max 500000000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 11000, max 500000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 4032 H = 3040
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:04.120661421
Setting pipeline to READY ...
(gst-launch-1.0:15980): GStreamer-CRITICAL **: 05:41:14.982: gst_mini_object_set_qdata: assertion 'object != NULL' failed
GST_ARGUS: Cleaning up
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
Setting pipeline to NULL ...
Freeing pipeline ...
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
nvidia@linux:~$
There is also a large number of kernel error messages.
[ 68.530994] host1x 50000000.host1x: cdma_handle_timeout: timeout: 34 (54080000.vi_1) client 10, HW thresh 0, done 1
[ 68.541499] host1x 50000000.host1x: cdma_handle_timeout: timeout: 38 (54080000.vi_4) client 10, HW thresh 0, done 1
[ 68.566986] host1x 50000000.host1x: cdma_handle_timeout: timeout: 35 (54080000.vi_2) client 10, HW thresh 2, done 2
error.log (111.5 KB)
IMX477 and I2C communication is normal.
Is there any way to debug it? (HW/SW)
help is appreciated.
