I use two inferences in deepstream.
I want to use the data from first inference in second inference.
And there are two plugins each implemente inference.
How can I pass the data of first inference to next plugin (second inference).
Could you share more information about your use case?
Is the model is detection + classification.
Deepstream do support the pipeline with detector+classifier inference:
Please check our document for the details:
[url]https://docs.nvidia.com/metropolis/deepstream/4.0/dev-guide/index.html#page/DeepStream_Development_Guide%2Fdeepstream_app_architecture.html[/url]
If you have the similar workflow, just replace the file path in the configure will be enough.
I am using custom detector + tracker and pose estimation.
In pose estimation plugin, I should get detector’s data.
How can I pass the data?
You can use the operate-on-gie-id and operate-on-class-ids flag.
Take source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt as example:
[primary-gie]
gie-unique-id=1
config-file=config_infer_primary.txt
[secondary-gie1]
[b]operate-on-gie-id=1
operate-on-class-ids=0;[/b]
config-file=config_infer_secondary_carcolor.txt
The detector, which is declared as primary-gie, use the ID=1.
The classifier of secondary-gie1 will be applied to the ROI from class#0 of engine ID=1.
But I am not using deepstream-app with config files.
I make custom gstreamer plugins like dsexample.
And then I make execute program like deepstream-redaction-app.
In this case, How can I do?
For dsexample-like application, you can directly control the data flow of GStreamer.
So just make sure you have feed the output of primary-gie into secondary-gie.
Ex. In dsexample, you will need to add a sencondary-gie in DsExampleProcess:
if (dsexample->process_full_frame) {
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *) (l_frame->data);
NvOSD_RectParams rect_params;
// Scale the entire frame to processing resolution
rect_params.left = 0;
rect_params.top = 0;
rect_params.width = dsexample->video_info.width;
rect_params.height = dsexample->video_info.height;
// Scale and convert the frame
if (get_converted_mat (dsexample, surface, i, &rect_params,
scale_ratio, dsexample->video_info.width,
dsexample->video_info.height) != GST_FLOW_OK) {
goto error;
// Process to get the output
output =
DsExampleProcess (dsexample->dsexamplelib_ctx,
<b>dsexample->cvmat->data</b>);
// Attach the metadata for the full frame
attach_metadata_full_frame (dsexample, frame_meta, scale_ratio, output, i);
i++;
free (output);
} else {
// Using object crops as input to the algorithm. The objects are detected by
// the primary detector
NvDsMetaList * l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
/* Should not process on objects smaller than MIN_INPUT_OBJECT_WIDTH x MIN_INPUT_OBJECT_HEIGHT
* since it will cause hardware scaling issues. */
if (obj_meta->rect_params.width < MIN_INPUT_OBJECT_WIDTH ||
obj_meta->rect_params.height < MIN_INPUT_OBJECT_HEIGHT)
continue;
// Crop and scale the object
surface, frame_meta->batch_id, &obj_meta->rect_params,
// Error in conversion, skip processing on object. */
continue;
// Process the object crop to obtain label
output = DsExampleProcess (dsexample->dsexamplelib_ctx,
// Attach labels for the object
attach_metadata_object (dsexample, obj_meta, output);
free (output);
