in deepstream 6.2, use nvdeepsort can not detect good, in source/tracker_NvDeepSORT/data/ add picture is it necessary?The required image format is 12864, but in file the pic is 64128, how can i do , please
I is download mars-small128.pt , then convert.py convert it to mars-small128.uff_b100_gpu0_int8.engine.
• JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
# Package would be ignored #
Python recognizes 'pycuda.cuda' as an importable package,
but it is not listed in the `packages` configuration of setuptools.
'pycuda.cuda' has been automatically added to the distribution only
because it may contain data files, but this behavior is likely to change
in future versions of setuptools (and therefore is considered deprecated).
Please make sure that 'pycuda.cuda' is included as a package by using
the `packages` configuration field or the proper discovery methods
(for example by using `find_namespace_packages(...)`/`find_namespace:`
instead of `find_packages(...)`/`find:`).
You can read more about "package discovery" and "data files" on setuptools
documentation page.
check.warn(importable)
error: command '/usr/bin/aarch64-linux-gnu-gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for pycuda
Failed to build pycuda
ERROR: Could not build wheels for pycuda, which is required to install pyproject.toml-based projects
Please refer the readme: /opt/nvidia/deepstream/deepstream-6.2/sources/tracker_NvDeepSORT/README
