IMX708 video recording error
Hi all,
I attempted to record a video from the IMX708 sensor (Raspberry Pi v3 camera) using Jetson Nano (not the orin Nano). I have successfully captured images from the sensor using the drivers from RidgeRun.
However, I am encountering an error when trying to record a video, and I’m unable to find a solution. The error message is as follows:
_ValidateEncodeParams: Invalid encode width
I tried a very basic example pipeline form RidgeRun, so I don’t think the pipeline itself is the issue. I’m seeking advice on how to resolve this problem. Any assistance would be greatly appreciated.
pipeline:
SENSOR_ID=0 # 0 for CAM0 port
FRAMERATE=14 # Framerate can go from 2 to 14 for 4608x2592 mode
gst-launch-1.0 -e nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=4608,height=2592,framerate=$FRAMERATE/1" ! nvv4l2h264enc ! h264parse ! mp4mux ! filesink location=rpi_v3_imx708_cam$SENSOR_ID.mp4
Error:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4608 x 2592 FR = 14.000001 fps Duration = 71428568 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 500000, max 65487000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 4608 H = 2592
   seconds to Run    = 0
   Frame Rate = 14.000001
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
H264: Profile = 66, Level = 0
tvmrVideoEncoderBitsAvailable_MSENC: ucode ERROR = 16
NvVideoEncTransferOutputBufferToBlock: DoWork failed line# 674
NvVideoEnc: NvVideoEncTransferOutputBufferToBlock TransferBufferToBlock failed Line=685
Can you try adding format to the camera caps and changing the encode
SENSOR_ID=0
FRAMERATE=14
gst-launch-1.0 -e nvarguscamerasrc sensor_id=$SENSOR_ID ! 'video/x-raw(memory:NVMM),width=4608,height=2592,framerate=$FRAMERATE/1, format=NV12' ! nvvidconv ! "video/x-raw,width=1920,height=1080" ! x264enc ! qtmux ! filesink location=RidgeRun_out.mp4
if this doesn’t work, please try
gst-launch-1.0 nvarguscamerasrc sensor_id=$SENSOR_ID -e ! 'video/x-raw(memory:NVMM),width=4608,height=2592,framerate=$FRAMERATE/1, format=NV12' ! fakesink
Hi ManuelLeiva.
The first pipeline perfectly worked!
But now I encountered another issue I cannot record the video while displaying the video stream.
I will open another topic.
Thank you for your help.
Great!
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Thank you so much.
If it’s okay, please also take a look at the following topic.
