Hello NVIDIA Community,
I am facing a persistent and challenging issue with my Jetson Orin Nano developer kit and an IMX477 CSI camera. My goal is to run the device in a headless configuration for an RTSP streaming application, but the camera fails to initialize reliably once I move away from using a physical display.
I would be very grateful for any insights or solutions.
System & Hardware Information:
- Device: Jetson Orin Nano Developer Kit
- JetPack Version: JetPack 6.2.1
- Camera: IMX477 CSI Camera Module
- Goal: Operate in headless mode, capture from IMX477 using
nvarguscamerasrc, and stream via RTSP. Remote access for development is handled via VNC.
The Problem in Detail:
1. Baseline Success:
When the Jetson Orin Nano is connected to a physical DP monitor, everything works perfectly. I can open a terminal and run GStreamer pipelines with nvarguscamerasrc, and the IMX477 camera feed displays correctly.
2. The Headless Mode Failure:
The problems begin as soon as I attempt to configure the system for headless operation. My core requirement is to have remote desktop access for development and debugging.
Attempt 1: Installing VNC Server (TigerVNC + XFCE4)
- I disconnected the monitor and configured the system for SSH access.
- I installed
tigervnc-standalone-serverand thexfce4desktop environment, configuring it to start a VNC session on boot via asystemdservice. - Result: This change seems to have broken the camera functionality. After installing and enabling the VNC server, the camera no longer works.
nvarguscamerasrcfails with errors. Critically, even reconnecting the physical DP monitor does not fix the issue at this point. The system seems to be in a state where the camera driver ornvargus-daemoncan no longer initialize the sensor.
Attempt 2: Forcing a Virtual Display with
xorg.conf- Based on research suggesting
nvargus-daemonrequires an active X display, I tried a different approach. I reverted the changes from Attempt 1. - I created a custom
/etc/X11/xorg.conffile to force the NVIDIA driver to initialize a virtual display (e.g., 1920x1080) on boot, even without a monitor attached. - I then used
x11vncto share this existing X session (:0) for remote access. - Result: While I could successfully connect to the VNC session, the camera still failed to initialize. The errors are very similar to what I encountered before.
It appears that any deviation from the standard “boot with a physical monitor plugged in” configuration leads to a state where the Argus stack cannot open the IMX477 sensor.
Logs and Diagnostics:
Here are the critical logs I’ve captured during these failures. They appear consistently across my headless attempts.
1. nvargus-daemon.service Status and Logs:
This log shows that the daemon is running, but it fails to initialize the sensor driver. The key errors are Unable to initialize driver v4l2_sensor and Sensor could not be opened.
jetson@ubuntu:~$ systemctl status nvargus-daemon.service
● nvargus-daemon.service - Argus daemon
Loaded: loaded (/etc/systemd/system/nvargus-daemon.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2025-07-31 15:47:42 CST; 3min 45s ago
Main PID: 799 (nvargus-daemon)
Tasks: 1 (limit: 8809)
CGroup: /system.slice/nvargus-daemon.service
└─799 /usr/sbin/nvargus-daemon
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: NvPclStartPlatformDrivers: Failed to start module drivers
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: NvPclOpen: PCL Open Failed. Error: 0xf
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, fu>
Jul 31 15:50:15 ubuntu nvargus-daemon[799]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(),>
2. GStreamer Command Output:
When I run a basic GStreamer pipeline, it fails with a BadParameter error, which seems to be a direct result of the nvargus-daemon failure.
jetson@ubuntu:~$ gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! autovideosink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Got context from element 'autovideosink0': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayX11\)\ gldisplayx11-0";
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 93)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:318 Failed to create FrameConsumer
Got EOS from element "pipeline0".
Execution ended after 0:00:00.106832534
Setting pipeline to NULL ...
My Core Question:
What is the officially supported and reliable method to use a CSI camera (specifically IMX477) with nvarguscamerasrc on a Jetson Orin Nano in a truly headless environment?
It seems there’s a deep dependency on the display server’s state at boot time that is not being met by virtual display or standard VNC setups. Is there a specific configuration for nvargus-daemon, the device tree, or the kernel that is required for this use case?
Thank you for your time and assistance.
