**• Hardware Platform (Jetson / GPU)**GPU docker • DeepStream Version5.x/6.0 • TensorRT Version7.0/8.0
**• NVIDIA GPU Driver Version (valid for GPU only)**440.33/440.33
**• Issue Type( questions, new requirements, bugs)**bugs • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) deepstream_lpr_app
The attribute information of the vehicle corresponding to the license plate can be obtained from the obj_meta->parent structure
In deepstream-5.x, obj_meta->parent is not empty (!=NULL)
In deepstream-6.0, obj_meta->parent is empty (=NULL)
Why is this the case? How to solve it?
For example, in the DS5 version, after placing the probe in the sink of nvosd, the attribute data of the license plate can be obtained. But in DS6 version, same operation, obj_meta->parent is empty (=NULL). So I can only put the probe in the src pad of secondary_classifier, obj_meta->parent is not empty (!=NULL). why?
