In docker: Fails to install deb that depends on libnvidia-compute-550, libnvidia-encode-550
I’m trying to build a docker image, that installs a deb that depends on libnvidia-compute-550, libnvidia-encode-550.
I get the following error:
16.45 The following packages have unmet dependencies:
16.49  driveu-node : Depends: libnvidia-compute-550 (>= 550.54.15) but it is not installable
16.49                Depends: libnvidia-encode-550 (>= 550.54.15) but it is not installable
16.50 E: Unable to correct problems, you have held broken packages.
Note: When we were using nvidia-driver-470 - it was ok.
nvidia-driver-535 is ok as well.
Attached is the Dockerfile.
Dockerfile.txt (2.1 KB)
Any help is much appreciated.
Thanks,
Adi
Some additional info:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.6 LTS
Release:        20.04
Codename:       focal
$ nvidia-smi
Mon Jul  1 17:19:42 2024
| NVIDIA-SMI 550.90.07              Driver Version: 550.90.07      CUDA Version: 12.4     |
|   0  NVIDIA GeForce RTX 3050 ...    Off |   00000000:01:00.0 Off |                  N/A |
| N/A   56C    P8             11W /   20W |     732MiB /   4096MiB |     12%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      2450      G   /usr/lib/xorg/Xorg                            214MiB |
|    0   N/A  N/A      4724      G   /usr/lib/xorg/Xorg                            198MiB |
|    0   N/A  N/A      4900      G   /usr/bin/gnome-shell                           70MiB |
|    0   N/A  N/A      6835      G   /usr/lib/firefox/firefox                      122MiB |
|    0   N/A  N/A     40339      G   ...yOnDemand --variations-seed-version         53MiB |
|    0   N/A  N/A     47783      G   ...seed-version=20240628-130141.777000         47MiB |
$ docker run --rm --gpus all nvidia/cuda:11.0.3-base-ubuntu20.04 nvidia-smi
Mon Jul  1 14:24:14 2024
| N/A   56C    P8             11W /   20W |     747MiB /   4096MiB |     12%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
$ apt list --installed | grep nvidia
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libnvidia-cfg1-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-common-550/unknown,now 550.90.07-0ubuntu1 all [installed,automatic]
libnvidia-compute-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-compute-550/unknown,now 550.90.07-0ubuntu1 i386 [installed,automatic]
libnvidia-container-tools/unknown,now 1.15.0-1 amd64 [installed,automatic]
libnvidia-container1/unknown,now 1.15.0-1 amd64 [installed,automatic]
libnvidia-decode-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-decode-550/unknown,now 550.90.07-0ubuntu1 i386 [installed,automatic]
libnvidia-encode-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-encode-550/unknown,now 550.90.07-0ubuntu1 i386 [installed,automatic]
libnvidia-extra-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-fbc1-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-fbc1-550/unknown,now 550.90.07-0ubuntu1 i386 [installed,automatic]
libnvidia-gl-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
libnvidia-gl-550/unknown,now 550.90.07-0ubuntu1 i386 [installed,automatic]
libnvidia-ml-dev/focal,now 10.1.243-3 amd64 [installed,automatic]
nvidia-compute-utils-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
nvidia-container-toolkit-base/unknown,now 1.15.0-1 amd64 [installed,automatic]
nvidia-container-toolkit/unknown,now 1.15.0-1 amd64 [installed]
nvidia-cuda-dev/focal,now 10.1.243-3 amd64 [installed,automatic]
nvidia-cuda-doc/focal,focal,now 10.1.243-3 all [installed,automatic]
nvidia-cuda-gdb/focal,now 10.1.243-3 amd64 [installed,automatic]
nvidia-cuda-toolkit/focal,now 10.1.243-3 amd64 [installed]
nvidia-dkms-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
nvidia-docker2/unknown,now 2.13.0-1 all [installed]
nvidia-driver-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed]
nvidia-firmware-550-550.54.14/unknown,now 550.54.14-0ubuntu1 amd64 [installed,auto-removable]
nvidia-firmware-550-550.54.15/unknown,now 550.54.15-0ubuntu1 amd64 [installed,auto-removable]
nvidia-firmware-550-550.90.07/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
nvidia-kernel-common-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
nvidia-kernel-source-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
nvidia-prime/focal-updates,focal-updates,now 0.8.16~0.20.04.2 all [installed,automatic]
nvidia-profiler/focal,now 10.1.243-3 amd64 [installed,automatic]
nvidia-settings/unknown,now 555.42.02-0ubuntu1 amd64 [installed,automatic]
nvidia-utils-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
nvidia-visual-profiler/focal,now 10.1.243-3 amd64 [installed,automatic]
xserver-xorg-video-nvidia-550/unknown,now 550.90.07-0ubuntu1 amd64 [installed,automatic]
