Hi,guys:
I get the following error when using the sklearn library in the container “nvcr.io/nvidia/pytorch:21.03-py3”:
<ModuleNotFoundError: No module named ‘sklearn.metrics.base’>
I looked for a solution in Google but failed.Any idea?Thansk.
Hi,guys:
The “ModuleNotFoundError: No module named ‘sklearn’” error occurs in Python when you try to import the ‘sklearn’ module, which is part of the scikit-learn library, but Python cannot find it in your current environment. To fix this, you need to install scikit-learn using a package manager like pip. Open your terminal or command prompt and run the following command: pip install scikit-learn. This will download and install the scikit-learn library, allowing you to import and use it in your Python scripts. Make sure you have a working Python environment set up and that pip is properly configured to install packages.
