Here’s the working change. Need modify the pix_clk_hz too.
iff --git a/common/tegra194-camera-jakku-rbpcv3-imx477.dtsi b/common/tegra194-camera-jakku-rbpcv3-imx477.dtsi
index 2cc928e..03fe85d 100644
--- a/common/tegra194-camera-jakku-rbpcv3-imx477.dtsi
+++ b/common/tegra194-camera-jakku-rbpcv3-imx477.dtsi
@@ -27,13 +27,13 @@
#address-cells = <1>;
#size-cells = <0>;
mux-gpios = <&tegra_aon_gpio CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
- i2c-parent = <&i2c7>;
+ i2c-parent = <&cam_i2c>;
i2c@0 {
reg = <0>;
#size-cells = <0>;
rbpcv3_imx477_a@1a {
- status = "disabled";
+ status = "okay";
reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
@@ -42,7 +42,7 @@
#size-cells = <0>;
rbpcv3_imx477_c@1a {
+ status = "okay";
reset-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
diff --git a/common/tegra194-camera-rbpcv3-imx477.dtsi b/common/tegra194-camera-rbpcv3-imx477.dtsi
index 8b7b1c6..fb5f076 100644
--- a/common/tegra194-camera-rbpcv3-imx477.dtsi
+++ b/common/tegra194-camera-rbpcv3-imx477.dtsi
@@ -16,34 +16,34 @@
- host1x {
- vi@15c10000 {
- num-channels = <2>;
- ports {
- #address-cells = <1>;
- #size-cells = <0>;
- port@0 {
- reg = <0>;
- rbpcv3_imx477_vi_in0: endpoint {
- port-index = <0>;
- bus-width = <2>;
- remote-endpoint = <&rbpcv3_imx477_csi_out0>;
+ tegra-capture-vi {
+ num-channels = <2>;
+ ports {
+ #address-cells = <1>;
+ #size-cells = <0>;
+ port@0 {
+ reg = <0>;
+ rbpcv3_imx477_vi_in0: endpoint {
+ port-index = <0>;
+ bus-width = <2>;
+ remote-endpoint = <&rbpcv3_imx477_csi_out0>;
- port@1 {
- reg = <1>;
- rbpcv3_imx477_vi_in1: endpoint {
- port-index = <4>;
- bus-width = <2>;
- remote-endpoint = <&rbpcv3_imx477_csi_out1>;
+ port@1 {
+ reg = <1>;
+ rbpcv3_imx477_vi_in1: endpoint {
+ port-index = <4>;
+ bus-width = <2>;
+ remote-endpoint = <&rbpcv3_imx477_csi_out1>;
- nvcsi@15a00000 {
+ host1x@13e00000 {
+ nvcsi@15a00000 {
#size-cells = <0>;
channel@0 {
reg = <0>;
@@ -207,7 +207,7 @@
line_length = "11200";
inherent_gain = "1";
mclk_multiplier = "80";
- pix_clk_hz = "840000000";
+ pix_clk_hz = "300000000";
gain_factor = "16";
framerate_factor = "1000000";
@@ -247,7 +247,7 @@
line_length = "7000";
gain_factor = "16";
@@ -320,7 +320,7 @@
gain_factor = "16";
@@ -360,7 +360,7 @@
gain_factor = "16";
diff --git a/common/tegra194-p3509-0000-a00.dtsi b/common/tegra194-p3509-0000-a00.dtsi
index 6f411e3..10cd7bf 100644
--- a/common/tegra194-p3509-0000-a00.dtsi
+++ b/common/tegra194-p3509-0000-a00.dtsi
@@ -17,7 +17,6 @@
#include "tegra194-audio-p3668.dtsi"
#include "tegra194-super-module-e2614-p3509.dtsi"
#include "tegra194-camera-jakku-rbpcv3-imx477.dtsi"
-#include "tegra194-camera-jakku-rbpcv2-imx219.dtsi"
gpio-keys {
compatible = "gpio-keys";
