Hello everyone,
I have an imx678 and I would like to use the DOL-HDR.
I modified the .dts file but it appears that my short exposure image and my long exposure image are vertically shifted when they are merged together by the Nvidia ISP.
Here is my device tree :
mode1 {/*mode imx678_MODE_3840X2160_DOL_7FPS*/
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
mode_type = "bayer_wdr_dol";
pixel_phase = "rggb";
active_w = "3872";
active_h = "4480";
readout_orientation = "0";
line_length = "6280";
inherent_gain = "1";
pix_clk_hz = "288000000";
serdes_pix_clk_hz = "480000000";
mclk_multiplier = "4.27";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "300"; /* 30dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "16";
max_hdr_ratio = "16";
framerate_factor = "1000000";
min_framerate = "7000000"; /* 4 */
max_framerate = "7000000"; /* 30 */
step_framerate = "1";
default_framerate= "7000000";
exposure_factor = "1000000";
min_exp_time = "15"; /* us */ /* 2line */
max_exp_time = "39000"; /* us */
step_exp_time = "1";
default_exp_time = "30000";/* us */
embedded_metadata_height = "0";
num_of_exposure = "2";
num_of_ignored_lines = "50";
num_of_lines_offset_0 = "30";
num_of_ignored_pixels = "16";
num_of_left_margin_pixels = "8";
num_of_right_margin_pixels = "8";
I modified “number_of_lines_offset_0” to realign my images because the documentation states that it represent the VBP, and the shift corresponds to the VBP value of the IMX678 datasheet. This did not have any effect, even though I tried multiple values.
Finally, “number_of_lines_offset_0” seems to be parsed, since I also have to change “active_h” when I change it.
