In Deepstream config file uri='RTSP URI'
• Hardware Platform (Jetson / GPU) GPU 3070
• DeepStream Version 5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 525
my rtsp uri = rtsp://user:1234@192.168.123.108:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
i try gst-launch-1.0 rtspsrc location=rtsp://user:1234@192.168.123.108:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif ! fakesink
Progress: (connect) Connecting to rtsp://user:1234@192.168.123.108:554/cam/realmonitor?channel=1
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading.
Additional debug info:
gstrtspsrc.c(5829): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
No supported authentication protocol was found
but gst-launch-1.0 rtspsrc location=‘rtsp://user:1234@192.168.123.108:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif ! fakesink’ is no problem
so i want put ‘rtsp uri’ in deepstream config file
what should i do?
You should input the uri without any quotation mark in the configuration file.
then throw out invalid rtspsrc error
